BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Intercooler and CP Recommendations
Carbahn Autoworks
      06-28-2018, 11:58 AM   #45
enjoythemusic
enjoythemusic's Avatar
343
Drives: 2014 BMW 435i Dinan Stage 4
Originally Posted by glennQNYC View Post
I put black anodized fmic and charge pipes (both sides) from ER on my F30 335. I already had a Dinan cae, full Akra exhaust and M Performance Power Kit at that time. To tell the truth I think the ER fmic was too large for this setup. I actually lost low end power.
Because of this (and my addiction to modifying cars) I brought it over to Enzo to layer a custom tune onto the Power Kit and add a catless downpipe. This made all the difference. Power at all rpm is now markedly better than it ever was. My only regret is now I'm spoiled. The car runs like a champ!
The moral of the story is be careful you don't put too large of an intake tract on your little oem charging system, or you may need to improve that too.
Don't doubt what you say, yet am curious.... maybe the DP helped to 'balance' the increase of incoming air? Reason for asking is; just received a Fabspeed HJS catted DP and will install next week.
Enjoy the Drive,
Steven
2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S.
      06-28-2018, 12:09 PM   #46
XxThe_RemedyXx
Greece
394
Drives: 2014 335i XDrive
Originally Posted by sspade View Post
Holy cow. No way it takes a dealer 4+ hours to install a CP and FMIC.
I bet a good tech can install both in 1 hour. Super simple.
If either of you have a garage, you should give install a shot and save the money.
Dude I wish I had a lift, I'm sure I could do it myself.
      06-28-2018, 01:05 PM   #47
glennQNYC
Benelli M4 Speed Loader
glennQNYC's Avatar
Drives: M Sport 335i
2014 335i  [4.87]
I wasn't getting proper boost pressure until Enzo cracked open my ECU and uploaded his custom tune. Initially I thought I had a leak. After proving to myself I had a sealed intake tract it became obvious the sheer size of the ER fmic was the issue. Enzo confirmed this after he did the tune. The ER fmic and charge pipes is a lot of volume to pressurize with the stock turbo and just MPPK.
      06-28-2018, 01:08 PM   #48
MacklinUSOB
Drives: f30 328i 6MT Sport
I did my FMIC with a couple jack stands and it was a breeze, done in an hour. The charge pipe clips aren't even a hassle if you use zip ties and something to keep them stuck open, otherwise there is just two screws and some wiggling to do.
Add 5 horsepower for every M logo
328i sDrive | Sportline | Coral Red on MW | 6MT | JB+ | MPE | GPlus FMIC | KW V2 | F80 LCA | APEX SM-10 | Michelin PS4S | EBC RedStuff | RBF600 |
Past: E36 328is & E38 740i
      06-28-2018, 01:27 PM   #49
enjoythemusic
343
...The ER fmic and charge pipes is a lot of volume to pressurize with the stock turbo and just MPPK.
Ahhhh, many thanks and makes sense. The stock turbo simply can't properly provide ongoing pressure it seems with that setup. Afterall, this is a 'system' of bits.
Enjoy the Drive,
Steven
      06-28-2018, 01:31 PM   #50
glennQNYC
glennQNYC's Avatar
2014 335i  [4.87]
Just to further clarify... The issue was the MPPK tune wasn't aggressive enough in ramping up pressure. The result was low boost pressure at low rpm. I ultimately had good pressure at high rpm, but I lost low-end torque until Enzo tuned the ECU to ramp up pressure more aggressively.
      06-28-2018, 01:57 PM   #51
sspade
sspade's Avatar
Drives: F30 328i
2014 BMW 328i  [5.00]
Same. Took me a bit longer (admittedly) but I also installed a TIC and DV+ at the same time. DV+ was a bitch due to tight access but other than that, very easy and quick install.
BMW 328i visit my garage for build details.
      06-28-2018, 03:13 PM   #52
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
I recommend Active Autowerke, Wagner EVO I or VRSF 5" for your mods OP.
