05-19-2022, 10:24 PM | #23 | |
Rep 409
What about the other CF pieces? Not listed. The large center console piece, and the dashboard piece, etc? Any chance you have links on those. It's always more comforting to buy from places that you know others have been happy. |
05-19-2022, 10:37 PM | #24 | ||
Rep 312
I went with genuine OEM F80 trim I picked up off eBay. Just did a quick search and looks like this could work.. https://www.ebay.com/itm/14455596892...#38;media=COPY There is also an Ali option https://a.aliexpress.com/_mtMra8I |
05-19-2022, 10:45 PM | #25 | |
Rep 409
05-21-2022, 11:08 AM | #26 |
Rep 312
I don't know the actual LED chip supplier. I will run some before/after illumination tests and report back. Hopefully going to work on getting these installed tomorrow so I can get them out of my living room.
05-24-2022, 06:01 PM | #29 |
Rep 584
I'm thinking of buying either these tips
https://a.aliexpress.com/_m0JkHrs Or these tips. https://a.aliexpress.com/_mrkXWT4 Was thinking about a gloss finish. But concerned about how they'd look after a while, esp with the effect heat will have in the lacquer... |
boyerizm243.00 |
05-24-2022, 06:52 PM | #30 | |
Rep 312
I mean for the money you can just swap them out every year lol |
05-25-2022, 12:15 PM | #32 |
Rep 312
I went with 60mm for my MPE. I'm still waiting on them but I'm hopeful it will work. I had to hunt through this thread https://f30.bimmerpost.com/forums/sh....php?t=1339852
05-25-2022, 01:24 PM | #33 | |
Rep 1,818
boyerizm243.00 |
05-25-2022, 01:35 PM | #34 |
Rep 55
Well, I *didn't* have an AliExpress addiction before now...
I am always hesitant to buy from there because frankly I have never really trusted it, but then I consider all of the same crap I buy from Amazon and it's all coming from the same place. Definitely going to check out the steering wheel wrap, that's about the first I have seen that looks like it's appropriately cut for the shape of the wheel. Thanks for the links and also GFY for providing the links |
boyerizm243.00 |
05-25-2022, 03:39 PM | #35 | |
Rep 312
B58-Hustler39.00 |
05-25-2022, 04:03 PM | #36 | ||
Rep 312
I just went out a measured and now I'm thinking I might need to get a smaller size. The thread suggested 58mm OD but I'm getting 56mm for the pipe size. OD on the tips is 70mm, not much clearance between so I'd stick with that. |
05-25-2022, 04:07 PM | #37 | |
Rep 1,818
The tip you're measuring is a slip on over the exhaust, so when you measure where the tip starts, is not the measurement you need to take. You need to take that tip off, by loosening the screw on the bottom, and measure the exhaust that's currently covered by the tip. You can even check sites that sell aftermarket tips, they all list MPE as 67mm: https://monacoms.com/bmw-2-3-4-f22-f...ust-tips-2pcs/ Last edited by toxik; 05-25-2022 at 04:15 PM.. |
05-26-2022, 05:14 PM | #38 | ||
Rep 312
The link you sent is for the >335i MPE which must have a larger exhaust pipe. Also the OD wouldn't work because the spacing between pipes is closer for the N20/N26 exhaust. But glad you challenged me because I was about to buy smaller tips. Instead, the ones I bought should work great. |
toxik2454.50 |
05-31-2022, 12:12 PM | #40 |
Rep 145
I know for the stock exhausts, there was a nub that locked the old tips in and people had to shave it down for the new tips to fit in correctly. I'm not sure if yours has it, but wanted to throw that out just in case
boyerizm243.00 |
05-31-2022, 12:30 PM | #41 | |
Rep 312
Could get a size smaller but the issue is the outlet OD is 80mm where as OEM is 70mm and the pipes are too damn close together. |
06-01-2022, 03:52 PM | #43 | |
Rep 312
I mean I like Brian but I'm not going to just hand him the $500 difference for drop shipping lol |
06-01-2022, 04:13 PM | #44 | |
alpinweiß
Rep 64
Tempting...I hate my halogens (put LED bulbs in, but they're fugly) |
