BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Battery registration question
      05-14-2020, 12:25 PM   #45
califorbmw
Drives: 2013 X5
As mentioned recommended here, I used a new battery with specs that were very close to the original battery.
Then I followed instructions on YOUCANIC on how to register the BMW battery with a Foxwell scanner.
https://www.youcanic.com/vehicle/bmw...-a-bmw-battery
Everything went fine, been over two weeks with no issues.
Thank you for your tips everyone.
      05-23-2020, 10:35 PM   #46
mikedaul
Drives: BMW 335i GT
I had the exact same problem as the OP.
Turns out the fix (at least for me) was to power off the engine when doing the battery registration in BimmerLink.
      05-25-2020, 12:02 PM   #47
bobiam
bobiam's Avatar
Drives: Mineral White 2015 335xi
Did you first get the error message and then discover the correction?
So, your new batt is not quite the specs of the OEM original, but you accomplished the registration successfully? Sounds great. I've be hesitant to buy the new batt, but I want to do it before next winter. Anything else you can tell me??
2015 Mineral White 335xi Sport trim
      05-29-2020, 01:53 PM   #48
Rick4345
Rick4345's Avatar
472
Drives: 2022 WRX World Rally Blue
Interstate
I'm going to be replacing the batteries in both of my cars soon.
I am looking at Interstate batteries because I've had a lot of luck with them.
The battery has a 95Ah rating. The cars would be a 15 328Xi and a 17 M2. The M2 has a 91Ah rating and the 328Xi has an 80Ah rating. I may have to go with the smaller rating on the 328Xi.
I was hoping to do this with Bimmerlink.
Could it happen or do I need to go another route?
All advice would be greatly appreciated!!
      05-29-2020, 02:56 PM   #49
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
I don't know about Bimmerlink, but Bimmercode does batteries. You don't need to use an 80Ah battery in the 328, you just need to register it with the closest value that your tool will allow. Bimmercode, for instance, has 80 and 90Ah options for AGM batteries.
      05-29-2020, 03:22 PM   #50
Zanity
Zanity's Avatar
Drives: 428i
Are you sure that's a good idea tho ? I'm heavily against changing Ah size from stock, lower or higher, the amount of complex interconnected programs that uses these variables in the ECU is just not worth messing with. Not worth the risk to me, just an aftermarket one that fully fits the OEM spec.
Mods: Dinan Tuned, Intake, Catless DP
      05-29-2020, 04:04 PM   #51
gasman82
gasman82's Avatar
17
Drives: F30 335d xdrive
BimmerCode does batteries?
I thought it was Bimmerlink that did batteries?
      05-29-2020, 05:03 PM   #52
Billfitz
Billfitz's Avatar
My error, it will code battery type and capacity, but it won't register.
      06-06-2020, 01:27 PM   #53
AudiA4
AudiA4's Avatar
648
Drives: 2022 G01 X3 M40i (Black/Black)
Okay, I just posted a question in the forums about a problem replacing my battery in my F30 335i. I bought a battery from a local auto parts store and swapped it out myself, and the car still won't start. Are you guys telling me that we can't even do something as simple as changing the battery without some stupid dealer code/registration? That's supremely ridiculous if true. This is my second BMW, and I don't recall having this issue before.
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust
2006 E90 330i (Silver) 6MT, Sport
      06-06-2020, 02:10 PM   #54
Billfitz
Billfitz's Avatar
Registration tells the car that it has a new battery, so it won't overcharge it. It has no bearing whatsoever on whether the car will start or not. If it didn't start before you changed the battery and it won't start after you changed it and you've verified that the new battery is charged then the battery probably wasn't the problem in the first place.
      06-30-2020, 10:09 PM   #55
mikedaul
Drives: BMW 335i GT
Sorry for super slow response!
Exactly - I got the same error as the OP at first. Doing the registration step with the engine off was the key for me.
I've put a few hundred miles on the new battery with no issues so far.
      10-15-2020, 09:28 PM   #56
zeetotheh
Drives: 2015 BMW 428i
I have a 2015 428i BMW.
I am about to replace the batter with:
- S/N: 61 21 9 343 746
- AGM 12V 92AH 850A
I have decided to buy Carly for the registration, but I would appreciate some advice on what battery brand to go for? Would be great if you have a link as well.
Thanks
      11-18-2020, 11:35 PM   #57
chuckles01
Drives: 2014 328i Sport, 6M
So, I'm a bit confused about the battery part #, and am wondering if someone here has the answer.
I have a 2014 F30 328i, my current battery is 61-21-7-575-327 (90Ah, 900 CCA). Through searching, it seems my current battery is no longer used by BMW so I need to replace with a slightly different one. For ease, I am going to just order the battery from BMW and replace and register myself with Bimmerlink.
From searching online, it seems F30 owners have been replacing with this battery: 61-21-2-353-812 (92 Ah, 850 CCA)
However, when I search on different BMW parts websites, they all list 61-21-7-639-053 as the replacement battery.
I'm confused, which battery part # is correct? Did BMW change it again?
2014 BMW 328i, 6-speed
Prem / Nav / Drivers Assist / Heated Seats / Lighting
      11-19-2020, 08:11 AM   #58
Billfitz
Billfitz's Avatar
There's no reason to buy a BMW labeled battery, unless you like paying too much. Your best bet is Pep Boys, who will install it for free, and most locations will register it as well. Call first to be sure if a particular location does registration. https://www.pepboys.com/car-batterie...0%202.0L%20Dsl
      11-19-2020, 11:50 AM   #59
chuckles01
Thanks, I've decided to purchase a BMW battery and need some insight to the part numbers if anyone knows.
      06-23-2022, 09:13 PM   #60
DrivingPassion
DrivingPassion's Avatar
Drives: '15 M235xi
For around $100 less than your stealer wants you can buy a battery and a Schwaben scan tool that will register your battery and a whole lot more.
https://www.ecstuning.com/b-schwaben...020sch01a~scf/
Here's what Schwaben product description says:
Can reset most batteries but cannot change battery load setting or convert from AMG to Lead Acid at this time or vice versa. Possible in the future with software updates.
2015 M235i xDrive 8AT
      06-23-2022, 09:21 PM   #61
Billfitz
Billfitz's Avatar
Battery Ah and type changes are done via coding. Bimmercode will do it. You should not change from an AGM to wet cell battery.