For the charge pipe, VRSF or Active Autowerke
      06-28-2018, 04:57 PM   #53
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
VRSF's new HD Street FMIC is hard to beat. Mate it with a VRSF CP for easier install and great value.
|Like us on Facebook||Evolution Racewerks| |Active Autowerke| |ETS| |Burger Tuning| |PURE Turbos| |Mishimoto||VRSF| |AWE| |Wagner|
|Holiday Sales All December!| |KW| |Spec| |ST Coilovers| |Koni| |Bilstein| |Borla| |Magnaflow| |AFE| |Fabspeed| |Injen| Up to 10% Off!
      06-28-2018, 05:24 PM   #54
dr.roro
Drives: 2015 F32 435i
Did they fix the recent issue with the bracket being off due to a faulty jig?
      06-28-2018, 06:36 PM   #55
FastF30
FastF30's Avatar
201
I'd do it in a heart beat but here in the city there is no where to work on it... can't work on your car in the parking garage I'm in... plus being on warranty still just want them to do it... but haven't received the estimate yet... so we'll see... They gave me an X1 28i to tool around in... now I can go to costco this weekend and not worry about the parking lot .... lol..
      06-28-2018, 08:45 PM   #56
XxThe_RemedyXx
Greece
394
LOL!!! I'm in Westchester. You ever need some space to work on your car feel free to come up, just bring some of those hard seltzers (I'm on a diet).
'14 335 xDrive EWG FBO - VRSF Chargepipe - VRSF Downpipe - AA Intercooler - MPE - BM3 Stage 2 93 AGG - R1 Concepts Front/Rear Geomet Cross Drilled and Slotted Rotors
FastF30201.00
      06-29-2018, 05:25 AM   #57
XxThe_RemedyXx
Greece
394
Thanks Mike, I'll look into these.
      06-29-2018, 01:53 PM   #58
mike@x-ph.com
      06-29-2018, 03:40 PM   #59
enjoythemusic
343
Hope so, will know more once installed (hopefully this week). Ordered it about a month ago and just got it.
Enjoy the Drive,
Steven
      07-03-2018, 11:54 AM   #60
FastF30
FastF30's Avatar
201
I'm just doing it with the dealer because it's still on warranty... should be around 4hrs or $500 I'm hoping...
Bayside BMW Dealership just called... $540...
      07-03-2018, 12:07 PM   #61
sspade
sspade's Avatar
Drives: F30 328i
Dude. You're going to pay $540 for a CP and FMIC install?!
Im not trying to be cool when I say they were VERY easy and straightforward to do... on my back in the garage. Even easier with a proper lift.
Simple hand tools and a pair of ramps from Walmart is all you need. I promise you could you it on your own without a doubt.
      07-03-2018, 12:54 PM   #62
FastF30
FastF30's Avatar
201
Yes it is pretty straight forward... if you have a garage... tools... time... $500 is reasonable to me and my wallet for a dealer quote... plus car is under warranty and this just makes it easier if something happens when installed at the dealership...
      07-03-2018, 01:55 PM   #63
glennQNYC
glennQNYC's Avatar
2014 335i  [4.87]
It may be easy and straightforward, but you can't accurately put a value on his time and effort. I've had many occasions where I said "I can't afford my own time" and paid someone to do something for me when I could do it myself.
      07-03-2018, 01:57 PM   #64
sspade
sspade's Avatar
Drives: F30 328i
Fair enough...
For two hours time, we can assume he makes $250+ per hour. That seems realistic.
      07-03-2018, 02:01 PM   #65
glennQNYC
glennQNYC's Avatar
2014 335i  [4.87]
Fair enough...
It might not be a direct monetary correlation. He might rather spend time with one of his kids, or bang 3 hookers for all I know. Some things are priceless.
sspade750.50
FastF30201.00
      07-03-2018, 02:05 PM   #66
sspade
sspade's Avatar
Drives: F30 328i
Fair enough...
Haha, very true
At the end of the day - you're right. I just hate seeing people blow money at the stealership. Certain things, you absolutely need their expertise for but others can be done with a bit of effort.
I may be the odd person that actually enjoys working on their car once in a while.
