04-13-2021, 09:38 AM | #1 |
Rep 187
Adaptive suspension knocking at low speeds
I swear I'm not crazy. At super low speeds, like 5mph or so, there is a very slight knocking sound from the suspension. You can hear it from time to time at higher speeds, but it's really hard to focus on. I can't get my dealer to hear it or understand what it could be, but I don't hear this particular sound on any of my other cars. Does anyone know what could cause this, so I can point my mechanic in the right direction?? Is there a point that commonly fails on the adaptive suspension?
'17 440xi GC THP, MPPSK, AA Catted DP, Dinan CF CAI, TU HPFP, BM3, xHP, E-Sys
04-13-2021, 11:32 AM | #2 |
Rep 3,539
When does the knocking occur (types of surface features, front or rear, only high speed, ect.)? It's unlikely it's active suspension specific.
04-13-2021, 12:17 PM | #3 |
Rep 10,256
There are no known common M adaptive suspension weak points. The shocks are quite sturdy and have a decent life span - well beyond 50K miles.
Few questions (while acknowledging that remote diagnostics are rarely effective): - When did the sound start? - Is there a distinct metal-over-metal pitch or something more dull? - As FaRKle! indicated earlier: front or rear? Also - measure the gap between the wheel and the fender. If the gap is substantially different, this is worth investigating. The shock (more probable) or spring (less probable) could be failing. |
AllaVodka634.00 |
04-13-2021, 02:08 PM | #4 |
Rep 417
Could also be any suspension part, control arm, sway bar link.
My front M adaptive suspension were leaking badly but were still handling better than the stock F30 suspension, they did make a noise that I thought was a bad ball joint, but it was the shock because the noise went away when I replaced them with Bilsteins B4.
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD) '85 635csi M30 turbo race car (SOLD) |
04-13-2021, 11:25 PM | #5 |
Rep 187
I have had the car for only 2500 miles of it's 25k miles. It has had this sound for as long as I can remember, but it's really faint so I blamed it on the run flats until I changed them to go-flats and had an alignment done. Now the noise is more clear. It happens over slightly uneven pavement and can be heard best going slowly around a parking lot. It is definitely coming from the front and the sound reminds me of a poorly fitting knuckle or ball joint.
The wheel gap measures 4.875" on all but the front passenger side, where it measures 4.75". This is from the top of the rim to the to of the fender arch on an X-drive car with factory adaptive suspension and springs. |
04-14-2021, 03:51 AM | #6 |
Rep 3,873
Unrelated, but could you please measure your distance(s) from the centre of the wheel vertically to the arch? Just want to compare...
On-topic: I have the same suspension and have bought the car new. Already at the beginning I heard a knock a few times when going over speed bumps. Not every time and obviously very dependent on the speed (I never go too fast over them). It was a single knock coming from the front, like metal hitting metal. I have not heard it for quite some time now....
04-15-2021, 12:41 AM | #7 | |
Rep 68
_______________
340i Mineral Grey - M Sport package - Adaptive M Suspension Last edited by rooosh798; 04-15-2021 at 12:47 AM.. |
04-15-2021, 02:14 PM | #9 |
Rep 68
There's a bunch of threads on here about aftermarket springs not playing nice with the stock strut top mounts. Maybe that could be your issue.
_______________
340i Mineral Grey - M Sport package - Adaptive M Suspension |
04-17-2021, 04:53 PM | #10 |
Rep 1,909
I have the same thing with my 17 340i xdrive with adaptive suspension. faint knocking sound at low speeds. had a driver side front strut replaced and the issue was still present. also replaced leaking thrust arms, still present. right side front strut is next thing on the list, as it is leaking a little bit but not sure if its enough to cause the noise. the springs have been stock.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
04-18-2021, 01:51 PM | #11 | |
Rep 122
I've heard that early F-series with adaptive suspension had noise/sound issues. My 340i (10-2018 production) with adaptive suspension is fine, no strange sounds from the suspension
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800, OS Giken LSD, Ross Racing PCV+OCC V1
04-19-2021, 12:22 PM | #12 |
Rep 187
Mine is MY17, 10/16 production, so it's an early LCI. I have an appointment with an Indy in my area to take a drive and a look on Wed so I'll report back!
04-29-2021, 12:17 PM | #13 |
Rep 187
So I now have had 3 shops look at this, along with an alignment, and there is nothing wrong. The slight knocking sound is just that this suspension/tire combo is noisier than the stock non-adaptive setup. Crisis averted.
Uni-Rapide71.00 |
05-07-2021, 02:32 PM | #14 |
Rep 32
I had a knocking from the front left at low speeds over almost any type of road surface. Mileage is 69xxx.
I started with- replacing the steering box bushing- no change torsion arm- it was leaking/bad but no change lower control arm and upper strut mount- no change despite the strut mount being utterly shot strut- this was the culprit. I bought a pair of Bilstein B4 dampers so that I could save a few bucks over oem and I wasn't ready to commit more money for the b6. I'm so much happier driving it as it's been noisy since I bought it used in Feb of this year. |
05-07-2021, 10:56 PM | #15 |
Rep 143
I have a gravel driveway and hear the knocking sound everyday. Seems to be more prevalent in colder temperatures. The sound was there with my 2016 F31 328ix with adaptive and stock springs. Now running Eibach springs and the sound is still there. Dealership could not hear/replicate the sound. I thought I'd seen a thread some time ago with an SIB software fix for the adaptive struts. To me the sound is like shaking dice in cup with your hand over the open end.
05-08-2021, 05:39 AM | #16 |
Rep 8,494
Sorry to contradict some of the replies that state that there's no known problems with the adaptive dampers, but...
To the contrary, there was/is a problem with these units, depending on the age of the car. The adaptive damper valves are known for their opening/closing to not be optimised with the inputs that they are trying to control, which results in a knocking/clunking noise. It's typically heard at low speeds, say up to 20mph. There is a PUMA case on BMW's systems which (from memory) resulted in a QE (Quality Enhancement) which includes a software update to change the operation of the damper valves. I had this update applied to my car and it cured the problem. Ironically this only happened after BMW replaced both front adaptive dampers because it couldn't sure the knocking noise. Of course that's not to say that all knocking noises originate from the adaptive dampers, but it's certainly worth investigating.
cfm56d7b5886.00 |
05-08-2021, 11:14 AM | #17 | |
Rep 10,256
05-08-2021, 02:36 PM | #18 | |
Rep 8,494
His reply does at least confirm that a PUMA case does/did exist on BMW's systems for this issue.
cfm56d7b5886.00 |
05-08-2021, 05:21 PM | #19 | |
Rep 10,256
