03-20-2019, 02:00 PM | #1 |
Rep 53
Diagnosis Help - P0171 Lean Code
Hey fellas,
I'm trying to diagnose a lean DTC code P0171 on my 14' 435i. I did once receive a code for o2 sensor circuit slow switching from rich to lean for the downstream sensor. I have done a boost leak test and tightened down clamps on my chargepipe and other seals past the turbo outlet. The car does shudder at time when at cruising or low throttle situation. Car runs fine when driving hard. I replaced the MAF sensor so that should not be the culprit. I also cleaned MAP sensor with CRC MAF sensor cleaner. Below are the freeze frames from my OBD II app. Short term and Long term fuel trims are confusing me since I would thing the long term would be lower since the short term is negative. Only intake mod is a K&N filter in a mppk lower airbox (no mppk tune) Thanks for any help! |
