BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Some serious problems on my 428i ! Hopefully someone can help me out !
      06-17-2022, 07:15 PM   #1
kchung0618
Drives: Bmw 428i
I start my car today and it sounds like not smooth as usual. And then it suddenly stalled on the highway in a traffic jam. Will it be a spark plug issue since I saw the engine shaking a little bit which I am not sure normal or not? Or any other issue it could be?
Ps. I have installed a VRSF charge pipe and a bm3 stage 1 91 octane tune recently. The cp was installed in a shop and the screw of the connecting part of 2 pipe was not tight enough when I am driving back home and they separated for a while. But I do not have tool to tight them back. So I drive it back to the shop and ask them to tight it back for me. (You can say there is no cp when I drive back to the shop) I know it is a bad move now and I just want to fix it.
My car currently has a VRSF dp, cp, injen air intake in the engine bay.
      06-17-2022, 09:03 PM   #2
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
Did you pull the codes to see what the issue was?
Any leaks?
      06-17-2022, 10:41 PM   #3
kchung0618
Drives: Bmw 428i
Any leaks?
I cannot see any light on the dashboard. I feel like there are leaks from the charge pipe but the shop said no leak in there. Or should I go to another shop to check if there are any issues?
      06-17-2022, 10:46 PM   #4
weehe126
Drives: 2017 340i
Sounds like a bad coil or injector.
      06-17-2022, 10:51 PM   #5
kchung0618
Drives: Bmw 428i
Is it expensive to replace or fix it?
      06-17-2022, 11:01 PM   #6
BimR
Drives: 2016 328
Before you replace anything, please pull codes. A coil isn't expensive to replace so you hope it's something "smaller" like that. But.... Pull codes!
Billfitz8243.00
      06-17-2022, 11:02 PM   #7
kchung0618
Drives: Bmw 428i
Thank you. I will buy a reader for that.
      06-18-2022, 08:41 AM   #8
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
There's no need to buy a reader, there are at least a dozen free apps that will do. You just need a bluetooth OBD adapter.
      06-18-2022, 08:43 AM   #9
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Wait.. did they fix the charge pipe or not?
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      06-18-2022, 04:06 PM   #10
kchung0618
Drives: Bmw 428i
They said they fix it.
      06-18-2022, 04:10 PM   #11
kchung0618
Drives: Bmw 428i
Originally Posted by MichealPrescott View Post
definitely get the reader and run the diagnostics
I have bought it and read there is a code P00BD$07e8. I google it and it seems like related to mass airflow. I try to get to understand but I am being more confused.
      06-18-2022, 04:11 PM   #12
kchung0618
Drives: Bmw 428i
https://drive.google.com/file/d/1L7b...ew?usp=sharing
That's what it appears.
      06-18-2022, 04:30 PM   #13
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
You likely have a big boost leak. They didn't fix it
      06-23-2022, 09:42 AM   #14
Fliplegend
Fliplegend's Avatar
Drives: 2015 435ix F33
Considering it's a VRSF, I would bet fitment is garbage and you have a leak.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line
