View Poll Results: Is you navi info displaying correctly in 6wb Kombi? | |||
Yes | 5 | 50.00% | |
No, right side is cut off, graphics off centre | 4 | 40.00% | |
Yes, I had right side cut off but I fixed it (F3x) | 1 | 10.00% | |
I don’t know/ I can’t tell | 0 | 0% | |
Voters: 10. You may not vote on this poll |
05-09-2021, 05:03 AM | #1 |
Rep 43
F30 6wb coding to fix navi info not centered and cut off on right side
Hi, I have searched and read through all threads I could find, but still no definitive fix for this problem.
So I have a 2018 F30 with 6wa and hu_entrynav2 (entry evo or evo light, small display), no HUD, vin ending A605596, and have recently retrofitted 6wb. All is well, except the navi info in the kombi, the arrows or graphics show slightly off centre to the right, and also the right side of the graphics is cut off. Did anyone with F3x manage to get the correct navi graphics, centred and no longer cutoff on the right side, after retrofitting the 6wb? Or is it something we just have to live with? Please share your experience if you have the same problem or if you managed to find fdl coding for fixing this. I only request people with F3x to reply, it seems there is a fix for similar problem for F1x cars but it’s not working for F3x (I know, I tried). |
05-10-2021, 05:46 AM | #3 |
Rep 43
Trust me, I have read through maybe more than 100 pages of different 6wb coding threads and I have yet to see anybody with F3x confirm that some specific coding fixes this issue.
What I did see is people suggesting different coding options which I tried, to no effect. As I mentioned, people I saw confirming that they fixed the navi graphics with FDL coding have F1x 5 series cars. That information is of no use to me. This thread is ONLY about F3x cars and specific to this one issue regarding 6wb retrofit/coding. |
05-10-2021, 07:40 AM | #4 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
Isn’t all the data for the 6WB come from the HU?
Try flashing that to the latest psdzdata. That did solve issues for 6WB with HUD on NBT headunits. |
05-18-2021, 01:36 AM | #5 |
Rep 228
Drives: 2022 G20 330E
VO Code your HU with 6WB and you will see the magic happens.
05-18-2021, 03:14 AM | #6 | |
Rep 43
During coding I believe he did VO code the KOMBI and HU. But I have entry evo, I believe 6wb was option only for id6 navi professional. |
05-18-2021, 11:06 AM | #7 |
Rep 228
nope, i have done lots of 6WB retrofits to all kinds of cars, and if there is MOST connection in HeadUnit it will work as it should do. so my guess is that he didn't code HU, or made some mistakes while doing that.
05-30-2021, 01:17 PM | #8 |
Rep 32
I also have the same issue with my graphic being cut off to the right. As far as I can read there is nothing that can be done. I have tried all sorts of changes for fix the issue, but so far no luck.
05-30-2021, 10:07 PM | #9 | |
Rep 67
I have Entrynav2 with istep level end 2018 and totally new 6wb with istep 2019 and I don’t have HUD P.S I saw today someone suggested to “play” with following FDL values for HU. Did topic starter tried them? Kombi_Aufloesung: aktiv <--> nicht_aktiv MFID_KOMBI_VARIANT: aktiv <--> nicht_aktiv |
12-09-2022, 10:19 PM | #10 |
Rep 42
Here is a fix:
In NBT: HUD_AUFLOESUNG -> aufloesung_1 HUD_KOMPRIMIERUNG_ART -> rle_1 KOMBI_AUFLOESUNG -> aktiv NAVI_HUD_AVAILABLE -> aktiv In Kombi: NAVI_NBT_ENABLE -> nbt_anzeige HUD lines are necessary for displaying road names properly on cluster. I don’t even have HUD. Keep this: MFID_KOMBI_VARIANT -> nicht_aktiv otherwise it will remove some settings under “Instrument Cluster” in iDrive |
AndrewC198910931.00 |
03-24-2023, 05:12 PM | #13 | |
Rep 43
This was disappointing… EntryEvo id6 with retrofitted 8.8” screen. |
03-24-2023, 05:55 PM | #14 | |
Rep 42
This fix is for NBT only and not for NBT EVO/entryEvo. What you want to do is to do some additional research for NBT Evo and apply some of the codes from there. Do remember that you have to remove 6WA from VO completely. |
03-25-2023, 07:17 AM | #15 |
Rep 43
I start to strongly believe that there is no fix for EntryEvo (maybe even Entrynav/CIC) and you need NBT or full EVO ID6 to have navigation info correctly displayed.
