BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos > 992 Porsche 911 GT3
Studio RSR
      02-16-2021, 08:01 AM   #1
stein_325i
Ring Leader of G8X Haters
stein_325i's Avatar
Drives: A Car
992 Porsche 911 GT3
Motorsports technology meets the road: The 2022 Porsche 911 GT3
Originally Posted by Porsche
Atlanta, Georgia. Porsche continues the tradition of transferring what it learns on the race track directly to cars designed for the road in its latest model, the new 2022 911 GT3. Making use of extensive lightweight materials, refined aerodynamics and a motorsports-derived double wishbone front axle layout, the new 911 GT3 aims to raise the bar once again.
"With a soul that's born in the Motorsport, the new 911 GT3 sends a driver's heart racing," said Kjell Gruner, President and CEO of Porsche Cars North America, Inc. "Whether it's a customer enjoying their favorite twisty backroad or taking to the track, the new 911 GT3 promises to be among the most exciting and rewarding cars we make."
Engine: The heart and soul of a racer
A naturally aspirated 4.0-liter, six-cylinder boxer engine that revs to 9,000 rpm is at the heart of the new model. Generating up to 502 hp and 346 lb-ft of torque, the engine offers extremely sharp throttle response thanks in large part to its six independent throttle bodies. This engine is virtually identical to the unit found in the new, track-only 911 GT3 Cup race car. The seven-speed Porsche Doppelkupplung (PDK) transmission – engineered and tuned specifically for the 911 GT3 - is included as standard equipment, while a six-speed manual transmission is also available to order for customers who prefer a particularly engaging driving experience. This engine, which was first introduced in the limited-production 2019 911 Speedster, has been further optimized for use in the new 911 GT3 with new pistons. A dry-sump lubrication system ensures a sufficient oil supply even at very high lateral and longitudinal loads by using a total of seven suction stages that quickly return oil to the external tank. Acceleration from 0 to 60 mph with the standard seven-speed PDK takes only 3.2 seconds and top track speed is 197 mph.
Lightweight materials
The free-revving engine is only a one part of what makes the latest GT3 such a standout. Based on the 911 Carrera body, front track width increases by 1.9 inches. Despite the change in size, the new model weighs almost virtually the same as its predecessor. This is possible thanks in part to a more extensive application of lightweight materials in the body than ever before in a 911 GT3. The hood, rear wing, and fixed rear spoiler underneath the wing are all made of carbon fiber reinforced plastic (CFRP). Lightweight, noise insulated glass on all of the windows also aids in accomplishing the ambitious weight target.
Chassis and brakes
Narrowing the gap between race and road cars even further, the double wishbone front axle of the new GT3 is derived from the 911 RSR and 911 GT3 Cup cars and adapted for road use, marking a major milestone in the history of the 911. The new front axle offers even more direct and precise steering than the predecessor. Cornering stability improves, allowing for higher cornering speeds and better mid-corner control over uneven pavement. As with past models, the rear axle uses a multilink design, but for this generation an even greater number of ball joints in both the front and rear are used, further enhancing the capability of the GT3 chassis. In fact, the new GT3 suspension does not share any parts with the current 911 Carrera models.
The standard braking system also boasts improvements over the predecessor model with cast iron discs measuring 408-mm in diameter on the front axle, which is a 28-mm increase over the previous generation. Despite sharing a diameter with the recently introduced 911 Turbo models, the discs used for the GT3 are approximately 17 percent lighter due largely to the use of a narrower friction ring. Porsche Ceramic Composite Brakes (PCCB) are also available as an additional cost option. The optional system includes rotors with a diameter of 410 mm in the front and 390 mm in the rear that offer weight savings of about half compared to similarly sized cast iron brake discs and significantly improved thermal load capacity. The ability to deal with very high heat is achieved primarily through special cooling channels in the brake discs as well as newly developed, highly efficient ventilation of the brakes.
