BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Add tire pressure and temperature to the TPMS display
      08-14-2019, 09:23 AM   #45
kalinamichael
Drives: X5 e70 / 3er f30
I've got x5 e70 LCI
I've got S2VBA as factory option
I did:
- RDC - aktiv
- RDC_SAFETY - aktiv
But nothing happend. Stil have green wheels ((
Any ideas?
      08-14-2019, 11:17 AM   #46
atzebmw
Drives: Tesla Model 3
Originally Posted by kalinamichael View Post
I've got x5 e70 LCI
I did:
- RDC - aktiv
Any ideas?
I'm not sure if i understand.
Does your car had already the S2VBA or did you retrofit the RDC?
To see the tire pressure and the temperature you need more codings.
      08-14-2019, 11:30 AM   #47
kalinamichael
Already had. What more codings?
      08-14-2019, 12:49 PM   #48
atzebmw
Check these settings ( some ecus will probably have a different name):
FEM_01 > RemoteControl 30D0 > RC_RDC_ENABLE = aktiv
ICMQL > Daten 3000 > IcmKod_B_S2VBA = verbaut
DSC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_RDCi_l = nicht_aktiv
DSC_CT01 > DSC_CODIERDATEN_ALLGEMEIN 3000 > C_Funktion_RPA_e = nicht_aktiv
DSC_CT01 > DSC_CODIERDATEN_RPA_CONTI 3002 > C_RPA_Extra = nicht_aktiv
HU_NBT > EXBOX 3001 > RDC = aktiv
HU_NBT > EXBOX 3001 > RDC_DRUCK_TEMP = aktiv
HU_NBT > EXBOX 3001 > RDC_FORTSCHRITTSANZEIGE = aktiv
HU_NBT > EXBOX 3001 > REIFENUEBERWACHUNG_RDC_RPA = rdc
HU_NBT > EXBOX 3001 > RPA = nicht_aktiv
KOMBI L7_MID > ERM_Konfiguration 3004 > ST_TYR_RDC_ALIVE = aktiv
KOMBI L7_MID > ERM_Konfiguration 3004 > ST_TYR_RDC_TIMEOUT = aktiv
KOMBI L7_MID > FZG_Ausstattung 3003 > DSC_MIT_RPA = ohne_RPA
      01-23-2021, 02:43 PM   #49
fmorelli
fmorelli's Avatar
Drives: Atacama Yellow 35i
Would be nice if this question resolved. Did you look at the additional codings? What happened? Did you solve it? Thanks!
Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport.
      12-19-2022, 07:49 AM   #50
tomjonesBT33
tomjonesBT33's Avatar
Drives: 2006 Z4 M Roadster
resolved?
I have an e70 x5 as well with RDC. Did you ever resolve this?
The HU is CIC. It does not have the parameters: RDC_DRUCK_TEMP = aktiv or RDC_DRUCK_TEMP = druck_und_temperatur.
What other parameters and/or modules should I check?
Thanks.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic
2012 X5 M - Monte Carlo Blue Metallic
2017 X1 xDrive28i - Alpine White
      12-19-2022, 08:04 AM   #51
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
In order to code TPMS you must have TPMS.
      12-20-2022, 11:35 AM   #52
tomjonesBT33
I have factory TPMS. VO has 2VB as one of the installed options. The RDC module is installed and comes up as RDC in the UIF in INPA, but RDCLC in NCSExpert. And I have the metal valve stems/TPMS units in the tires.
That should be all I need, correct?
      12-20-2022, 02:50 PM   #53
Billfitz
Billfitz's Avatar
It would seem so. I coded mine to show temperature as well as PSI with Bimmercode. It showed PSI already. If yours didn't from the get go something isn't right.
      12-21-2022, 10:23 AM   #54
tomjonesBT33
Which module did you code for the temp and PSI? I checked through the HU CIC FSW_PSW.trc file and did not see an option for druck_and_temperatur
      12-21-2022, 11:14 AM   #55
Billfitz
Billfitz's Avatar
HU-NBT> Tire pressure control
If you don't have NBT I can't say what might work, if anything.
      12-22-2022, 11:19 AM   #56
BavarianJeff
Drives: bmw 335i
I searched this thread and couldn’t find the answer. Question is can my 2013 335i be coded to display pressures? I have metal valve stems.
      12-22-2022, 11:51 AM   #57
Billfitz
Billfitz's Avatar
If you open Bimmercode and go to HU-NBT and there's no entry for Tire Pressure Control you don't have Direct TPMS, which is the system that supplies temperature and pressure readouts. If you don't have HU-NBT I can't say if you have Direct TPMS or not. I wouldn't assume that the valve stem material is definitive. My last car had metal valve stems, but not Direct TPMS. It had Indirect TPMS, which doesn't give a readout, only a warning if a tire goes low.
      12-23-2022, 06:02 AM   #58
sspade
sspade's Avatar
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Should be able to with BimmerCode, yes.
I've done it on my prior 2014 328i and current 2016 320i.
