06-20-2019, 12:51 PM | #89 |
dad bod
387
Rep 382
Flashed it yesterday. Made a huge difference, at least for me. I had already coded 2TB but my upshifts felt laggy, now they're near instantaneous (and a lot smoother).
'15 F30 Estoril Blue 335i xDrive | 8HP | Stock Turbo | 420 awhp / 451 awtq | 11.85 @ 115 mph
E30 JordanTuned on BM3 | XDI-60 HPFP | Fuel-It! lines + sensor | VRSF FBO | GFB DV+ | XHP | Vörsteiner VFF-107s | Dinan Springs |
06-20-2019, 11:17 PM | #90 |
Rep 474
What is TB?
J. D. Cordier
06-21-2019, 08:36 AM | #91 |
Rep 1,286
Unrelated to the flash,
Does anyone else notice that the Manual mode isn’t quite as smooth as Sport Auto or D? Not necessarily a bad thing. I’ve noticed this since I got the car. Auto shifts are smoother than the manual, especially in 1st, 2nd and 3rd gear. The manual shifts have some “feedback” when changing gears. I don’t really mind it but I’m wondering why that is? Anyone else think this or is it just me? |
06-21-2019, 09:05 AM | #92 | |
Rep 2,653
imperfectluck425.00 |
06-21-2019, 10:33 AM | #93 | |
Rep 1,286
06-21-2019, 10:46 AM | #94 |
Rep 36
I'm running Stage 2 93 octane and just did the 8 speed transmission flash yesterday. It's a really solid and noticeable improvement, shifts are much quicker and smoother.
06-21-2019, 10:46 AM | #95 |
dad bod
387
Rep 382
2TB option code for the sport auto coding of the trans. A lot more info in the threads already out there but most of them are dated -- if you decide to do it you can use bimmercode or carly, no need to use e-sys.
jcordier160.50 |
06-21-2019, 10:52 AM | #96 |
Rep 205
Drives: 14 F30 335i xDrive
Wow! I don't check in for a couple days and surprise! The flash is finally released!
I'll flash it today. Hopefully I can get to the track soon and let you all know how it works there. |
06-24-2019, 01:19 PM | #98 |
Rep 604
I flashed it last week and been driving in D mode in comfort mostly, what I do notice and not sure if it's weird and if someone else noticed it as well, but when you're slowing down from like let's say 60mph or more, when the car is downshifting, the rpm in I believe when the car hits the 3rd gear, revs up high to like almost 2.5k-3k. I also feel like even in comfort+D, the rpm holds 200-300 revs more than stock.
2021 G80 M3C - Current
2017 G30-B58 - Sold 2013 F30-N55 - Sold |
06-26-2019, 12:33 AM | #99 |
Rep 345
06-26-2019, 06:00 AM | #100 | |
Rep 288
06-26-2019, 01:10 PM | #101 |
Rep 1,105
You heard wrong...
Pull up the app and see all the updates, including the shift point editor!
06-26-2019, 02:13 PM | #102 |
Rep 288
I think you're confused. That's what I want, comfort and eco pro to be untouched but sport and sport + to be altered.
06-26-2019, 02:55 PM | #103 |
Rep 426
Did you turn off the 2TB first, or just flash over it? I did the sport trans flash through Bimmercode and just curious if I should undo that first, or just send it.
Glacier Silver Metallic 335i X-Drive - Can't leave well enough alone... Fabspeed DP, Wagner Evo Comp II IC, ER CP, BM3 Stage 2 93 OTS, Bimmertech Amp (more to come... always more) Graphite Metallic X3 (nothing yet, but... you know) |
06-26-2019, 02:56 PM | #104 |
Rep 172
Drives: 2015 328i
Is this out for any 8sp? I drive 50/50 comfort and sport/sport+ due to traffic. I just want to keep the smooth comfort shifts so don't really care if performance is improved in that mode.
06-26-2019, 04:10 PM | #105 |
Rep 101
On xHP they advertise 50% faster shifts in M mode; only on stage 3 map. I can attest that shifts are much faster in manual but only at higher RPMs.
2015 335i ///M-Sport 8AT | M Performance Exhaust/Brakes/Suspension | BMS CP | BM3 Stage 2 | VRSF FMIC | AR Design DP | AFE Filter | RES Delete | BavAuto Coils | P3 Gauge | xHP Stage 3 |
06-27-2019, 01:07 AM | #106 |
Rep 28
I have the sports automatic option (2TB) and after the flash I definitely feel a huge delay on the paddles when shifting. The upshifts are also quieter/shorter upshift “burp”. I have bootmod3 stage 2 93 so the torque limit removal is huge. I like how when braking the car downshifts a bit higher. Hopefully they update the paddle response soon. Paddle shifting takes x2-x3 longer than before.
06-27-2019, 03:54 AM | #107 |
Rep 373
i just flashed this in my f20 m135i yesterday driven about 50miles so far with it. Im not sure if i can feel a difference ( apparently not needed on m135/235?) Shifts feel smoother and up shifts feel slightly faster ( placebo effect maybe?), downshifts are definitely not faster.
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
07-02-2019, 02:55 AM | #109 |
Rep 373
Ok i flashed it back to stock to compare biggest difference to me is the torque limitation in 3rd the car breaks traction now and puts more power to the road in 3rd when it does gain traction with the flash when it didn't before (odd as m135/235 shouldn't need this flash) the gearbox all round seems smoother in comfort
single downshifts seem to be the same speed maybe marginally faster single up shifts are noticeably faster i thought this flash was just a torque limitation removal in 3rd and 6th (according to their FB post) i definitely think they have done a lot more then that. would be nice if they released an official statement around what exactly this flash contains.
