07-16-2019, 04:50 PM | #2619 | |
Rep 1,048
what file version did you get ?, i got also an OTA Update 2.0.5 and OEM folder with factory_config.xml but it changed pretty nothing. have you got additional files ? can you share a System info screen ? sincerely Chri |
07-16-2019, 10:48 PM | #2621 | |
Rep 102
This is extremely fast! My 7.1 unit takes 10 seconds just to realise that I started the engine Can you share the link where you bought the unit? |
07-16-2019, 11:47 PM | #2622 |
Rep 33
Hi all,
It's been a while since being here and managed to happily live with 7.1 ugode unit until now. Strange thing happened few days ago: The device had done some sort of factory reset on its own. I had driven maybe two hours and used the device with no issues whatsoever, then turned off car, took a break of 15 mins and back to the car. The device had forgotten all settings in the meanwhile. Everything else (like Andoird apps with their settings, I was logged in to google services with my account, device knew my wifi password etc etc) where untouched. Not sure if I am using the right words but perhaps Android application layer was ok but MCU (?) had somehow messed up. Anyway, to the main issue. After I reconfigured everything in Factory Settings, I found that some of the features were missing. Not sure which ones, but at least the most visible was limited list of main menus (or what you would call them). Previously I had a great list of multiple BMW choices, some Audi, some MB and even JLR. Now there is just BMW-NBT, Audi and BMW-EVO remaining. What on earth happened to ID6 etc which were factory installed to my device and "survived" over all upgrades done so far... And oh, the even the main home button that looks like a house in upper left corner of the device, doesn't react. Yet you can get back to the main menu with "back" feature using BMW scroll wheel (so it is there but the button on GUI itself does not work). I think the solution would be to reinstall the device with best known firmware for both Android and MCU. Any recommendations which one? Was the missing list of menu selections in factory.xml or somewhere else? Could someone point a link to such please? |
07-17-2019, 09:03 AM | #2623 | |
Rep 21
I forgett to say that my unit have also the snapdragon 8 Core cpu. And yes we are talking about the booting time from Power to directly Show the GUI. Around 10-15 sec. The OTA file is very large about 1.4 GB. Dont have any download link for this. But can maybe upload and share this for someone who is interesed in this. I also dont like some Menü pictures of the ID7 GUI. I work as Web Designer and have Pro Photoshop skills. Is there Info how i can get into the raw images without root for editing this? |
07-17-2019, 10:37 AM | #2624 | |
Rep 1,048
2.0.5 has ID6 again, i switched to this, at least better than ID7, i would prefere NBT anyways ^^" i also got the same 2.0.5 update. You don`t need to root your device, ADB over wireless is already activated on this devices, so you can connect to them via adb. You can also extract the Launcher from your OTA file, i just added an Android 9 Extractor batch to the URTOOL at Github. when extracted you will find the APK under "system_android9\system\app\KswPLauncher" where you easily can unpack the apk with most zip software. sincerely Chri |
07-17-2019, 03:51 PM | #2625 | |
Rep 21
With the Urtool i have sucessfully unpacked the launcher and found all raw images. During the process of unpacking the files the URTool shows some errors like Fonts or some files cant be found. Iam a little bit scared about that. Hope later after repacking all files togehter i will not get Into a bootlop. What do you think? And how i can repack the files back correctly? Repacking with URTool not working for me. I also found some pictures in the launcher of different dashboard styles like in these picture.Are you able to select that and acitvate on your unit? |
07-18-2019, 01:40 AM | #2626 | |
Rep 1,048
As the interesting part are the apk files i ignored this for unpacking the APK. i wouldn`t make a complete new OTA update just for changing one file, that would be a huge work every time. i just tried root access to the device, it`s easier than on Android 9, as the bootloader is already unlocked by default and secureboot is disabled. So probably only a 5 liner to get root access Then you can replace the one particular file then, thats way more easy i`ll make a guide soon, but have no time this week anymore to work on the device. haven`t seen that other screens yet, but i also have not played around alot since i have it. sincerely Chri |
07-18-2019, 08:43 AM | #2627 |
Rep 29
I just bought a 8.1 android screen to replace my 7.1 version.
I used the cables of the 7.1 since this probably just is a software update of the screen module? I have some issues on the 8.1 version: Android system does not recognize the (F31) type in factory settings to set to 10.25" screen with (only other newer types) Rear aftermarket camera does not work anymore > no signal (aftermarket screen option) Works fine on the old 7.1 android version. Standard car beepers do not work anymore when driving backwards Please help.. |
07-18-2019, 10:36 AM | #2628 |
Rep 33
I guess there never was F3x listed in the display types. I just selected one of 10" inch models which matched by radio type closest (NBT F something). At least for me it worked fine.