GT-specific forged alloy wheels with a 20" diameter in front and 21" diameter in the rear contribute to the overall improvement in vehicle dynamics. The front wheels are half an inch wider than the wheels of the previous GT3, and gain an inch of diameter in the rear. Despite increased width, the new wheels are also about 3.5 lbs (1.6 kg) lighter in total as compared to the wheels on the preceding model. Customers may also specify pin striping on the wheel in either Shark Blue or Guards Red.
Complementing the new wheels, specifically developed ultra high performance summer tires that are 10 mm wider at both the front and rear, now measuring 255/35ZR 20 on 9.5J x 20 front wheels and 315/30 ZR 21 on 12J x 21 wheels at the rear. For drivers who desire an even more track-focused setup, Porsche is offering a street legal track tire – previously reserved for RS models – for the first time. These tires were used to complete the benchmark laps set at the Nürburgring.
The new 911 GT3 lapped the 12.944 mile (20.832 km) configuration of the most demanding track in the world, the Nürburgring-Nordschleife, in 6:59.927 minutes. This is where the 911 GT3 demonstrates its capabilities in impressive fashion. During final testing, it lapped the Nürburgring-Nordschleife, traditionally the ultimate proving ground for all sports car developed by Porsche, over 17 seconds quicker than its predecessor.
Aerodynamics
Aerodynamics also play a critical role in the improved performance capability of the new model. The new front fascia includes integrated cooling intakes as well as an adjustable front spoiler lip and an adjustable front diffuser that can be set up in stages for track use. Specifically developed side skirts optimize airflow around the wheels, but the most visually striking aerodynamic development lies at the rear where swan-neck connections support the rear wing, and a large rear diffuser is visible. As in the front, the rear wing is manually adjustable in stages ranging from settings intended for road use to positions intended for use only on tracks. Even in the "normal" position, aerodynamic downforce is up to 50 percent greater compared to the preceding 911 GT3. When the performance position, which is not intended for street use, is applied to both the front and rear, downforce increases by up to approximately 150 percent.
Interior
The connection to racing continues inside where a GT3 Multifunction Sport steering wheel with a 360 mm diameter and upholstery in Race-Tex is standard equipment. For the first time in a 911 GT3, the steering wheel also includes a drive mode switch, allowing the driver to switch between driver configurable settings by simply turning the dial.
Four-way Sport Seats Plus are included as standard, while 18-way Sport Seats Plus and carbon fiber Full Bucket Seats, the latter of which save roughly 26 lbs. compared to the standard seats, are available as extra cost options. While most of the interior is closely related to other eighth-generation 911 models, one difference in particular is plainly obvious: the gear selection lever. Specifically designed for the GT3, the PDK gear selection lever is based on an adapted version of the manual transmission gearshift lever. Unlocking it to change gear selections is possible by pressing on the shift pattern visible on the top. Additionally, this design allows for manual upshifts and downshifts without the use of the paddles.
There is also a GT-specific "Track Screen" function that reduces the amount of information in the screens surrounding the analog tachometer to the bare essentials and groups that remaining information closely around the central dial so that remains easily visible. Tire pressure and water temperature are always visible on the left, and on the right the display is individually configurable.
The Chrono Package continues to be available as an additional cost option. This feature, which differs from the Sport Chrono Package found on many other Porsche models, adds an analog stopwatch on the dashboard and a digital stopwatch in the instrument cluster. This also adds Lap Trigger support. The Lap Trigger, which is available through Porsche Tequipment, allows for very precise measurement of lap times that can be analyzed and compared on a smartphone using the Porsche Track Precision app.
Market launch and availability
The new Porsche 911 GT3 is expected to arrive in U.S. as a part of the 2022 model year, reaching dealers by Fall 2021. Market specific pricing and order availability will be announced closer to that time.
