04-12-2020, 05:16 PM | #397 | |
Rep 256
Quick shipping, perfect condition. They are unmodified though so you will need to bust out a rotary tool to shape/fit it. Was about a 3 hour job for me |
04-12-2020, 09:52 PM | #398 | ||
Rep 816
https://www.ebay.com/itm/274132112485 |
04-12-2020, 09:55 PM | #399 |
Rep 816
My screen is already precut to fit on f30 dashboard, I will let you know, it's hard to find these screens.
04-12-2020, 10:11 PM | #400 | |
Rep 379
so yours is touchscreen? i have 2016 328i nbt evo with id4. I see members saying touchscreen need id5 or higher. do you know whether the screen works with id4 without touch functionality for now and when i upgrade to id5 in future i don't have to buy a new screen again. Thanks.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
04-12-2020, 10:13 PM | #401 | ||
Rep 816
04-12-2020, 10:23 PM | #402 | |||
Rep 379
can we code my current id4 head unit to id5 ? i was under the impression that id5 needs a different head unit. or are you referring to coding the touch functionality in future when i upgrade to id5 ? yes i would be interested if you can precut the non touchscreen one
04-12-2020, 10:47 PM | #403 | ||||
Rep 816
04-13-2020, 12:53 PM | #404 | |
Rep 256
unless someone absolultely needs touchscreen its just a better to go non touchscreen |
04-14-2020, 04:04 AM | #405 |
Berloss
Rep 15
Hi,
I woud like upgrade my NTB EVO with 8,8” from 11/2016 To the 10,25” screen. Therefore I got an offer from a damaged f85 (Prod. Date 2015-12-02) The 10,25 screen from this car is labeled with a part number I cannot find in any ETK. Also in the web is nothing to find about this part number. Is somebody knew if this a regular nbt srcreen which is working with 8,4v power supply or is this an Evo screen (Touchscreen with 12v). BMW part number: 935790701 The conection in the screen is in the middle not on the left sight as for part 878. on web pictures i see only the Touchscreen display with the middle conector. Thanks for help Best regards |
04-14-2020, 11:04 AM | #406 | ||
Rep 816
04-14-2020, 01:07 PM | #407 | |
Rep 816
04-14-2020, 02:30 PM | #408 |
Berloss
Rep 15
I know that the regular Display working with lower voltage. I will use a voltage regulator for power supply. But first of all I need to know if this display is a Evo Touch Display or regular nbt display.
04-14-2020, 05:32 PM | #409 |
Rep 464
Nbt touch and nbt displays look different it will be very helpful if you have a pic
Instagram:catpupu_f80 |
04-14-2020, 08:56 PM | #410 | |
Rep 256
So assuming the donor vehicle has been running what it was built with you have 7878. And yes you will need to use a voltage regulator to get it working. Some have reported it works with a regulator others have had issues |
04-15-2020, 03:18 PM | #411 |
Berloss
Rep 15
Unfortunately I cannot upload pictures By mobile phone.
But my display with part number 9357907 01 look like the same in the video. Also my display does have the 3 cubes behind the Glas on the left and right corner. |
04-15-2020, 04:41 PM | #412 |
Rep 464
The 3 cubes on each side of the screen indicate that it's a touch screen.
04-15-2020, 08:36 PM | #413 |
Rep 256
That's weird since the f85 you said is the donor did not have touchscreen. Must have been upgraded
04-16-2020, 02:00 AM | #414 | |
Berloss
Rep 15
Will the display damaged if it’s supply at 12v and it’s a apix1 display with 8,4v power supply? In my understanding it’s a touch display with apix2 It will work plug and play (touch need to code) with my nbt Evo? |
04-16-2020, 04:39 AM | #415 |
Berloss
Rep 15
Attached a few pics of the display.
I tried to connect with my NBT Evo but the display show nothing, also not "no Signal" so I think its a no touch display APIX1 with 8,4V. hope it is not broken after my connecting try. |
04-16-2020, 07:42 AM | #416 | |
Rep 256
Evo id4 is typically apix1 depending on the vehicle. Id5 in the f30 starts apix2 generally (Although some late production id4 see.to be apix2) |
04-16-2020, 12:36 PM | #417 | |
Berloss
Rep 15
Tried today to supply the display with 12v and 8,4v without Hsd video connector. But on I haven’t seen the”no signal”. Does it show only with video cable connected? Or is the display damage if it’s a 8,4v display and after I connected to 12v? |
04-16-2020, 12:44 PM | #418 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
Did you code the resolution changes? Regardless of touch capability a 10.25" screen is not "plug and play", you need to code the color depth and resolution.
CID_APIX_MODE = APIX2 CID_COM_MODE = MMI CID_COLOR_DEPTH = 24bit CID_RESOLUTION = 1440_540 (might also be CID_DISPLAY_RES) CID_DISPLAY_SIZE = 10_25 DISPLAY_VARIANTE = breites_display DISPLAY_SIZE_RESOLUTION = 10.25_1440x540 DIMMUNGSVARIANTE alte_dimmung |
