06-05-2018, 01:48 PM | #1 |
Rep 15,966
Why you need a Foxwell NT 510
The NT 510 is a diagnostic tool that plugs into your OBDII port. The Schwaben BMW/Mini Scan Tool is a repackaged version. Right now both are available for around $150.
Yesterday I started my F34 and got a dash warning for an ABS failure. A minute later a chassis stabilization warning came up, then the cruise control wouldn't work, finally my spoiler was declared non-functional. I feared the next thing would be limp mode. Even though I'm a mechanic all of this would have normally pointed to a dealer visit ASAP. Easier said than done, he's 90 minutes away. A bit of searching on line pointed to the likelihood of a speed sensor on a wheel being the cause, since the ABS and all the rest need to have speed information from all the wheels to function. I even found a few videos on how to diagnose the problem with the Foxwell. Today I hooked it up, did a scan, and all of the faults came up, the first traced to the left rear speed sensor. It said the problem was intermittent. I cleared the codes and all the dash warnings went away. I did an operational test of the speed sensors and they were all working. I took a drive, no new warnings. If the problem comes back I'll order a new speed sensor, changing them is easy. If I couldn't have diagnosed and cleared the warnings myself it would have been a full day to take it to the dealer to have them do the same thing I did. Even if it was a no-charge warranty item time is money, so that saved trip saved me twice what the Foxwell cost. If you can't change a light bulb and/or your dealer is within walking distance then you can live without one of these, but I'm a real believer now, because all of the on-board diagnostic tools in the iDrive said the same thing: get to the dealer. |
06-05-2018, 04:25 PM | #2 |
¯\_(ツ)_/¯
537
Rep 1,000
Does the foxwell actually say which speed sensor it is on there or is it like any other scan tool that just gives a code/tells you what the problem is but not where. Example miss fire but doesnt say which cylinder
06-05-2018, 04:49 PM | #3 |
Rep 15,966
It tells you which sensor triggered the fault, and it allows you to test them by driving the car, showing the speed at each wheel. If one of the sensors is out it won't register any speed. It only takes 1 MPH to show up, so I was able to confirm operation in my driveway driving maybe 20 feet. The fault on mine was registered as an intermittent. What happens with the iDrive is that once a fault is triggered the warnings, and their consequences, remain until they're cleared, even if the problem went away. With the NT 510 you can clear them yourself, making sure that there really is something broken before you make a trip to the shop to fix it. Less expensive scanners are as you describe, they don't necessarily pinpoint the fault source or let you clear the fault.
06-05-2018, 06:44 PM | #4 |
Rep 1,487
Drives: 2108 X3 xDrive30i
Where did you get it?
06-05-2018, 09:28 PM | #5 |
Rep 15,966
I got mine direct from Foxwell. Supposedly it was to come from their US warehouse, but it shipped from Hong Kong. I still got it in 5 days. It doesn't come with the software loaded, you have to download that. Typical of Chinese products the documentation and instructions are horrible, but thanks to youtube you can find videos of everything you need to know, from installing the software to every operation it's capable of.
06-06-2018, 07:05 AM | #6 |
Rep 6,979
I get the same diagnostic code interpretation and clearing capability from the Carly for BMW app (installed on my Android device) and their bluetooth OBDII adapter - plus coding and several other capabilities. Total cost under $100 for the "pro" software version and the adapter. As with your experience, it has saved me trips to the dealer and also detected a defective auxiliary cooling fan that caused limp mode (replaced under warranty). More info on this and other similar products can be found in the "DIY and Coding" section of this forum.
08-16-2018, 10:37 AM | #7 |
Rep 15,966
Update: Ten weeks later no repetition of the ABS sensor fault. Glad I didn't have to waste a day at the dealer for what was probably just a system glitch.
08-16-2018, 11:05 AM | #8 |
AutoPilot
97
Rep 87
Drives: 19 X1,18 M550i,15 X5,14 328d
Garage List 2011 Mercedes GL550 [0.00]
2019 BMW X128i [0.00] 2015 X5 XDrive35i [0.00] 2018 M550i [0.00] 2014 328d [0.00] |
I just received my unit on Monday. Amazon, 2-day Prime shipping... Works great.
08-16-2018, 11:40 AM | #9 | |
Rep 2,499
08-16-2018, 11:42 AM | #10 |
Rep 15,966
Knowing from experience that a false-positive code can really mess up your day I now keep mine in the car, just in case I get a repetition a few hundred miles from home.
08-16-2018, 12:46 PM | #11 |
Rep 10,232
Another vote for Foxwell NT 510 code reader. I bought the same code reader / Schwaben from Turner Motorsports. Highly recommended.
08-16-2018, 12:56 PM | #12 |
Rep 6,979
Not that I'm aware of. To do engine-related coding, I've used INPA (E-chassis) and ISTA (F-chassis) with a Windows laptop and an OBDII cable.
08-16-2018, 02:13 PM | #13 | |
Rep 714
I have both Carly and the Foxwell NT510. For diagnostic, I always use the Foxwell. |
08-16-2018, 02:49 PM | #14 |
Rep 10,473
08-16-2018, 07:20 PM | #16 |
Rep 2,389
Yes I did that on my Z4 N54. My experience with the F30 is that Foxwell is lagging on functionality with the later models. Attached is the NT-510 function list.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
08-18-2018, 10:03 AM | #17 |
Rep 2,180
Foxwell was having a flash sale last night, but I ended up with the NT520 Pro for BMW from an eBay seller with 100% feedback. Will be interested to learn more about what it can do for me!
08-18-2018, 10:49 AM | #18 |
Rep 3,752
I just have one question as you are a mechanic....can this tool be use on different car....ie Mitsubishi, honda, ford, toyota and audi . I have all those cars😂
08-18-2018, 10:53 AM | #19 |
Freude am Fahren.
801
Rep 1,286
Drives: F15 X5 xDrive35i
Nothing beats $10 enet cable ¯\_(ツ)_/¯
Freude am Fahren.
08-18-2018, 11:15 AM | #20 |
Rep 15,966
08-18-2018, 11:29 AM | #21 | |
Rep 3,752
11-18-2018, 08:43 AM | #22 |
Rep 15,966
Update: before going in for my state inspection I ran a scan to see if there was anything there. It was totally clean. Whatever caused all those codes to get thrown five months ago hasn't reoccurred.
vooonoo537.00 Bricktop100021.00 |
