08-05-2019, 11:57 PM | #133 | |
Rep 182
05-29-2020, 02:27 PM | #135 |
Rep 2
I have 320I xDrive 2013 new engine
Hello, I got my engine replaced December 2018 and now the oil replacement light came up on my IDrive, BMW suggested I buy 0w-30, just wondered what would you guys suggest? 0w-40? Castrol? thanks
05-29-2020, 02:37 PM | #137 |
Rep 2
Thank you for your reply, I am in the UK, what's the differences between 0w-30 and 0w-40? my engine is brand-new and someone said for new engine is best to stick to 0w-30 rather than 5w-30 is that true? thanks
05-29-2020, 03:22 PM | #139 |
Rep 5,392
Castrol European Formula in the black jug used to say BMW LongLife-01 until Castrol stopped paying BMW a licensing fee. Same oil though. I use 0W-40 because that's what my local Walmart sells at <$25. I get Mann filter kits ~$9 from Amazon
05-29-2020, 03:31 PM | #140 | |
Rep 495
In Texas it hardly ever gets to freezing temps, so there's no problem running 5w-10w really. A Liqui Moly rep says it's better to use thinner oils when the engine is new, and as it wears go to thicker. So 0w-20 -> 0w-30 (50,000mi) -> 0w-40 (100,00mi +) if coming from brand new and remaining stock would be natural progression for an engine that gives an allowance for 0w-20 to 5w-40. Last edited by AspektUSA; 05-29-2020 at 03:38 PM.. |
05-29-2020, 03:53 PM | #141 | |
Rep 7,598
The tolerances and engine specs are specifically matched to a given weight of oil. There is no break in on bearings, for example. The only reason you would increase in oil thickness/weight is because you have wear that should not have occurred in the first place (and are compensating with thicker oil to maintain lubricity and oil pressure), or you are doing something like tracking the car where you want a thicker oil to mitigate the thinning that occurs at higher temps. You should use the weight of oil that the OEM/engine calls for. Oil is one of the most important things for engine longevity so i would not cheap out on unapproved brands or formulas to try and save like $50 per year. |
05-29-2020, 05:19 PM | #142 |
Rep 16,076
True, within reason. A new engine has tighter tolerances, so a thinner oil can better coat the surfaces. As the engine gets older and the metal wears away thicker oil can better fill the gap between parts. But the over riding reason why BMW went from 5w-30 to 0w-20 was for better fuel economy. The engines hadn't changed. Many dealers will put 0w-20 into cars that were originally recommended 5w-30 so they only have to stock one oil type. LL doesn't mean anything, other than the manufacturer meets BMW requirements, and pays BMW for the right to call it LL. The number is the year it was first used, as in 2001 or 2014. I use LiquiMoly because it's a superior synthetic lubricant. I stayed with 5w-30 and my mileage with it went up by 2 MPG.
05-29-2020, 06:07 PM | #143 | ||
Rep 495
Tracking/racing/extreme conditions are always exceptions to the rule. 12:00 mark they give the advice for the oil weight over the lifetime of an engine. Quote:
The video above the Liqui Moly guy literally says oils weight doesn't matter much any more, as it's pretty much a just a conveyance for additives, detergents, stabilizers now. Your brand of oil doesn't matter much, just that it meets spec and you change it regularly. Considering Shell probably has 10x the R&D budget of Liqui Moly, I'm sure they're not just banging rocks together over there. |
05-29-2020, 09:15 PM | #144 |
Rep 16,076
The faster heat rise of 0w-20 is significant at below zero temperatures, otherwise not so much. With LiquiMoly you know that it's very different from run of the mill synthetics. It doesn't even feel like oil. I have a bit of experience with oil, having used Mobil 1 starting in 1974, and lived where 20 degrees is a balmy winter's day for longer than that.
05-29-2020, 10:07 PM | #145 |
Rep 10,351
FYI. BMW updated the LL01 specification. It is listed as LL01(2018).
https://online.lubrizol.com/relperftool/pc.html
"Drive more, worry less. "
05-30-2020, 09:43 AM | #146 | |
Rep 495
Liqui Moly is a fine brand, but keep in mind they're just buying in their base oil and adding their 11 herbs and spices. Companies like Shell are doing things like digging the oil out of the ground, refining the oil themselves, and running them in vehicles like Ferraris. Their GTL (pureplus) products are genuinely interesting, and are the biggest innovation in motor oil for the last 50 years - even if the GTL process itself isn't new. Your brand of oil doesn't matter, so long as you are consistent about intervals and it meets specification. |
alohasurftoad3076.50 sspade2464.50 |
05-30-2020, 09:53 AM | #147 |
Rep 16,076
Mobil 1 has been used and recommended by Porsche since 1996, so it can't be all that bad in a BMW. I use Molygen, because one the herbs it contains is UV dye. Knowing that an oil leak is a matter of when, not if, on a BMW, when mine happens I'll be ready to find the source.
alohasurftoad3076.50 |
05-30-2020, 08:48 PM | #148 | |
Rep 10,351
06-02-2020, 04:28 PM | #149 | |
Rep 387
I use 40 over 30 because I live in southern California where temperatures in excess of 100°F in the summer are the norm, as is sitting in bumper to bumper traffic for hours on end. If you make it a habit to flog your car pretty often, you are also better off with the 40. I also like the idea of the thicker oil for a little added protection of the turbo bearings. I do a fair amount of uphill driving where my work takes me several times/month, so it gives me a little more peace of mind when the turbo is really being put through its paces. |
sspade2464.50 |
06-10-2020, 08:59 PM | #150 | |
Rep 29
https://s3.amazonaws.com/oats.packsh...efault-usa.png |
06-13-2020, 06:14 AM | #151 | |
Rep 864
NOACK High
The PP Euro 5-40 has the lower NOACK similar to BMW Branded oils. |
08-31-2020, 03:43 PM | #152 | |
Rep 22
They took out Mobil 1 for no good explanation?
-ray Quote:
08-31-2020, 09:02 PM | #153 | ||
Rep 10,351
We can't be all that surprised when BMW a few years ago moved it's fleet to "FE" and 20w oils. LL01(2018) is not a FE spec.
09-01-2020, 02:11 PM | #154 |
Rep 80
Amsoil has 0W-20 per BMW LL-17FE+ as of today.
https://www.amsoil.com/p/sae-0w-20-l...-afe/?zo=36101 Last edited by JimKden; 09-01-2020 at 02:29 PM.. |
