12-17-2019, 05:05 PM | #23 | |
Rep 4
Yes, the Advance Auto should have an OBD reader. How would that help as the BimmerLink app isn't showing any error codes and I'm pretty sure that a standard OBD reader won't allow for registering the battery? |
12-17-2019, 05:16 PM | #24 |
Rep 16,082
You need a tool, not a reader. A reader tells you what's wrong, a tool, like a Foxwell 510, can fix it. Since Pep Boys is known to register batteries they must have a tool to do it. Advance may, since they sell batteries the same as Pep Boys does.
12-17-2019, 05:16 PM | #25 | ||||
Rep 2,671
12-18-2019, 10:53 AM | #26 |
Rep 425
FWIW
I called my local Autozone asking about registration after stumbling on to this thread.
It appears that they too are able to handle the registration like Pep Boys. |
12-19-2019, 04:42 PM | #27 |
Rep 4
The frustrations continue!
Advance Auto (where I bought the battery) doesn't have a tool that will do BMW registrations. Pep Boys here in Austin doesn't have an OBD tool that will handle BMW registrations on a 2011 BMW 328i. And Auto Zone also won't do 2011 BMW 328i battery replacements because they don't have the necessary registration tool. Does anyone have confidence that a $120 Foxwell NT520 will succeed even as the BimmerLink app with Veepeak OBD Check BLE adapter did not? Thanks in advance for ideating how I can get past this aggravation! -Trevor in Austin |
12-19-2019, 04:52 PM | #28 | |
Rep 1,502
12-19-2019, 05:04 PM | #29 | |
poopycat
266
Rep 791
I think this new generation is almost against calling a place, describing the problem, and asking for an estimate. OMG and if you have to charge them, instagram blows up. |
12-23-2019, 03:45 PM | #30 | |
Rep 4
deviantspeed For the record, I am 52 and had already called the 3 recommended auto shops after my registration challenge not to mention 2 BMW dealerships and 1 indy repair shop initially which is when I learned that replacing the battery can run $450+. So, your salty comments don't square with the situation. The first indy shop here in Austin, TX wanted $49.50 to register my battery. The second indy shop was Terry Sayther Automotive and they certainly earn their 4.9 star Google rating. They were happy to do it free of charge immediately upon my stopping in. They were awesome and their free advice model and their garage are impressive. As for the error when using BimmerLink, it appears my second battery wasn't coded to AGM after the BMW dealership installed a new one under warranty roughly 5 years ago (it was only one month after I bought the car CPO and it took some escalations to have it covered) and that was blocking the registration from happening properly. It had to be reset which Terry Sayther tech Matt easily handled with his full powered BMW OBD tool. So, the drama is behind me no thanks to the BMW dealership tech who fell short years ago. :-( Thanks to all who assisted. And happy holidays. |
Pauloxxi339.00 |
12-24-2019, 09:30 AM | #32 |
Rep 2,197
I'm glad you found Terry - you're in good hands now!
12-24-2019, 10:20 AM | #33 | |
Rep 1,502
12-28-2019, 03:45 PM | #34 |
Rep 233
I've read this thread completely and I'm still lost. I can't even locate a compatible battery! 90 or 92 ah, 900 CCA . I'm shopping on line. I want to register it myself and have the Bimmerlink that should do it.
Advice???
2015 Mineral White 335xi Sport trim
02-18-2020, 10:35 AM | #35 |
Rep 919
My indy shop was unable to register the battery on my 2016 340i xDrive. It used both autologic and another tool.
The battery management area showed, and it showed the current state of charge of the battery...so I'm wondering whether maybe the car registers itself in newer models? I put in an identical battery...and want to save the money not going to the dealer unless I have to. I will get this foxwell nt510 tool everyone's been talking about here...unless I learn it's not supporting the b58 or 2016s. Are we sure 2016s need battery registration?
02-18-2020, 08:23 PM | #36 |
Rep 338
When i got my battery replaced just recently, my shop used the J-Box scanner, but those devices are super expensive, was real easy for them though..Love this Indie shop near me, cos i am friends with the mgr and he installed the new OEM 90ah batt and coded it for under $300..
2013 320ix N20 8AT|BM3 stg1|Muff Res Delete|HPB-LED-Amber-DRL's
IG: DadzBmer_N2o |
02-20-2020, 07:05 AM | #37 | |
Rep 919
Billfitz8243.00 |
02-20-2020, 07:18 AM | #38 |
Rep 16,082
A Foxwell can pay for itself the first time you use it. Mine did. Be sure to keep it in the car. If you get a code that limits the car while away from home you want to be able to clear it.
02-20-2020, 11:36 AM | #39 |
Rep 2
Battery
So if I change up the battery from stock, my Foxwell will allow me to register a new battery with different specs? Just want to make sure before I go out and bring one of those 60 lb beasts home.
02-20-2020, 03:29 PM | #40 |
Rep 919
Yes, but I'm not sure you have unlimited range...and I'm not sure that changing the battery size is such a good idea. I'd stay agm and 90 Ah just because our car is so electricity dependent and sensitive. The agm is probably needed if you use the auto start/stop... otherwise ymmv.
travelingjohn0.00 |
02-20-2020, 06:00 PM | #41 | |
Luxury at the redline :)
9105
Rep 7,563
I'm guessing it requires programming to add a lower amperage battery. |
02-20-2020, 08:32 PM | #42 | ||||
Rep 2
02-20-2020, 08:57 PM | #43 | |
9105
Rep 7,563
Just pointing out that the menu does not show a battery VO string below 80ah, regardless. However, the M4 uses a lithium ion battery that rated at 69AH.. Go figure right : |
02-20-2020, 09:04 PM | #44 | ||
Rep 338
IG: DadzBmer_N2o |
