03-11-2019, 11:59 AM | #89 |
Rep 16,063
Try here: https://www.newtis.info/
03-18-2019, 06:40 AM | #90 | |
Rep 829
03-20-2019, 02:47 PM | #91 | |
Rep 829
Fthree6mafia3.00 |
03-20-2019, 09:54 PM | #92 | ||
Rep 761
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
03-28-2019, 09:26 AM | #93 |
Rep 69
These are simply expensive because they are plug in and play. I plugged in an Audison Prima AP5.9 to a BMW with basic audio. It's not hard to do, but hard working out what to do.
If I had the HK system, I don't think I would make the effort. The basic or hifi system worth while improvements can be made. Improve the amp. gives you the best boost as the speakers are ok, its the lack of power that kills the sound. Plus BMW filters the sound to prevent rattles. If you have a basic system then you're short of the two front tweeters. So for me I added some Eton speakers and additional trim required. The lack of power of the systems is the biggest limiting factor here. Adding speakers with better magnets & coils does not help much if you don't really have enough power to drive them everything stays sounding rather soft. Depending on what you want to achieve a 4/5/6/ or 9 channel amp is required. You needs some sort of DSP or way to balance/eq the sound else it will be a very top heavy sound balance. You can buy the pre made cables available but again very expensive and not necessary as it very easy to make the cables for a 10th of the price. So using standard amp with DSP and making my own cables I saved around 40% over the plug in and play route. Sound wise replacing the amp. gives tuneful solid bass and much more detail top end. The rather soft sound of the BMW system has gone. Last edited by ashenfie; 03-28-2019 at 09:39 AM.. |
Wgosma806.00 |
04-20-2019, 01:35 PM | #94 | ||||
Rep 37
04-20-2019, 03:06 PM | #95 |
Rep 1,906
The older model 82DSP amplifier had a micro SD card slot which could be loaded with two (2) separate tune files - in addition, next to the card slot there was a tiny push 'control' button one could externally toggle to move from one tune file to the other. I think that's why I stated in above posts that one could load a tune file w/o using the Audiotech software, not really a 'correct' statement, excuse me on that. So it seems on this older 82DSP one could either use the micro SD card containing 2 tune files and manually toggle between the two OR use the audiotech software to 'load' a tune file into the amp. The newer Up7 amplifier has no micro SD card slot but retains the 'control' push button such that the user can externally toggle the tune files w/o using the tuning software......
This might help a bit regards the software tool; I don't have all the steps listed here but take a look. As I recall when I first attempted to get my Win 7 laptop talking to the amp (I'm using Bimmertech 82DSP older model amp) I ran into some issue where I did not have the proper driver...I think Windows alerted me and then did a search and located/installed a driver; I'm running low on my own memory on this, darn can't really exactly recall- but I did have driver hiccup when I started into this software. Obviously the two devices need to be talking to use the software. As best I can tell the computer does not show the amplifier connected as a external 'device' (such as when you connect a USB thumb drive, etc.) - at least I don't see it when I open my control panel in Win 7. Couple of pic's might help a bit. This first screen shot (snip-1) is what you should see when you have computer connected to amp and first initiate/run the software. Then click the 'CONNECT" tab/message shown in red. That should bring up what you seen in next screen shot (snip-2). 82DSP amp is capable of storing 2 separate tune profiles; what you see is (1) V3_F25.... and (2) no setup loaded ('no setup loaded' meant I only stored one tune file). On that screen, if I select (2) no setup loaded then move my cursor down and click 'LOAD" tab then the software pulls up what you seen in the 3rd screen shot (snip-3)- the software has gone to my computer and brought up a list of tune (.apfx) files from which I can highlight one to load to the amp. Highlight the selected file, cursor up to top of screen and click on 'LOAD' tab (located between RESET and Save/Store) and the file is loaded over to the amplifier. Hope this helps; it's a place to start. I do believe that if the software and amp are NOT talking you'll get a message from your computer, again it may be a driver is needed. Good luck/Bill Last edited by Wgosma; 04-20-2019 at 06:05 PM.. |
04-20-2019, 10:48 PM | #96 | ||
Rep 37
Overall satisfied so far. Running stock drivers, with the exception of some Alpine tweeters I had laying around and installed prior to getting the amp. I was running the standard BMW limo tune but changed to faveon's file when I finally got the amp to connect earlier tonight. Kind of hard to judge the difference in amp tunes right now, as it also finally activated the output to my trunk sub I just install last week. Ears are focused on newly found sub bass, which was plentiful. I'll write a more detailed review of my Match UP 7BMW experience thus far after I've had another week or so to form a better opinion. |
04-21-2019, 10:13 AM | #97 |
Rep 1,906
Sounds good!
