BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Front cigarette lighter port not working...
      10-02-2015, 12:02 AM   #1
1flossedm3
Drives: ...
I just got my 335xi, go to use the front port for my phone charger... doesn't work.
Plug it in the rear port.. works fine.
Dealer said it's testing fine at 4 volts, I checked the fuse and it's fine.
Any ideas?
      10-02-2015, 06:47 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
If it reads 4 volts it's not fine. The lighter outlets should read between 12 and 14 volts.
      10-02-2015, 07:26 AM   #3
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Try plugging a different device into the front charger port - there are actually two; one is above the cupholders and another is on the passenger side nearest the center console on the bottom side of the glove compartment. The plug on some devices doesn't always connect at the tip without pushing it further down into the receptacle.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      10-02-2015, 09:12 AM   #4
1flossedm3
Drives: ...
I will try that thank you. Dumb dealer!
      10-02-2015, 09:37 AM   #5
1flossedm3
Drives: ...
Found that little hidden gem located underneath glove box. BEST SPOT EVER for a charger port.
Works fine. I'll have to go back to the dealer and tell them its still broken. Good news is I can at least charge my phone now .
      10-02-2015, 12:59 PM   #6
ji99lypuff
Drives: 2014 bmw 328xi
Wheb you checked the fuse was it the one in the trunk or the engine bay?
      10-02-2015, 03:31 PM   #7
1flossedm3
Drives: ...
Engine bay #69
2015 BMW 335xi M Performance Edition
LOADED
Alpine / Coral
      10-02-2015, 05:44 PM   #8
NightWriter
NightWriter's Avatar
4844
Drives: G80 M3 Pure
I thought I had the same issue, then I tried a different USB adapter that reached down deeper, and it worked fine.
      10-02-2015, 06:28 PM   #9
CHCCubs
CHCCubs's Avatar
Latvia
97
Drives: 2013 BMW 328i xDrive Sport
Had a similar issue with plug on a portable air compressor. Certain plugs definitely don't seem to work well with 12V ashtray outlet.
2013 BMW 328i xDrive Sport Line
Mineral Grey on Everest Grey
      10-03-2015, 08:39 PM   #10
Biorin
Biorin's Avatar
2785
Drives: to get cheeseburgers
I have the same issue, but it used to work, and now it doesn't - same item, so it's not a depth thing. Hmm.
      10-04-2015, 10:21 AM   #11
mayja6
Drives: 2015 328i
I have had the same issue as well. Two different phone chargers won't work in the front outlet. One will kind of work if I push down on it really hard but loses connection as soon as I let go. They both work perfectly in the rear outlet. I took it in to the dealer as well but they said it tested out fine, and my portable air compressor worked fine in the front outlet when I finally tried it. It looks like the front outlet just has a really sensitive/crappy connection to it that is very particular about what plugs work in it.
      12-30-2015, 11:27 AM   #12
Jwitbo44
Drives: 15 335i xDrive MSport Min Grey
I am having the same issue so this post has been helpful. I splurged (too much) on the Escort 360 and was bummed to see that it would not work in the front outlet but would in the back. I had never used the front outlet having bought the car in June. Had no idea about the magic outlet under the glove box.... that works! I am scheduled to take the car into the dealer for the front outlet.... if it is not a fuse and only a weird port that has tempermental connectivity... that still seems like an issue to me.
      01-06-2016, 09:54 AM   #13
BBDDVV
Belgium
Drives: G31 530e
I have the exact same symptoms in my F15, and after a trip to the dealer it seems like:
- the outlet next to the ashtray is of 'Size A' and doesn't work with any of my USB chargers.
- the outlet in the back is of 'Size B' and does work fine with my USB chargers.
From Wikipedia
12-volt cigarette lighter receptacle and plug, size A:
- Receptacle inside diameter: 20.93 - 21.01 mm (median 20.97 mm)
- Plug body diameter: 20.73 - 20.88 mm (median 20.805 mm)
- Most often used in American automobiles
12-volt cigarette lighter receptacle and plug, size B:
- Receptacle inside diameter: 21.41 - 21.51 mm (median 21.455 mm)
- Plug body diameter: 21.13 - 21.33 mm (median 21.18 mm)
- Most often used in European automobiles, and sometimes as a second socket in American automobiles expressly for DC power connections.
Turned out my adapters don't have a chamfer at the bottom part of the plug, preventing the size B USB charger plug to move down the last ±5mm (where the above diameter restriction is in the front outlet).
In my previous F11, my USB chargers did work in the front outlet, but only when pressed (very) firmly. No issues in the outlet in the back.
I guess the height of the inner diameter is slightly higher in the F15 than it was in the F11...
I hope this helps saving someone a trip to the dealer... :-)
      02-09-2016, 02:47 PM   #14
Livetodrive
Drives: 2016 340i X Drive
I had the same issue with my M-B. I bought a double outlet adapter at Best Buy. It fit into the car's cigarette lighter and let me connect my devices.
      02-09-2016, 03:06 PM   #15
powerdbygarrett
Drives: 2020 F83
Where is this second hidden 12v exactly?
'15 335 Sportline xDrive
Jb4 - ER: Downpipe, Charge Pipe, TTIC Pipes, Intercooler - BMS Intake
      02-09-2016, 03:26 PM   #16
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
Not just a BMW thing. Have had the same issues with the Allroad and the Macan.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      02-09-2016, 03:28 PM   #17
StraightSix-d
StraightSix-d's Avatar
Drives: F30 330d Luxury (2015)
It's just under the glove box..sort of around where the yellow arrow is.. I had the same problem with occasionally functioning cigarette lighter 12v ports - all due to ill fitting chargers.
F30 330d LCI Luxury (2015) Review
E90 325d (LCI) - gone..
Review
      02-09-2016, 10:49 PM   #18
powerdbygarrett
Drives: 2020 F83
Originally Posted by StraightSix-d View Post
Attachment 1361930
Found it. Thanks!! Car is full of secretes lol
      02-10-2016, 10:37 AM   #19
paul e
Drives: 340i xDrive 6MT
Attachment 1361930
Ahhh!!!
Thanks for this, I was looking inside, around but NEVER directly under. And it's a perfect spot as well.
      08-12-2018, 10:41 PM   #20
Robario12
Drives: 18 430i GC/E92 M3/E46 M3
Can anyone post some links of adapters that work fine?
      08-13-2018, 04:23 AM   #21
IAmATeaf
IAmATeaf's Avatar
Drives: 2015 F30 335i
2015 BMW 335i  [0.00]
I too had this and like others the dealer reported no issues with it. I did some digging around and for me it turned out that the centre console port being a cigarette lighter has some extra internal prongs which can stop a USB adapter from fully being pushed in. The other ports in th car are accessory ports so won’t have these prongs which is why the USB adapter works in them. I ended up scouring Ebay until I found an adapter with a slim tail end, ravpower as it happens which works.
      10-14-2018, 06:04 PM   #22
Lagemba
Drives: F32 420d 2015 M Performance
Yeah the front port underneath the radio console doesn't work for me either. I use the USB port underneath the arm rest... Will try the port underneath the glove compartment also. Any suggestions on how to fix the front port? Thanks
