05-07-2019, 12:23 AM | #2245 |
Rep 141
I'm still learning how to read data logs, looks good to me. Did I miss anything?
https://datazap.me/u/tsa8151/log-155...ta=3-4-6-32-33 bootmod3 pwg stage 2 |
05-07-2019, 02:21 PM | #2246 |
Rep 252
Drives: 2017 Model S P100D
I'm looking to get a bm3 license in the next couple days, but I don't have a dp yet. I'll be buying the dp at the same time as getting the flash done, however they don't have time to do a dp install right now. Question is:
Which map should I run until I get the dp installed? I have intake, fmic, chargepipe, and exhaust done. Should I just flash to stage 2 right away since I'll be getting the DP installed within a week or two? Thanks! |
05-07-2019, 02:34 PM | #2247 | |
dad bod
387
Rep 382
'15 F30 Estoril Blue 335i xDrive | 8HP | Stock Turbo | 420 awhp / 451 awtq | 11.85 @ 115 mph
E30 JordanTuned on BM3 | XDI-60 HPFP | Fuel-It! lines + sensor | VRSF FBO | GFB DV+ | XHP | Vörsteiner VFF-107s | Dinan Springs |
05-07-2019, 02:47 PM | #2248 |
Rep 323
Drives: 2013 BMW F30 N55 335ix 6mt
bm3 failed aquring ots map. trying to download stage 2. i paid for the maps. i also havent been able to download the free map.
05-07-2019, 06:48 PM | #2249 |
Rep 931
05-08-2019, 01:57 PM | #2250 |
Rep 92
For those on stage 2 tune with NGK 97506 spark plugs. Would it be safe to switch back to stock tune/Stage 1 without having any misfire/rough running problems?
05-08-2019, 03:38 PM | #2251 |
Rep 373
Ptf are trying a tcu flash for the torque limitation in 3rd and 6th of the 8hp box. Has anyone got this flash yet and tried it? Is it just a removal of the limitations or are they improving shift speed as well?
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
05-08-2019, 03:46 PM | #2252 | |
Rep 1,375
05-08-2019, 05:37 PM | #2253 | |
Car Hypochondriac
335
Rep 901
Edit: I can't read. Above it was mentioned that it will be a TCU flash, that would be very interesting... Last edited by Eschmacher; 05-10-2019 at 08:03 AM.. |
05-09-2019, 10:20 PM | #2254 |
Rep 252
Pulled the trigger on bm3 today. Went over to CTS Turbo and they set it up for me. However.....
They set my OTS map to stage 2 91octane, even though I use exclusively chevron 94. Is this a problem? Does anyone have experience with the OTS maps and Vancouver gas? I tried doing a third gear data log, I'm not sure how everyone saves them and cleans them up nicely but I'll insert it anyway. Third gear, roughly 20kph to 130kph, relatively flat terrain, 20C, stage 2 91 map with chevron 94 I think I'm just going to buy the st2 93 map, however I don't know if it will be knocking badly like the guys at CTS said. Any info would be great! EDIT: Derp moment, link here: http://www.bootmod3.net/log?id=5cd4e659ae729b5de7fca62e Last edited by codestar; 05-09-2019 at 10:28 PM.. |
05-09-2019, 10:27 PM | #2255 | |
Rep 529
They are likely correct that the ots 93 octane map will be too aggressive for shitty western Canadian 94 octane that in reality is barely 91 octane. Make sure your car is running strong on the 91 map before even trying the 93 map.
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
05-09-2019, 10:37 PM | #2256 | ||
Rep 252
05-09-2019, 10:42 PM | #2257 | |||
Rep 529
Your wgdc is also oddly high throughout the pull which may be indicative of a boost leak.
05-10-2019, 01:39 AM | #2258 | |
Rep 222
i mean i hope thats what they are going for |
05-10-2019, 08:04 AM | #2259 |
Car Hypochondriac
335
Rep 901
I'm dumb and glossed over the fact that it was a TCU flash, my mistake. I'm very interested to see a TCU flash from PTF.
05-10-2019, 08:57 PM | #2260 | |
Rep 142
05-12-2019, 02:46 PM | #2261 |
Rep 101
bootmod3 OBD WiFi Agent Network Name Change from Mac OS Command Line
I got tired of renaming my phone to connect via hot spot to my WiFI agent to connect to bootmod3. There are instructions on how to edit the network information in the device firmware using a Windows PC on the bootmod3 site.
This works if you have access to PC, but it can also be done from your Mac OS computer using the built in SSH client software that came with it. Here's how... bootmod3 OBD agent device comes preconfigured with the bootmod3 WIFI network name. To change it to a different network name, follow these steps from a Mac OS machine:
📺 Subscribe to my F30 YouTube Channel https://www.YouTube.com/M3Beats
📷 Follow my F30 335i on Instagram https://www.instagram.com/m3beats Last edited by ROBBMAC; 05-12-2019 at 02:52 PM.. |
05-15-2019, 05:42 AM | #2262 |
Rep 373
Probably a dumb question, do i need a flex fuel sensor to run e30 with the ots map (n55)? How does this sensor integrate with the ots file does it pull timing if eth levels are too low? as i am thinking of getting a stage 2 lpfp and wondering if i need this sensor and how it will work with bm3?
thanks
05-15-2019, 07:56 AM | #2263 | |
Rep 1,499
No you don't need the sensor but I would recommend the Ethanol content tester (https://www.fuel-it.com/ethanol-content-tester/) then use an e85 calculator (http://www.georgebelton.com/E85Calculator.php) to figure out how much gasoline and ethanol to mix. With true E85 I mix 4 gals of E85 with 12 gals of 93 octane which gets me 96 octane and a 28.9% ethanol mix.
05-15-2019, 01:57 PM | #2264 |
Rep 470
Is anyone else experiencing problems with dropouts and disconnections? I have a pixel 3 and it refuses to just stay running smoothly. Kind of annoying since the whole point of the obd agent was to prevent having to use a laptop for logging and stuff.
05-15-2019, 03:35 PM | #2265 |
Rep 141
The dashboard will often freeze when I go WOT. Ill finish my pull and the dashboard will be stuck at 6500 rpm, etc. Until I re identify the agent.
05-15-2019, 03:36 PM | #2266 | |
Rep 2,654
