BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > BimmerLink - Charge Air temperature logging
      02-05-2024, 01:22 PM   #1
lidation
Drives: '13 X3 F25 w/ N20 engine
In our N20 engine intake systems, there are two temperature sensors along the airway path:
1. MAF sensor. At the factory airbox. In BimmerLink it's the "Intake Air Temperature" and I have no problem logging this parametric data.
2. charge air temperature sensor. Right before throttle on the charge pipe. On BimmerLink it has "Intake air temperature before throttle valve, measured". The logging result from this is always zero. I sent an email to BimmerLink asking about this three weeks ago but no replies from them yet.
Anybody has successfully logged the charge air temperature from BimmerLink? Thanks!
FYI, below is a picture the two sensor locations marked out on my X3 w/ N20 engine.
      05-25-2024, 01:18 AM   #2
kepmic
Poland
Drives: BMW F30 328iX
In my case bimmerlink shows the same value for all 3 sensors ("Intake", "Intake before throttle" and "before throttle linearized") and looking at the relatively low temperature it takes it from MAF.
      07-10-2024, 02:08 AM   #3
misha_l
Drives: F30 328i xDrive
Hi! Have you managed to get "Intake air temperature before throttle" value in bimmerlink? Was it bad TMAP sensor or bimmerlink issue?
