BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Transmission oil level check
Studio RSR
      10-14-2023, 05:01 AM   #1
lukenzo
Drives: F31
Hi all.
Long story short: recently I had my gearbox replaced (incl. oil/filter change) and adaptation. After that my car still shifts a bit weird and someone suggested to check if there is enough oil in the transmission. Gearbox code is GA8HP50Z.
Is it true, that in order to check transmission oil level I just need to get ATF temperature in 40-50 degrees range and remove fill plug? And if there is enough oil it should be only a slow stream coming out ?
Like in this FCP Euro video around 13:30 ?
Thanks!
      10-14-2023, 11:20 AM   #2
RPM10000
Drives: F32
Yes
