BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > F15 10.2" Monitor installed to F30 car
      02-20-2020, 06:06 PM   #375
yjypm
yjypm's Avatar
Drives: 2018 M3 ZCP
Originally Posted by nitsuj17 View Post
Originally Posted by yjypm View Post
2016 lci comes with NBT evo headunit. This screen doesn't work.
I have the 8.8 screen 9387453 running now that I upgraded from the 6.5 inch screen. Isn't that apix1 the same as last h 10.25 inch one I linked?
I have nbt Evo id4 but in thought that was still apix1
I believe 9387453 is apix2 using 12V.
The 8.8 nbt screen is 9292248 (ie 2015 f30)
If you think your screen is different to 2018+ f30 it's because starting from 2018 they added touchscreen function to the screen.
Instagram:catpupu_f80
      02-21-2020, 07:46 AM   #376
nitsuj17
Drives: F30 328ix
ok thanks for clarification. Do you know if 65506816387 would work then? https://www.realoem.com/bmw/enUS/partxref?q=65506816387 it does say it exchanges retrospectively with 65509347878 which would make me think it wouldn't since it would be the same voltage
How does both 9387453 and 9292248 work in in the lci then as indicated here without a voltage adapter? https://f30.bimmerpost.com/forums/sh...6&postcount=39
      03-07-2020, 07:07 AM   #377
M2RTY
Member
Drives: e46, e93 + f23 M sport verts!
I have NBT id4 evo on a 2016 f33 and still trying to work out which screen I bloomin need lol. I’m away at the moment but will end up taking mine out next week to check part number
      03-07-2020, 08:49 AM   #378
nitsuj17
Drives: F30 328ix
Well I ordered screen 7878 for my Evo id4 and it's here (was $170 on eBay sonitbwas worth a shot) will let you know how that goes when I plug it in
      03-07-2020, 04:01 PM   #379
nitsuj17
Drives: F30 328ix
can confirm that 9347878 works on my lci f30 with nbt Evo id4
      03-07-2020, 04:03 PM   #380
yjypm
yjypm's Avatar
Drives: 2018 M3 ZCP
I have NBT id4 evo on a 2016 f33 and still trying to work out which screen I bloomin need lol. I'm away at the moment but will end up taking mine out next week to check part number
Interesting. Maybe this has something to do with id4. Anyways clearly I was wrong. Sorry!
      03-07-2020, 04:10 PM   #381
nitsuj17
Drives: F30 328ix
No worries, I think id4 was still same as nbt since the carplay boxes worked with it so I took the chance and figured if I was wrong I could get a voltage converter or flip it on eBay again.
I thought 170 was too good of a deal for a like new CID...it's cheaper than I paid for the lci 8.8
Now just need a free day to mod it to fit......
yjypm219.00
      03-15-2020, 01:13 PM   #382
nitsuj17
Drives: F30 328ix
Another one
Poochie9104.50
      03-15-2020, 01:17 PM   #383
El Conquistador
Drives: M240 Vert - 6M as god intended
Can someone provide the measurements of the 10" screen. Wondering if it can be squeezed into an F23
      03-15-2020, 05:22 PM   #384
nitsuj17
Drives: F30 328ix
if the f23 has the same dash opening as the f30 it will fit with modification. What does it look like?
      03-15-2020, 07:03 PM   #385
El Conquistador
      03-18-2020, 11:30 AM   #386
nitsuj17
Drives: F30 328ix
thats just a picture of the car. not your dash
based on what i could tell it looks like it would fit the same way (with modifying the CID) as the f3xx cars. Someone posted they bought it for a f22 and they could probably confirm for sure but i dont think they bought the right one so they couldn't get it to work. just check the thread a few pages back
edit: if your dash looks this (same it while glancing at a m2 competition) https://13c50d323025159807cb-35889f3...b3842f6a17.jpg
then i don't see it fitting, you wouldn't be able to cut enough of the CID. you would need a custom riser or something like this: https://f30.bimmerpost.com/forums/sh...&postcount=130
Poochie9104.50
      03-18-2020, 02:51 PM   #387
xDHC
Netherlands
94
Drives: F20 116i
So what is the difference with 8.8 and 10.2 except the inches?
      03-18-2020, 03:39 PM   #388
nitsuj17
Drives: F30 328ix
It's just a bigger screen, there are no other feature differences. Its great for nav, more usable split screen, airplay videos, etc.
It is a much bigger jump in size then 8.8 vs 10.2 would seem
xDHC93.50
      03-18-2020, 08:56 PM   #389
El Conquistador
That's what she said
yjypm219.00
Poochie9104.50
      04-10-2020, 09:12 AM   #390
Herofmine
Herofmine's Avatar
Drives: E92M3, F10535i, 15 M5,340i,X5M
2015 X5M  [10.00]
Planning to sell the car I hope bigger screen will add value))
      04-10-2020, 04:25 PM   #391
yjypm
yjypm's Avatar
Drives: 2018 M3 ZCP
You better take it off and sell it on the forum
      04-12-2020, 12:43 AM   #392
freespirit
freespirit's Avatar
83
Drives: f30 2016 BMW 328i
Does it have touchscreen and can you please provide the link from where you bought it.
Thanks you
      04-12-2020, 07:41 AM   #393
nitsuj17
Drives: F30 328ix
Thanks you
no touchscreen is only the id6 screens and are really expensive and incompatible with nbt
I got mine on ebay. Paid 170 for a like new
      04-12-2020, 02:05 PM   #394
psyki
E36fiend
Drives: 2014 435i xDrive
2014 435i xDrive  [0.00]
2014 X5  [0.00]
Mods rarely increase the sale value, at least not as much as you paid for it. If you want to recoup your investment when you sell the car your best bet is to put the stock idrive back and sell your retrofit parts here.
      04-12-2020, 03:59 PM   #395
nitsuj17
Drives: F30 328ix
this ^
And depending on what you do you might give the new owner more headaches. If you coded the larger screen from say the stock 6.5 and they take it to BMW for service and for some reason update idrive they will have a blank screen and probably don't know how to fix it
      04-12-2020, 05:04 PM   #396
freespirit
freespirit's Avatar
83
Is that a 10.25inch screen or 8.8 ? If its 10.25 and you want to sell it I am ready to buy.
I have 8.8 screen as of now with id4 pro nav.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop