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300
mkoesel7511.50
turbo_joe1614.00
clutchdj1877.00
BigHunk269.50
      02-16-2021, 08:09 AM   #2
stein_325i
stein_325i's Avatar
Drives: A Car
turbo_joe1614.00
      02-16-2021, 08:26 AM   #3
HeelToeShift
Drives: Mine
MIGHTY, MIGHTY impressive car. Under 7 min N'Ring lap is nothing short of incredible. Speaks well for the RS and 2RS.
stein_325i25083.00
AlexFL7836.00
WolfGTI716.00
      02-16-2021, 08:32 AM   #4
No Boost
enthusiasm > practicality
No Boost's Avatar
Drives: 987 CS | G35x
The 992 GT2 RS is going to be mental based upon the sheer speed of the Turbo S and the CFRP laden GT3.
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp
Left lane campers, GTFO!
      02-16-2021, 08:35 AM   #5
Murf993
Murf993's Avatar
14114
Drives: Porsche 993
You have to wonder how much better Porsche can do and then they make more improvements. They are a force to be reckoned with.
stein_325i25083.00
NickyC17473.50
Vivek.1366.00
nicholasn261.00
      02-16-2021, 08:36 AM   #6
stein_325i
stein_325i's Avatar
Drives: A Car
There's a reason there is no substitute...
This is gonna be one hell of a car. I'm sure the markup and allocations are going to be insane.
Murf99314114.00
minn1914028.50
      02-16-2021, 08:38 AM   #7
HeelToeShift
Drives: Mine
And to think...how much did the purposely hold this car back for the 3RS and the facelift in a few years. It is never even close to a 100% max all-out exercise.
stein_325i25083.00
Murf99314114.00
      02-16-2021, 08:39 AM   #8
HeelToeShift
Drives: Mine
Markup will be 50-60K over MSRP for the GT3.
stein_325i25083.00
      02-16-2021, 08:44 AM   #9
Murf993
Murf993's Avatar
14114
Drives: Porsche 993
I'm not a big fan of the mark up but that's capitalism....on the flip side, even with the markup this thing will crush super cars costing much much more.
      02-16-2021, 09:10 AM   #10
stein_325i
stein_325i's Avatar
Drives: A Car
Looks like the PDK won't be a little toggle shifter like the Carrera's. Almost fooled me into thinking it was a stick.
Vivek.1366.00
TSM330i877.50
      02-16-2021, 09:13 AM   #11
baege
Drives: 2022 Cayman GTS 4.0 6MT
I can't believe how race car it sounds despite the OPF, porsche somehow managed to surmount this obstable this time (unlike with the GT4)
      02-16-2021, 09:27 AM   #12
GOLFFRR
GOLFFRR's Avatar
10810
Drives: GOLFFRR cart
so sick
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      02-16-2021, 09:31 AM   #13
Conelays
Drives: e90 m3
Porsche has been killing it over the past few years, and the 911 turbo is seriously something to be reckoned with too.
Murf99314114.00
      02-16-2021, 09:41 AM   #14
R N M
R N M's Avatar
3633
Drives: F80 M3
2016 BMW M3  [0.00]
Well Porsche is firing on all cylinders.
They got the offerings with NA engines, Turbos, Hybrids and even full EV.
I NEED this GT3!
Current
2018 F80 ///M3 CompPack; 2020 BMW X3 M40i
2015 Subaru BRZ Series.Blue (https://www.youtube.com/watch?v=qEBobwprGtA)
Previous: 2016 F80 ///M3; 2013 F10 535i MSport; 2012 F10 528i MSport; 2009 E92 335i MSport
Murf99314114.00
      02-16-2021, 09:53 AM   #15
irunalot
Drives: Porsche Carrera S
Man another impressive GT from Porsche. WOW I need this car ugh
Murf99314114.00
      02-16-2021, 09:57 AM   #16
NickyC
NickyC's Avatar
17474
Drives: M4 CS. Former G82, x2 F82, F80
Pretty incredible, but prior model is way better looking in my opinion. That car was absolutely perfect.
