BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > M performance side skirt vinyl
proTUNING Freaks
      07-15-2018, 05:26 PM   #1
Dan930
Dan930's Avatar
Drives: 3series
Any tips on how to apply the whole side skirt vinyl
I’ve looked on you tube& it looks quite hard to do
      07-15-2018, 06:46 PM   #2
rcaso26
rcaso26's Avatar
Drives: 2015 328i xdrive
I tried to do it and it was brutal I stopped halfway through. Interested as well.
      07-15-2018, 09:06 PM   #3
perryo91
perryo91's Avatar
Uganda
373
Drives: 335
Easy, tilt the car over so you’re at a better angle.
Oompah90.00
      07-16-2018, 12:48 AM   #4
Kendo67
Kendo67's Avatar
Scotland
1099
Drives: Me - 440i , Dog - Cayenne
Leave it to the bodyshop , i got mine fitted before i picked the car up from the BM dealers.
They were £140 supplied + fitted , it doesn`t seem to be something that can be done for the first time , properly, lying on the driveway.
It was the only job i didn`t fancy doing myself.
Kenny
      07-16-2018, 01:05 AM   #5
muffking
Regular user
muffking's Avatar
Drives: F30 330D M-Sport Auto
I did mine a few weeks ago. £16 from ebay.
My steps were to:-
Clean the sills thoroughly.
Start from the rear (the thin end of the decal).
Use a hairdryer to warm the sill and also the decal.
Use a felt edged squeegee to apply the decal, peeling back the protective layer as you go.
I did mine on my own, but it would help if you had someone to hold the other end of the decal along side the front of the sill to help keep the top edge straight.
https://f30.bimmerpost.com/forums/sh...postcount=2010
      07-16-2018, 01:51 AM   #6
Oompah
Drives: M5
+1
      07-16-2018, 01:59 AM   #7
geordiepaul
F31 330d M Performanced up.
geordiepaul's Avatar
Drives: F31 330d
Can they not be applied by wetting them? That's how most vinyls are applied. Give a long working time and room for realignment. Normally baby shampoo/water combo works well.
      07-16-2018, 02:14 AM   #8
Nobby Clark
Nobby Clark's Avatar
759
Drives: F36 430d xDrive M Sport
The sill comes off quite easily - 10 or 11 torq screws and unclip from teh rear to front. Take it off and work on a bench.
      07-16-2018, 03:37 AM   #9
Dan930
Dan930's Avatar
Drives: 3series
I’ve also seen videos on you tube where they spray some liquid on to apply
      07-16-2018, 03:51 AM   #10
NotGotABimmer23
Drives: 340i touring - incoming
You wet the vinyl and skirt so they can be easily aligned. Seems like a 2 person job to me.
      07-16-2018, 05:05 AM   #11
Nobby Clark
759
Lightly soaped water usually works. You can slide the vinyl around and squeegee out the moisture.
      07-16-2018, 07:04 AM   #12
lear45xr
Drives: 420i msport
BMW instructions
https://www.bimmerfest.com/forums/at...8;d=1429251745
      07-16-2018, 10:30 AM   #13
aquazi
Drives: 18 M4C
I tried fitting an eBay jobby after i got my car.... having tinted windows in the past thought how hard can it be!!
Its a nightmare! Especially on your own.... and i ended up with creases on the wider lower section even after heating during a wet application.
Genuine ones are thicker so probably easier... but personally i would leave it to a bodyshop to do and if they mess them up its their cost!!
      07-16-2018, 10:43 AM   #14
t5pilot
t5pilot's Avatar
Drives: M4 CP & S1000 XR
This.
I've done a couple of sets.
1. Make sure the sills are COMPLETELY clean. And I mean clay-bar clean or else you will get tiny bobbles on the finished installation. The surface really does have to be silky smooth.
2. The good news is that's the difficult part.
3. Mix a soapy water solution. I just use car shampoo - in a spray bottle.
4. Drench the sill with this solution & begin to apply the decal from the back (it's easier to line up there). Peel the backing paper off as you move along, using more spray if it's starting to dry. (Once applied, the vinyl is pretty manoeuvrable until you squeegee the liquid out).
5. When you're happy, start at one end (and from the middle of the decal going up & down) and squeegee the liquid out. A credit card or smaller is ideal.
6. Stand back & admire. It's pretty easy even if it doesn't sound like it. Find an off-cut & have a practice, even when squeegeed it's easy to peel off straight away before it's properly stuck.
BUT PREP IS THE KEY - CAN'T STRESS THIS ENOUGH.
/// BM3 + M-Power ///
      07-16-2018, 01:56 PM   #15
Dan930
Dan930's Avatar
Drives: 3series
Originally Posted by t5pilot View Post
This.
Cheers mate
      07-16-2018, 03:27 PM   #16
ukbeemerboy
Beemer Heaven
ukbeemerboy's Avatar
Drives: BMW M4 Competition
Exactly this, I took them off to fit the skirt extensions very easily. I didn’t bother with the vinyls as I don’t like them.
Scott
2018 BMW M4 Competition
2019 Mini Countryman Cooper S : 2008 Mini Cooper
      07-17-2018, 09:40 AM   #17
MarkAndrew
Drives: F31 335d Xdrive Msport Touring
A word of warning, Ive had mine done by my local dealer and one side bubbled slightly and the vinyl flaked. The dealers replaced it no problem, but it is not a job Id do myself as the slightest contamination on the paint surface can bugger the application, it also takes a day to cure properly.
      07-17-2018, 10:25 AM   #18
NotGotABimmer23
Yeah worth getting these done by the dealer purely due to the number that fail. They will replace under warranty without issue, different story if you get it done elsewhere.
