10-14-2019, 07:05 PM | #1 |
Rep 10
Winter Wheels / Tires
Hello,
I have a 2019 440i xDrive coupe with M Sport Brakes and 19" wheels. It's a Canadian model if that matters. I want to go non-staggered Michelin X-ICE Xi3s. When I put my car into tire rack's car configuration it doesn't give me the option for M Sport Brakes. Only Track Handling Package, so I don't know if it applies to my car. The winter tires it suggested was 225/45R18 with 18x8 wheels and between ET 29 - 32. Which is the best offset to choose? Thank you. |
10-15-2019, 06:35 AM | #2 |
A family of bimmers
2747
Rep 7,742
The 32s will sit 2mm out compared to a stock fitment. If you go with 29 they will be out another 3mm. Which, in the winter isnt necessarily a bad thing to prevent slinging crap all up the side of the car. I personally would stick with 32mm offset though.
You'll have to be careful with certain 18s as they have been reported to not clear msport brakes. Might be a good idea to call Tire Rack and speak to one of their reps.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills Last edited by wdeerfield; 10-15-2019 at 08:55 AM.. |
250gtcalifornia0.00 |
10-15-2019, 08:56 AM | #4 |
A family of bimmers
2747
Rep 7,742
I wrote it incorrect. the 32 will sit further in than the 29. I would still recommend a 32 offset for winter over the 29
10-16-2019, 05:09 PM | #6 |
Rep 6,703
For reference, we recommend the following fitment for winter use as a direct fit:
Front & Rear: 18x8.5" ET35 with 225/45-18 winter tires In response to your original question, the 18x8 with an offset between ET29 and ET32 will work wonderfully as well! You will be hard pressed to notice the 3mm difference in offsets in that range. - Max
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
10-16-2019, 06:09 PM | #7 |
Rep 10
Thanks for the answer, Max!
I wish I had gone with Apex wheels, but the shop I ended up ordering my tires/wheels from didn't have them in stock. I heard such good things about them. Thanks again. |
