10-27-2021, 12:40 PM | #23 | |
Rep 1,199
10-27-2021, 12:44 PM | #24 |
Rep 193
Section 9 is physical and chemical properties. ZF seems to have a much more comprehensive technical info document than a traditional MSDS. For ref, this is what I'm looking at (hopefully linking a PDF works)
https://aftermarket.zf.com/remotemed...luid-8-nzl.pdf |
10-27-2021, 01:09 PM | #25 | |
Rep 1,199
There is probably a technical data sheet out there.L that has some extra things like CTE.
Itogliano103.00 |
10-27-2021, 05:35 PM | #26 | |
Rep 3,947
10-28-2021, 01:21 PM | #27 | |
Rep 7,602
What i found most interesting in the MSDS is the viscosity changes by almost a factor of 5 between 104F and 212F. Makes me wonder what the optimal trans oil temp is. |
10-28-2021, 08:11 PM | #29 | ||
Rep 1,483
10-29-2021, 11:26 AM | #30 |
Rep 7,602
10-29-2021, 09:48 PM | #31 |
Rep 1,483
185 is fine. The fact that it goes above 200 tells me that ZF8 LG should be only fluid used.
11-01-2021, 11:51 PM | #32 |
Rep 25
Updates after oil change
Hi guys, sorry just got time to update... I did the Transmission and Diff oil change during the weekend.
New Parts/Oil being used: * ZF Original Oil Pan and drain plug * 7 Litres of ZF Lifeguard 8 -- We ended using c. 5 litres, while manage to bring out c. 4.5 litres. * 2 Litres of BMW Hypoid Axle G1 75W-85 Diff Oil * Drain plug for Diff Result is great tbh, the car shifts more smoothly.. Takeaways: * Previously in Comfort "D" mode from D1 to D2, I feel the shift is not that smooth with a "little kick"; but now after the oil change it's all smooth. I am on Stage 2 XHP tune. * Sport/Sport+ mode to be honest cant feel any change, shift as fast. But I did not push the car too hot/fast. * Differential oil change -- can't feel anything change as well. Will I do it again?? Yes I would... You guys should see what the oil like -- and note turns out my car is near 15,000 miles (not 12k), I got the conversion wrong since we use Kilometres here in Indo. On other note... I also manage to indulge myself with this Spoon Sports Rigid Collar Kit, for the subframe -- hefty price for a very small piece of metal.. Result can be felt definitely in Sport mode (Adaptive Suspension); but the changes is not as drastic as in my Golf GTI. |
11-02-2021, 08:36 AM | #33 |
Rep 1,483
Color of the fluid is not indicative of remaining additives or high oxidation. Only analysis could determine that.
Toyota WS fluid becomes pitch black after few thousands of miles but it is lubricating millions of transmissions without issues. |
F32Fleet3570.00 |
11-02-2021, 09:08 PM | #34 |
Rep 25
Ahh I see, unfortunately I dont think we have anywhere to send the fluid for analysis in this Country.
Anyway though, Im happy with the trans oil change and would do it again from my experience -- in Comfort mode, its far smoother.. But the Diff Oil, to be honest I dont feel any changes -- not that I have any complaint in the first place. Off Topic -- this Spoon Sports Rigid Collar impacted the weight of steering as well, it is lighter but firm (previously I felt the steering is a bit heavy). Most of you will feel it in the Sport mode, stationary not moving, steering is very heavy -- interestingly this rigid collar helped. The more I drove the car, the more I feel like the shock absorbers now absorbs bumps and uneven roads much better. Last edited by b7ff; 11-02-2021 at 09:13 PM.. |