If you haven't already done so it's definitely worth checking the time alignment of the speakers (mids/tweeters)- I noticed a nice improvement in the sound stage in my X3 when I aligned speakers to driver seating position. I suppose my passengers will suffer inferior quality but such is life, it's mostly me alone In the car. Bill |
08-29-2019, 05:51 AM | #98 |
Rep 81
Hi guys,
A lot of information in this thread, thanks a lot. When a want to change the tune file, I just need to click on the Load button, that's all ? If I do some modification in live, should I redo the Load if it automaticcaly synch ? Another question (maybe I should wait but I'm not patient ). I installed the amp, and put the SUV tune file I found on the website (hope I did it correctly). All the sound seems to come from the center speaker that is very strange. I will upgrade front door and rear pillar speakers on friday, the only speaker that is already upgrade is the center speaker. Can this explain that I feel that all the sound is coming from the center channel ? Anyway, is someone has a good tune file for F20 2018 ? |
11-24-2019, 12:59 PM | #99 |
Rep 255
Drives: F36 430d GC, XKR, Clio 172
Thought I would post in here rather than making another thread.
I'm sure I've read it somewhere and not just imagined it... but if you disconnect some of the speakers (the rear speakers for instance) the amp will re allocated the power from those channels and make the other channels more powerful? Is that total BS or actually true. If so... would it work just by unplugging the rear speakers, or would you need to delete those channels in the IO screen on the software? Thanks
Midnight Black Jaguar XKR Convertible | Saphire Black BMW F36 430d Gran Coupe | Iceberg Silver 2002 Renault Clio 172 Track Car
11-25-2019, 03:24 AM | #100 | |
Rep 2,180
No.
03-04-2020, 07:37 AM | #101 |
Rep 1,245
On Friday, I traded my '14 F30 for an '18 F34. I've worked with the dealer's service department a lot in the past, and they swapped the Audiotec Fischer into my new car.
Having just heard the stock amp during my test drive, I was quickly reminded of just how well the Audiotec Fischer works. The difference was stunning. When the sales rep was in our car explaining iDrive 5 differences, I put on some music and he was shocked at the difference. He wanted to know more, so I showed him the Crutchfield page. This sales rep (with whom I've worked previously) has been selling BMWs for > 20 years, and he's not easily impressed. PS - Thanks again to BMW of Reading (PA) for swapping the amps for me while I waited. They're truly an awesome BMW dealer with great staff. |
03-04-2020, 10:24 AM | #102 | |
Rep 16,063
It makes you wonder why BMW did such a lousy job with the electronics, when by far it's where the most improvement will be had.
03-05-2020, 09:09 AM | #103 | |
Rep 5
03-05-2020, 05:39 PM | #105 |
Rep 500
The best part about the amp is the ability to set delay, individual channel loudness adjustment and EQ. Without this, it's hard to get good imaging. When I first install the amp with OEM speakers without tuning, I can feel it can play louder with lower distortion but imaging is still the same as OEM amp which sucks.
04-27-2020, 08:11 AM | #106 |
Rep 4,515
04-27-2020, 11:32 AM | #107 |
Rep 2,180
04-28-2020, 11:17 AM | #108 |
Rep 10
Anyone know how to connect a separate amp+subwoofer to this Match amp?
I see the Line Out with what looks like one RCA connection and the Remote out with 2 outputs for remote wire. Do I just connect wire from the Positive terminal of the Remote Out on the amp to the remote line in subwoofer amp, then pick one RCA to plug into the Line out to connect to the subwoofer amp? Picture attached of the Match. I guess that makes sense. Im just a little confused because the Technics PnP add a sub LOC harness I'm using has Two RCA and one remote wire. Thanks for the help! |
04-28-2020, 03:27 PM | #109 | |
Rep 2,180
Match amp sub output is mono.
Use an RCA splitter in reverse as the inputs of your sub amp -1 RCA to 2 RCA. Remote out from Match to remote in at your sub amp. Quote:
kdont30.00 |
04-28-2020, 08:18 PM | #110 |
Rep 10
