01-01-2019, 11:49 AM | #23 | |
Rep 3,539
This is the catch can I have. Mishimoto made it for high flow diesel pickup engines. I haven't added any extra material to it. It's quite a bit larger than the other catch cans I've seen people use. If you're interested, I actually have another one that I couldn't get the bottom can portion to thread off. Mishimoto threads them on SUPER tight from the factory. I had to use a strap wrench and put the head of the can in my vise to get the can off of the second unit I got (that didn't work with the first unit). You can have the first one for cheap if you're interested. Last edited by FaRKle!; 01-01-2019 at 12:02 PM.. |
01-05-2019, 11:57 AM | #25 |
Master Sergeant
Rep 8
Large Mishimoto Oil Catch Can
To FaRKle on your post of 17 Dec 18 at 1:43, I too have the large Mishimoto oil catch can for my 328d. How did you mount it? I had been looking at two options: on the passenger side, using the existing heat shield screws; or on the driver's side near the front fender. I am in search of 25 mm ID hose today. Any help you can send, I'd appreciate it. My catch can is identical to the pic you posted on 1 Jan 16 at 11:49. Thank you!
01-05-2019, 03:26 PM | #26 | |
Rep 3,539
I'd skip trying to find 25mm ID hose. That's difficult and expensive. I used some 1" to 5/8" (25mm to 16mm) straight silicone reducers to pair with the AN10 hose. I also tried looking for new fittings with smaller ID barbs, but Mishimoto used a thread on these that's not terribly popular for barbs... |
07-16-2019, 12:32 PM | #28 | |
Master Sergeant
Rep 8
Hose elbows for OCC
07-21-2019, 11:41 PM | #29 |
Rep 238
08-06-2020, 03:31 PM | #30 |
Rep 365
Wanted to share my results using Mishimoto's compact baffled oil catch can. Unlike the larger size that FaRKle! used, the compact one has a smaller bracket and requires DIY bracket to offset it so that it clears the electrical connector below. I purchased a metal shelf bracket at Home Depot, then used my angle grinder to cut it and metal brake to bend it. Turned out okay. I like the brackets Mishimoto has for M3 vehicles, if they offered a slightly modified bracket with larger front to back offset, we could use it on ours. I am working on proof of concept bracket to attach to 2 screws near the latching mechanism and having the can hang where it is now. Will see if that works. For now, current bracket does a decent job. I used EPDM membrane to sandwich between bracket and the weld joint to protect the paint and to create a connection that is less likely to slip over time.
Overall, exceptional guide here, with Farkle!'s video and his recommendations making the job fairly easy. I would suggest going ahead and taking intake pipe off that attaches to turbo, since it is easier to cut the ring off on a table instead of it still attached to the car. The mechanism to remove the PCV heater off the pipe is complex, I was only able to do it with intake pipe out and on my dining table. All that requires is removing one bolt that supports it and pulling the clip out that holds it to the turbo. Reinstall was also quite easy, as it just snapped in place. Overall, over first 500 miles, I only collected oil on the catch can walls, not enough to pool yet. Most sources say better catching efficiency in winter time due to easier condensation when cold. Wish there were a way to keep it cool in the summer to help condense the oil vapors as the entire can heats up nicely over time. By the way, would suggest getting catch can from Mishimoto directly, Amazon has older design with 2 screws attaching the bracket. This results in the side with pipe openings to droop. The new design has 3 screws which support better. Not sure how Mishimoto compact compares to regular size vs. Burger's version in terms of oil catching. This one fits well. The only complaint is that I wish the pipe inlet and outlet were parallel instead of being offset 45 degrees. But it still worked out fine. Last edited by eugene89us; 08-06-2020 at 03:38 PM.. |
FaRKle!4016.00 |
03-16-2022, 04:05 PM | #31 |
Rep 5
Hi All, Does anyone have the part number for the wiring harness that goes from the bottom of the CCV hose to the top? I am getting a 28D700 Engine Ventilation Heating Activation Open circuit code. Thanks in advance!
The part in question (2015 328D): |
