01-10-2021, 09:43 AM | #23 | |
Rep 495
The oil pricy, but it's cheaper than causing problems by using ersatz stuff in this case. |
01-12-2021, 02:04 PM | #24 |
Rep 99
Yeah, I just placed my order with FCPEuro. Bought the OEM Front/Rear Diff fluid with 4 drain/refill plugs. Two for front and two for back? If thats correct. Am I missing anything else while Im under there doing the job?
01-24-2021, 06:10 PM | #25 | |
Rep 1,454
I used ECS' xDrive service kit. Comes with Shell Transfercase fluid (OEM) and 3 quarts of Redline 75W-85 gear oil. I've had it in for about 4 weeks. I drive the car hard and I notice no changes. Seems good to me. I used Motul Dual Clutch fluid for my 6-speed manual and my tranny is fine. I make sure the oil meets the BMW-spec or has the exact same BMW part # listed as compatible. Otherwise I don't use it. Just my personal experience with non-OEM oil. BMW isn't an oil manufactuer. They just picked a spec off the shelf that also works with their off the shelf diff.
2022 CT4-V Blackwing 6-speed
01-25-2021, 11:22 AM | #26 |
Rep 216
I'm going to add this is the difference between GL-4 and GL-5. This may explain the reason why those with limited slip need different fluids than those without.
It looks like those of us with x-drive might be able to use the same fluid front and rear for our differentials but nothing confirmed yet. https://www.rymax-lubricants.com/upd...gl-4-and-gl-5/ |
10-24-2022, 11:15 PM | #27 | |
Rep 328
The fluid
11-11-2022, 12:51 PM | #28 |
Rep 2,655
I used Redline 75W85 50104 in my 340i xDrive rear differential. I'm trying to see if the same fluid can be used for the front differential (NOT TRANSFER CASE). I believe you can, but will do a bit more research before swapping it out.
09-20-2023, 12:55 PM | #29 |
Rep 42
WrxToBeamerGuy492.00 |
