01-03-2019, 12:17 PM | #265 | |
Rep 164
01-05-2019, 03:12 PM | #267 |
Rep 21
Hi all,
My G30 is due next week, it’ll have the NBT EVO (nav pro) but no CarPlay because it’s not an option that can be ordered over here. So I guess not WiFi antenna. From this thread I can see that part number 61119372321 is recommended, but playing around with ETK I can see there’s 61116816435 which seems to be specific to the G30. Any recommendation? |
01-07-2019, 06:50 AM | #268 |
Rep 468
Also as above, I wold like to ask is it better to install the genuine BMW WIFI repair cable antenna or the cheaper FAKRA ebay version?
I see that the BMW antenna is just the cable with a ticker end, as opposite to Ebay Fakra cable which looks like a proper antenna style? Thanks |
01-09-2019, 07:15 AM | #269 |
Coding ECU's remotely
445
Rep 1,176
61119372321 is the right part number and fits the G series cars no issue (EVO systems are all the same)
The issue with firmware 11-18 will hopefully be resolved this month.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
01-09-2019, 07:19 AM | #270 | ||
445
Rep 1,176
01-09-2019, 04:57 PM | #271 |
Rep 69
Simon at Bavarian Coding did apple CarPlay fully screen on F020-18-11-531 back in November last year
01-14-2019, 06:05 PM | #273 |
445
Rep 1,176
Thats not 18-11 firmware, it's 18-03. It would be NBTevo_P if it were 18-11.
01-15-2019, 03:40 PM | #275 | |
Rep 69
Firmware 18-11 for you |
01-30-2019, 08:49 AM | #277 |
Rep 2
Hello,
sorry if I post in this section of the forum but i couldn't find a more appropriate one. Would this Headunit support CarPlay on Mini F56? Part number is 65126842266 Thank you |
01-31-2019, 11:57 AM | #278 |
Rep 1
Picked up my BMW F46 three months ago, didn’t get Apple air play prep, is there any way to add it as an aftermarket. My connected store says it’s not available. What do I need?
02-01-2019, 12:29 AM | #279 |
Rep 14
I'm in the same boat. Bought my first new BMW in 18 years and passed my E46 along to my son. 340i, August 2018 build. Assumed Carplay would be installed or available for purchase but doesn't show as available on connected store. Wifi hotspot not showing as a connection option, so I assume I need a wifi antenna, but it's not clear to me whether I need anything else.
02-04-2019, 12:43 AM | #280 | |
Rep 468
02-04-2019, 03:58 AM | #281 | |
445
Rep 1,176
F46 Active Tourers use a business nav system, Carplay is a factory order only.
02-05-2019, 12:35 AM | #282 | |
Rep 15
Software updates after Apple CarPlay
Have you had any software updates done at the dealer after enabling? |
02-10-2019, 02:44 AM | #283 |
Rep 2
Hi guys,
About to buy a used i8 and want to retrofit CarPlay. Seen a few references to guys in the UK that can do this for me but can someone share contact details or can of those folks message me to arrange to get it done? Also note that BimmerPost have something you can buy too, but I don’t know if that’s better/worse? Or if it’s the same thing essentially? Hope you can help! |
03-06-2019, 09:06 AM | #284 |
Rep 2
Hello all.
I've recently bought a late 2017 F16 which doesn't have carplay. It's not available on the connected drive store. The car is fitted with ID5 and I believe the NBT_EVO HU. I assumed it didn't have the WiFi antenna; however following the submission of a question to Bimmertech along with my VIN, they've advised that my car does in fact have the WiFi antenna fitted, so all I need is the code on USB. wibbles I've tried to PM you as you seem to be extremely knowledgeable on this topic, and I'd like to find out if you'd be able to provide the required codes for USB installation in the F16, but apparently your mailbox is full. I'd appreciate it if you could let me know when it's possible to send you a message on this subject. |
03-06-2019, 01:00 PM | #285 |
Rep 1
Hello,
I've read most of the messages on this post, but still unsure what I'd need to do for Carplay activation. I have just bought a June 2018 F32 435D which has ID6 and Nav Pro HK fitted - is that NBT_EVO?. Car doesn't have EB so guess I'll need an antennae fitted. |
03-07-2019, 10:07 AM | #286 | |
445
Rep 1,176