ntg442888.50
omgf80207.00
Murf99314114.00
      02-16-2021, 10:09 AM   #17
Gdiddy23
Drives: 2020 M340i
2015 BMW F30  [0.00]
How could you not love this
2020 M340xi PB (sold)
2020 Ram 1500 Laramie (Daily)
2019 Shelby GT350R (Weekend)
Murf99314114.00
      02-16-2021, 10:33 AM   #18
Humdizzle
Drives: GT3 + M2c
not super impressed.
the lap time is with Cup 2R tires. These are better tires than the last GT3 and RS got.
straight line performance is the same
weight is the same
some improvements to aero and suspension
the carbon buckets are the same
looks arguably worse (bumper and swan neck wing)
From car and driver:
Performance is barely changed over the 2017 GT3: Porsche is claiming a 3.2-second zero-to-60-mph time for the PDK and a 3.7-second time with the stick. (We ran the old car through that benchmark 0.2 second quicker, manual or auto.) Top speed is 197 mph with the PDK and 198 mph with the manual.
Bigger differences should emerge on racetracks, where the new suspension and aero improvements will pay lap-time dividends. Porsche confirms the new GT3 lapped the Nürburgring Nordschleife in less than seven minutes. In fact, with a 6:59.927, it is less than a handful of hundredths below the hallowed mark. And if you're well versed in 'Ring lore, you'll balk when we say this is faster than the 6:57 and 6:56 laps set by the 991.2 911 GT3 RS and 918 Spyder. Those lap times were set using the old benchmark that wasn't an actual complete lap. Using the old standard, the new 992 GT3 turned a 6:55.2.
To lap that quick, though, you'll need the optional Michelin Pilot Sport Cup 2Rs, as Pilot Sport Cup 2s come standard on 20-inch front and 21-inch rear wheels.
i was expecting more. i'll keep my 991.2 for now. If someone is in the market for a gt3 though i'd recommend they get a new one and spec it how they want. although be prepared to pay the dealer markup. i'm sure with good specs these will be near or over 200k.
2018 Porsche GT3 6MT
2021 M2C DCT
Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS
NickyC17473.50
      02-16-2021, 10:37 AM   #19
NickyC
NickyC's Avatar
17474
weight is the same
Your car is way better looking too!
Humdizzle6054.00
      02-16-2021, 10:58 AM   #20
hellrotm
Drives: F80
Perfection.
      02-16-2021, 11:10 AM   #21
Law
Global Moderator
Law's Avatar
Drives: E90 M3 6MT
2011.5 BMW M3  [10.00]
2004 BMW M3  [10.00]
Yes, overall these are incremental (evolutionary) changes over the 991 but that's what keeps the line focused and true to its form.
In that philosophy, things that ain't broken don't need fixing and tradition is important.
But you can't really win as a car manufacturer, can you?
Too much change and you have people saying Porsche/BMW/Insert Brand Name here has lost their way...the older models are better.
Too little change and you have people complaining about what's the point of the new one...might as well get the older models.
My favorite is still the 997.2 but all in all, I think the world is better off having this 992 GT3 than without it.
The interior is a huge step up as well (I find the entire 991/981 generation of interiors to be quite horrible).
In the end, can we just celebrate the fact that a car manufacturer is even making a brand new car with high-rev NA engine with a manual gearbox in this decade?
2011.5 E90 ///M3 | 6-Speed Manual | Slicktop | Jerez Black | Fox Red
E9x M3 Press/Media Archives Thread | S65-based Racing Engines Thread
Appreciate 7
Humdizzle6054.00
AlexFL7836.00
irunalot1518.00
Fined243.00
Murf99314114.00
nicholasn261.00
      02-16-2021, 11:22 AM   #22
swagon
swagon's Avatar
Drives: F80 6MT
The front bumper needs to be full color
