10-07-2018, 10:03 PM | #1827 | |
Rep 2,357
(A Dane in China) |
10-07-2018, 10:12 PM | #1828 |
Rep 1,693
10-08-2018, 12:42 AM | #1829 |
Rep 504
It seems this guy does not listen lol.. Weird thing that anyone who faces any problem with tune earlier was blaming rpm vs coolant temp limiter (which is set as low as 5500rpm) now time has come for 3/6th gear limiter I would not be surprised at all if some guy with 6MT would come and start screaming about gear limiters
bradsm87594.50 |
10-08-2018, 06:59 AM | #1830 |
Rep 931
10-09-2018, 10:50 AM | #1832 |
Rep 2,653
Mine still show 6.1? For PWG only?
10-09-2018, 12:15 PM | #1833 |
1296
Rep 3,532
my EWG still shows 6.1 as well.
10-09-2018, 02:38 PM | #1834 |
Rep 521
FBO Stage 2 93. Here are some logs. Still on stock plugs, 97506's on standby. What should I be looking for to know if I need to swap plugs? There was wheelspin at the beginning of the second run.
Run 1 Run 2
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
10-09-2018, 03:20 PM | #1836 |
Rep 643
you're 1-1.5 psi off from target and your wastegate duty is over 90%.. do you have a boost leak?
10-09-2018, 03:29 PM | #1837 | |
Rep 521
https://f30.bimmerpost.com/forums/sh....php?t=1541882
10-09-2018, 03:49 PM | #1838 |
Rep 227
Have read through quite a bit of this and tons of quality information here. One thing I couldn’t find exactly is whether or not I can run a stage 2 with only a HFC. I don’t have an aftermarket IC yet but have the Wagner HFC. Given that it’s getting colder now, do I NEED an IC to run stage 2 or not necessarily?
10-09-2018, 04:33 PM | #1839 |
1296
Rep 3,532
Whats a good number for the duty cycle?
10-09-2018, 04:52 PM | #1840 |
Rep 643
im not sure, but for reference, i am typically under 80% for 14.8 psi and my WG duty is relatively level through rev range.
since your wg duty increases with your rpm, makes it seem like there's a leak. you're best bet is to see other logs and compare.. or wait for someone else to chime in. |
10-09-2018, 05:06 PM | #1841 | |
Rep 521
Stage 1, stock CP/IC
10-09-2018, 06:36 PM | #1842 | |
Rep 808
A boost leak would be noticeable I'd imagine. |
10-09-2018, 07:23 PM | #1843 | ||
Rep 521
the dope steez403.00 |
10-09-2018, 07:59 PM | #1844 |
1296
Rep 3,532
Yeah I'm above 80 and I hit 90 a little. I'm about .5-1.5psi short of my targets usually
10-09-2018, 08:52 PM | #1845 |
Rep 2,357
What would you call this then?
(A Dane in China) |
10-09-2018, 08:54 PM | #1846 |
Rep 1,693
10-09-2018, 10:30 PM | #1847 |
Rep 1,115
WGDC is affected by altitude, judging by his log he's at some elevation. Mine hits 100% at times and the car has been smoke tested before with no boost leaks.
10-10-2018, 12:24 AM | #1848 | |
Rep 2,357
(A Dane in China) |