07-19-2019, 03:18 PM | #2629 | |
Rep 21
07-21-2019, 12:53 AM | #2630 | |
Rep 1,048
They have no HL-102CK for F-Series CIC Controller left, they said to me they produce new one when ordering at least 200 piecies But unless your unit has no full Bluetooth Capability its useless, so try if you can connect a bluetooth mouse or keyboard over the normal Android system before. i bought one from them, and have to say it`s not really a benefit, you then have just a singlepoint mouse, no real multitouch / zoom / letter writing feature. sincerely Chri Last edited by Kri; 09-18-2019 at 08:25 AM.. |
07-21-2019, 10:03 AM | #2631 |
Rep 220
Drives: MINI Cooper, 2020 X1
unfortunately, images cannot be displayed ...
07-22-2019, 02:48 AM | #2632 |
Rep 22
I don't want to take this off topic, however the sound quality on here has been mentioned a few times so just want to report back.
I have a BMW 2014 F10 that originally came with the base stereo sound with no amp. The sound quality was poor to say the least on the OEM side. Having purchased the ugode PX3 a year ago, the sound quality went from bad to worse. Those in a similar boat will know exactly what I'm talking about. I'm not a bass junkie. Just somone that wants to turn the volume up when 'that' track comes on. Anyway, a couple of weeks ago I decided to upgrade the sound system. I placed some Eton mids and tweeters in the door and Left the underseat subs for a future upgrade. Wired up an amp to power the underseat woofers and the door mids to manage the highs and the lows. I didn't go to town with the amp as I tried to keep myself on a budget. but now that the wiring is in place, I can always upgrade to a more powerful amp in the future. I Must say, the sound improvement really is night and day. There is a significant improvement in sound on the android side. On the OEM it's absolutely amazing! Happy to share the setup I have if anyone is interested. Also fantastic work @_fred_. Updated my mcu yesterday . Just need to do a little more reading on the eventcenter.Apk My biggest gripe right now is the left speaker sound issue when in navigation on Waze. |
07-22-2019, 09:14 AM | #2633 |
Rep 539
Anyone else find their 7.1 unit is really really slow for downloading things? I've tried downloading Sygic and TomTom maps on mine countless times and it's always insanely slow.
Sygic maps are about 650MB for the UK and TomTom around 1GB for the UK. I've had my unit connected to my home wifi on a 200Mbit connection where my laptop will happily give full speed through wifi and at my parents' place on a 75Mbit connection. No matter what connection I use I seem to get ridiculously slow speeds - like 20-30 minutes to download the 650MB Sygic maps, if not longer. I've also tried tethering it to my phone on 4G which speedtests at a fairly respectable 40-50Mbit, and it's still just as slow through that too. Even downloading the base Sygic app, which was only about a 40MB download if I remember rightly, took a good few minutes when it should only be a few seconds. I've had this issue since I got the unit back in December but that, coupled with the GPS issues on my unit, makes me wonder if it's worth getting the Android 9.0 version. |
07-22-2019, 10:37 AM | #2634 | |
Rep 118
7.1 is crap 8.1 is good (I know because i have both) Dont know about 9.0 |
07-22-2019, 11:24 AM | #2635 | |
Rep 118
It's pretty much instant on. Takes about five seconds to boot into Android fully interactive. I think what happended is I use my car very sparingly and probably my battery was a bit low. Now I have been using the car for a few consecutive days the boot up is around five seconds. |
07-23-2019, 12:57 AM | #2636 | |
Rep 1,048
The booting time we are talking about is always a cold boot from "Ignition (Power) on" until "GUI load" . sincerely Chri |
07-23-2019, 01:43 AM | #2637 | |
Rep 118
What Im saying is that the unit does not cold boot now, it's in some state of suspension, and after ignition it takes around 5 seconds to "GUI load". As I said its probably because when I recorded the video my battery was a bit low. My old 7.1 never did that, It always was a cold boot more than 25+ seconds. |
07-23-2019, 05:02 AM | #2639 |
Rep 1
Hi, I bought my unit Android 7.1 a week ago and the black screen had come up three times. I had to do factory reset 3 times but have a feeling it will have the same issue again. Anyone here had it and managed to fix it? Thank you very much in advance
This is my unit info statewide cars |
07-23-2019, 08:09 AM | #2640 | |
Rep 51
