01-11-2019, 12:31 PM | #1 |
Rep 525
Anti-theft advise?
just wondering if anyone else use such devices like trackers or coding immobilisation or whatnot?
i dont have comfort access so not sure if i need to be worried or not about my car being nicked... (or as much as say, owners who Do have keyless). don't think the 440i is desirable enough to want to be nicked anyway, but in any case, can people 'hack' into the car? or is this only a concern for keyless entry folk? |
01-11-2019, 12:42 PM | #2 |
Rep 3,965
Never heard of non keyless entry cars being hacked but maybe I've missed it?
I use a Disklok all the time and have gap insurance - that's the extent of my precautions. Has worked for many years now, touch wood
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
01-11-2019, 12:50 PM | #3 |
Rep 620
Vehicle Replacement GAP insurance
I have comfort access, but am told things are more secure now (not sure if thats the case?) At the end of the day if some scrote is determined to take the car, chances are they will. All I can do is make sure I get a replacement.
Current - 2018 F32 430d M Sport+
Previous - 2013 F30 320d M Sport Previous - 2008 E92 320d SE |
01-11-2019, 03:34 PM | #7 |
Rep 821
It's not advisable to advertise on a public forum what security you have on your car or home.
Don't be fooled in to thinking a 440 isn't a desirable car to be stolen. Any BMW is a desirable car when these thieves are selling your car on for just a fraction of the cost of it to his cousin in the next town. Disc lock is a good visual deterrent imo. Faraday pouch for your remote keys is a must too. Don't bother with tracker if you have gap insurance. Would you want your old car back if the other option is to get a brand new one that hasn't been thrashed around by the thief? Prevention is better than a cure, so fit a Ghost immobiliser if you don;'t want your car to be stolen in the first place by means of key theft or obc theft, or even signal snatching. I would also highly recommend putting your car in a garage and out of sight if at home at all times. So many cars get stolen off the drive these days, it's untrue. If you have a driveway but no garage, get one of those driveway intruder alarms so you know as soon as someone has come onto your property. They really are a good idea, https://www.ebay.co.uk/itm/1BYONE-WI...PIoA:rk:5:pf:1 |
RENT-A-GOAT462.50 gippy230.00 |
01-11-2019, 03:45 PM | #8 | |
Rep 7,703
Oh, and the Faraday pouch isn't a must for the OP, it's pointless. He doesn't have keyless entry. Only keyless entry keys are permanently transmitting and can be read. |
01-11-2019, 03:45 PM | #9 |
Rep 1,066
01-11-2019, 04:05 PM | #10 | |
Rep 821
The faraday pouch may well not be much use to the op, but one would be useful to many other owners that read this topic. I have just watched a Merc GL being stolen in a matter of seconds by keyless theft, a faraday pouch would have prevented this. For just £6.00, i think it is worthwhile. |
01-11-2019, 04:12 PM | #11 | |
Rep 7,703
It'd be a lot of effort for me, I'd have to build a garage..... |
335d Touring Xdrive318.50 |
01-12-2019, 07:44 AM | #12 |
Rep 624
I've got a Faraday pouch. I didn't spec comfort access on my car due to security concerns but it does have key-less start (as standard) so there's still some risk there albeit a potential thief would need to break into the car first before stealing it - that's not beyond the realms of possibility though.
01-12-2019, 07:54 AM | #13 | |
Rep 7,703
01-12-2019, 07:58 AM | #14 |
Rep 129
when I picked up my car only one set of keys worked, the bmw sales guy said it just needs another coding and did it just as the car door was locked. I assume they do something similar when you lock your car
01-12-2019, 08:03 AM | #15 | |
Rep 821
The position of the obc was in a place where they could access it without ypu car alarm going off once they had broken your drivers side window. I am not sure this is still the case with newer cars. Some people have the obc moved or disabled or relocated. |
01-12-2019, 08:24 AM | #16 |
Rep 624
Its just a case of gaining access to the car using more traditional methods and then using the usual relay trick to activate the key-less start. I was wondering if the immobiliser would stay active if the car hasn't been unlocked with the key but I've not been able to confirm this yet.
01-12-2019, 08:29 AM | #17 |
Rep 620
So does a 2018 car have this type of key?
01-12-2019, 09:47 AM | #18 | |
Rep 7,703
A comfort access key normally transmits all the time, so someone outside your front door can potentially read the signal and steal your car. A normal key only transmits when you press the button, zero risk of being read at any other time. So, as far as I can see, a Faraday case does nothing at all for you. |
01-12-2019, 10:17 AM | #19 |
Rep 1,205
Get a Disklok or a Stoplock Pro/Elite for the steering wheel and maybe an immobiliser as well such as Pandora Immo which works of a driver tag so all you have to do is have it with you to deactivate the immobiliser as opposed to tap in a code like the Autowatch Ghost requires.
If you want an alarm with it and which immobilises the OBD port too then get a Pandora Mini BT. Both the Immo and Mini BT are excellent and a great alternative to the Ghost. The driver tag is not much bigger of thicker than an SD card - a great bit of kit ! |
01-12-2019, 10:18 AM | #20 |
Rep 797
In prior cars I've wired a hidden kill switch to the fuel pump. Doesn't get much better than that. I'd tell you where I hid the switch but I'd have to kill you.
01-12-2019, 10:41 AM | #21 | ||
Rep 624
The normal key transmits in the same way as the comfort access key - that's how the keyless start works. It's actually keyless start that's is the issue. It's not such a big deal that a theif can open the doors - the real problem is that they can start the engine with a relay attack. In terms of key less start both the comfort access key and normal key are exactly the same. |
01-12-2019, 12:49 PM | #22 | |
Rep 1,705
