BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Oil level issue
proTUNING Freaks
      10-17-2016, 09:48 AM   #1
kevC
Drives: 2020 BMW M340i
Oil level issue
So I just got a pre-owned 2014 335i a month ago and put about 800 miles on it. It gave me a "Engine oil at minimum" warning. I ran the engine oil level check several times to make sure it was giving me consistent readings and it was consistently giving me the same warning. So I put a quart of Castrol Edge in it and checked the oil level again and it was right between the maximum and minimum level. I checked a few times after that and it was staying consistent at mid level. I checked again yesterday morning again, and now it's saying the engine oil level is at a maximum. WTF? I have no idea where the engine oil level is at and there is no dipstick.
      10-17-2016, 09:57 AM   #2
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Take it to a dealership or independent shop and have them check the sensor.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
      10-17-2016, 11:13 AM   #3
tuco44
tuco44's Avatar
Drives: 2018 340i xDrive M Perf Edtn
Usually takes a day or two for the reading to be accurate.
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971.
      10-17-2016, 01:27 PM   #4
kevC
Didn't know this. Yeah the mid-level readings were right after I put the new quart in and hours after. The max level reading came the morning after, probably around 12 hours later.
So I guess the dealership just didn't fill up the engine oil when they sold it to me and I burned through enough to get to a minimum level in the 800 miles or so I drove (I did drive pretty hard). I have not noticed any leaks whatsoever.
I'll make them check for a leak and the sensor my next service unless it goes low again.
      10-17-2016, 03:12 PM   #5
vitriol
vitriol's Avatar
Drives: 2016 340i M Sport
The N55 burns oil, especially if you drive it hard. Dealer confirmed this is a known trait of the engine.
I'd say I went through a quart every 7,500 miles or so with both my E90 and F30 335s.
5k into my 340/B58 so we'll see.
      10-17-2016, 03:15 PM   #6
nirvanabob
nirvanabob's Avatar
Drives: Bmw F30 335i xDrive 2013
Put more oil until the system shows the max line! But make sure the temperature is right, no more than 90 degrees Celsius!
Sometimes when the oil gets old the car starts to burn it, so I recommend to change the engine oil with the new one! ?
      10-28-2016, 08:00 PM   #7
Axman85
Drives: 335i x-Drive M-Sport Min. Grey
My '13 335i burns oil. I get anywhere from 2000-4500 miles between oil level warnings. Mostly in the summer, maybe I drive it harder then. Dealer is useless. They have replaced my sensor and now I no longer get it's at a minimum warning unless I check the oil. It's a pain in the ass but I love my 335.
      11-02-2016, 10:32 AM   #8
cfm56d7b
My MY13 335i sedan did not burn oil at all. The N55 engine was replaced due to excessive connecting rod bearing wear after I insisted to investigate a faint 'clicking clack' sound at idle. The dealer performed oil analysis and detected excessive metal particles later traced to the problem mentioned above.
There is nothing normal about excessive oil consumption. In addition, one of the results of a malfunctioning crankcase ventilation system can be increased engine oil consumption.
I suggest to insist on performing oil analysis and calling BMWNA.
      11-30-2016, 01:07 PM   #9
Axman85
This is what BMW considers normal oil consumption. In 4 years I have added 14 quarts of oil. On only four occasions did I get more then 4K per quart. They refuse to budge on this.
