12-04-2021, 09:16 AM | #1 |
Rep 255
Drives: F36 430d GC, XKR, Clio 172
Share your Audison AP F8.9bit amp tune file
As per the brilliantly useful 'Share your BimmerTech PP82DSP Amp Tune Files' thread
https://f30.bimmerpost.com/forums/sh....php?t=1182351 Does anyone have tune files from the Audison AP F8.9 they would like to share? I'm starting my install on monday so once I have a tune file, I'll share here. Components I'm using: Audison AP F8.9bit Focal ES100K 4" components Rainbow 8" under seat subs Hertz HCP 1D sub amp JL 10W3V3-4 sub Basser F31 boot sub enclosure
Midnight Black Jaguar XKR Convertible | Saphire Black BMW F36 430d Gran Coupe | Iceberg Silver 2002 Renault Clio 172 Track Car
12-06-2021, 05:10 PM | #2 |
Rep 255
Wow. one thing I will say is that the software is not a patch on the Audiotech Fischer software!! Maybe thats why no one has commented or posted a tune file yet... no one can understand it!
10-10-2022, 06:39 PM | #3 |
Bmw driver
Rep 15
Drives: 2016 320i F30 Sport GP
So nice. I will share mine
10-10-2022, 07:28 PM | #4 |
Bmw driver
Rep 15
Here is my setup attached
10-12-2022, 09:31 PM | #5 |
Bmw driver
Rep 15
It's not easy to get the tune of f8.9 bit right...
There is a downloadable configuration tune file on the Audison website, but it is pre-configured for a hi-fi system only. I downloaded it and did VO Code on my car to Hi-Fi system (SA 676). At first I noticed that it was working fine. ok, but it didn't turn on my external subwoofer APBX 10AS (channel 9). I entered the configuration and noticed that in this setup there was no channel 9 pre. And then the madness started... Because the output channels cannot be reconfigured after the setup wizard is finished. I did a lot of testing and compared the configuration binary files (in hex format) and that's when I was able to redirect the rear subwoofers from the original configuration to the front/underseat subwoofers and add the rear subwoofer on channel 9 pre. This took about 2 hours or so. But now I have something very satisfying. is final tune attached. Last edited by armenio1986; 10-13-2022 at 07:44 AM.. |
08-08-2023, 08:09 AM | #6 |
Rep 2
armenio1986 Where on the Audison site did you find their tune for your specific car? I've been looking everywhere and can't find it. The Configurator just tells me what speakers to buy. Thx!
08-08-2023, 03:00 PM | #7 | |
Rep 485
When you do load someone else’s dsp map just check the crossover point for the focals and have them anything from 150hz up. And knock of at least -3db on the tweeter if running active Maybe try something like below as a starting point.. Es100k 150-20,000 , 24 db / high pass Ranbows 50-60hz - 150-175 24 db bandpass JL up to 60hz 12 db |
10-05-2023, 08:34 AM | #8 | |
Bmw driver
Rep 15
Depois, dentro da página específica do meu carro onde todo o setup de equipamentos é exibido, encontrei o arquivo na seção "Download setup files" > "Plug&Sound Setup File" as an example, this can be seen here: https://audison.com/spc-kit/?kit=661...=17&y=5&type=4 |
10-05-2023, 08:39 AM | #9 |
Bmw driver
Rep 15
After many hours of making some refinements, I have the most satisfying setup yet.
10-22-2023, 04:17 PM | #10 | |
Rep 2
