12-18-2018, 12:20 PM | #89 |
Rep 32,881
12-22-2018, 05:59 AM | #91 |
Rep 32,881
12-23-2018, 05:46 PM | #92 |
Rep 68
Ok, the results are in.
I followed the instructions in the original post and used the same products. I must say, I am very happy with the outcome! Not as good of a job as Teaston but I am thrilled with what I managed to achieve given the starting point. Before: After: The most noticeable part is where there is a transition between the original manufacturer lacquer and where I have sanded down to bare metal before re-lacquering. However, this is only noticeable in the right light (as I have tried to show in the second picture). The parts where I have only sanded part way through the manufacturer lacquer before re-lacquering are not noticeable at all (there was also damage around the right hand side of the wheel that I didn't show in the first picture). The only damage that remains are the notches right on the corner of the rim that I couldn't sand out without taking off a significant amount of metal and the one scratch further down the spoke that I simply didn't bother working on but these are far less noticeable now than the original damage in the first picture. Thank you Teaston for the excellent instructions and product recommendations and hope others can get similar results too! It's well worth having a go at this before deciding on a full refurb as it's significantly cheaper and great results are possible. |
12-23-2018, 05:53 PM | #93 | |
Rep 32,881
Still it looks great, as I've always said you'll still notice it if you stare at the wheel, but nobody does that, it's just not noticeable under normal conditions. So much better than spending £100 on a refurb that will corrode after a few months, and that you could go and kerb the wheel again a few days later. |
SEF13.50 |
03-08-2019, 02:38 AM | #95 | |
Rep 32,881
And it’s a bit cold for spraying currently so make sure to heat up the wheel and spray can to at least 20°C! |
03-10-2019, 09:50 AM | #96 |
Rep 229
Gave this a go as well for some minor-ish chips. Did the lacquer coats and waiting for it to dry. At the minute the lacquer looks slightly matte and under a direct light (LED lamp), grainy (very fine though). This is like, under 'starring' conditions though Is that normal and would you get it completely glossy with the final wet sanding stage and compound?
'22 G21 M340i xDrive (MHT) in DG
Gone: '18 LCI F32 440i M Sport Plus in EBII '15 LCI F30 330d M Sport Plus in EBII |
03-10-2019, 10:13 AM | #97 | |
Rep 32,881
Give the lacquer a light sand then with the can and wheel at at least 20°C put a thicker coat of lacquer on and you should see it gloss straight away, if not then spray a bit more on, best done with the wheel laying flat. Then leave for at least 48 hours before sealing, and keep above 20°C for at least the first couple of hours of drying. |
03-10-2019, 10:26 AM | #98 | |
Rep 229
I'm thinking I might have been keeping the can too far away and the coats were too thin. I'll see how it looks once completely dried and after some wet sanding to finish it off.
03-10-2019, 02:20 PM | #99 |
Rep 229
This is what I mean by the way. The glossy-er bit is the original lacquer where the wheel was masked. Hoping to get the sprayed area a bit clearer with some wet sanding and compounding. Don't want to start again...
03-10-2019, 03:03 PM | #100 |
Rep 32,881
03-24-2019, 07:50 AM | #103 |
Rep 3,667
I need to try this......
When I swapped to winter wheels back in November, I noticed that one of my summer rears had a screw in the central tread. The garage repaired the puncture, and I duly parked my wheels away in the shed for the winter. This weekend, I took them back out to give them a quick clean before I got them put back on, and to my horror noticed a sizeable discoloured area per the photos below. I can only assume the muppets nicked the lacquer coat when they took the tyre off to repair it, and over the winter the changes in temperature & resulting condensation in my slightly damp shed has caused this. I did wash and dry them at the time, but they're not stored in wheel bags or anything to keep them completely moisture free. The lifted edge of the lacquer was so sharp I thought at first the actual alloy itself was cracked. Really gutted. I've been exceptionally careful with my 403's given how easy it is to damage the surface on diamond cut alloys. No point in going back to the garage after nearly 5 months - they'll no doubt tell me to f*ck off or prove it was them. I guess all I can do is attempt a Teaston-esque repair and hope that white worm sets in so I can get it replaced under warranty.... any words of wisdom on how to approach this? . |
03-24-2019, 08:42 AM | #104 | |
Rep 32,881
Blacktemplar3458.50 |
03-24-2019, 08:51 AM | #105 |
Rep 3,667
Cheers teaston. I'm touched by your faith in my cack-handed DIY skills with the use of the phrase "that should be dead easy"
03-24-2019, 01:39 PM | #106 |
Rep 32,881
Important to make sure the wheel and spray can are at least 20°C though, otherwise you’ll have a lot of wet sanding to get a high gloss finish.
03-25-2019, 06:51 AM | #107 |
Rep 3,667
So I'll be leaving it until May or June then..... this is Scotland after all. 20C & dry is a rare occurrence this far north of the wall
03-25-2019, 06:57 AM | #108 | |
Rep 32,881
2 Bar Rectangular Portable Halogen Electrical Heater Quartz Electric Home Office Upright Energy Saving Safety Auto Knock-Over Cut Off Switch (Black) https://www.amazon.co.uk/dp/B07M6RHS..._xgmMCb9SNGGDD |
03-25-2019, 06:58 AM | #109 |
Rep 3,667
Just out of curiosity, does anyone know how much a mobile alloy repairer would take to fix a lacquer problem like mine?
There seem to be a few advertising on line that say they pitch up with an infrared heater to cure the primer, spray booth and oven to cure the lacquer coat. For example, this lot in Glasgow - anyone used them? https://www.alloy-master.co.uk/ |
03-25-2019, 09:16 AM | #110 |
Rep 7,484
^ I used a heat gun to gently warm up the can. I also used a small digital point and shoot laser gun to check temperature. Then use the heat gun to dry the lacquer. It worked a treat. I was very impressed with the end result.
