BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Ordering new tires, need advice on higher sidewall
Studio RSR
      07-25-2021, 05:45 AM   #1
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
Morning guys. Today I hit a real nasty piece of metal on the highway and it destroyed the sidewall on one of my PSS's. Current setup is 18x8.5 ET35 with PSS 245/40 all around square setup.
I commute a lot more now and don't track my car so I want to switch to all seasons. I have Michelin X-Ice 3's for the winter. I'm looking to see which tire size would be best for the wheel specs.
235/40
235/45
245/40
235/45 is what I'm learning towards to have a bit more sidewall.
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      07-25-2021, 12:13 PM   #2
alohasurftoad
Drives: 440i gran coupe w/mppsk
235/45/18(26.3") taller sidewall will provide better ride, impact protection and reduce wheel gaps further. will look a pinch beefy if you don't mind.
https://f30.bimmerpost.com/forums/sh...3&postcount=29
you may want to also consider 255/40/18(26"). max size on 8.5" width, so there's tiny bit of sidewall bulge, reduces fenderwell gap with girth.
https://f30.bimmerpost.com/forums/sh...8&postcount=46
https://f30.bimmerpost.com/forums/sh...7&postcount=19
no bulge on 9" width
https://f30.bimmerpost.com/forums/sh...4&postcount=66
245/40/18(what you have now) fits optimally on 8.5", lower profile provides sharper turn-in and looks nicer, especially if you're lowered.
since you have winters, i'd actually stay with a summer such as MPS4S, however if you are definitely switching to a ultra high performance all season then i'd go with MPSAS4, ContiDWS06+, Goodyear Exhilarate
cfm56d7b5886.00
      07-26-2021, 07:22 AM   #3
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
alohasurftoad I cannot thank you enough for your reply. I ended up ordering the 235/45's so the ride is a bit more comfortable (even better for the wife and daughter). Will report back once I put more miles on the DWS06+
      07-30-2021, 07:00 AM   #4
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Alohasurf Drive drives great on the DWS06+. Nice and smooth and great over bumps. Thanks!
      08-07-2021, 02:07 AM   #5
Tallest
Tallest's Avatar
1307
Drives: 911
2011 911  [10.00]
Please post pics from side or 3/4 angle of the car on new tires. Considering same setup for winter.
      08-07-2021, 09:06 AM   #6
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Hey, this is what I have on hand
Tallest1307.00
AndrewC198910931.00
      08-07-2021, 09:22 AM   #7
Maximus92
Drives: F30, 2012, 320i
That looks awesome!
      08-09-2021, 01:41 AM   #8
Tallest
Tallest's Avatar
1307
Drives: 911
2011 911  [10.00]
Wait, this is 235/45 R18 8in rim?? This looks SO good.
Solidjake945.00
      08-09-2021, 02:33 PM   #9
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
On 8.5's. ET35
Note to self, idk if I should have put the tire shine on it. I like the matte look for I will find one that maintains that.
      08-09-2021, 07:15 PM   #10
alohasurftoad
Adam's VRT. matte, no sling, water and dust resistant.
      08-10-2021, 11:46 AM   #11
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Thanks!
      11-28-2021, 11:48 AM   #12
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Do you feel any noticeable change (decrease) in acceleration after slightly increasing the wheel diameter?
I want to do the same with my next set of tires but not at the cost of acceleration. Granted you went from 245/40 to 235/45 which is a +2.3% increase whereas I'd be going from 225/45 which would only be +1.2% so I feel like you'd be more likely to feel a difference than I would.
      12-05-2021, 03:31 AM   #13
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Honestly I have not noticed any changes. From a stop it's not noticeable and on the highway the car picks up great.
AndrewC198910931.00
      12-05-2021, 04:08 AM   #14
Maximus92
Isn't ride more comfortable on 245/40 than on 235/45? Does 235/45 have a higher or a lower sidewall than 245/40? Considering those 2 dimensions for my summer square set up (currently running stock 17), I would like a higher sidewall as well, seen 245/40 looks meaty and I like it, but I want smooth and comfortable ride. As I read most prefer 235/45 set up.
      12-05-2021, 09:58 AM   #15
alohasurftoad
245x40%=98mm sidewall
225x45%=101.25mm sidewall(oem)
235x45%=105.25mm sidewall
245/40/18 best increased performance
235/45/18 best combination of ride, bump in increased grip, slightly reduced fenderwell gap.
no need to overthink this. choose based what you desire most. either choice is fine.
Solidjake945.00
AndrewC198910931.00
      12-05-2021, 02:49 PM   #16
Polo08816
Drives: 2014 335i M Sport
235/40
235/45
245/40
It seems like the OP originally opted for a tire size that has a lower sidewall height than OEM.
If he's running 18x8.5 all around, he could also run a 255/40-18 tire which is the original sidewall height.
      12-11-2021, 01:14 PM   #17
AndrewC1989
No, the 235/45 has a larger sidewall:
https://tiresize.com/calculator/
Good to hear. I'll be getting my next set of MPSAS4 in 235/45/18
      12-11-2021, 01:57 PM   #18
alohasurftoad
FYI, 235/45/18 is typically 26.3". for some reason a MPSAS4 in 235/45/18 is 26.7". it's sidewall will be 0.2" more than a typical 235/45/18 sidewall, so it'll look quite beefy and heigtening gearing slightly more.
for some reason, many MPSAS4 tires are taller than typical for a given size, not sure why...
AndrewC198910931.00
      12-11-2021, 02:04 PM   #19
AndrewC1989
FYI, 235/45/18 is typically 26.3". for some reason a MPSAS4 in 235/45/18 is 26.7". it's sidewall will be 0.2" more than a typical 235/45/18 sidewall, so it'll look quite beefy and heigtening gearing a bit more.
That's weird, I wonder why that is. Good to know though, guess I'll have to pick a different tire.
      12-11-2021, 03:31 PM   #20
alohasurftoad
many tire reviews out there. here is a one of many
vanguard8245.50
      12-11-2021, 04:12 PM   #21
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
I wonder if it’s because of the rim protection?
      12-11-2021, 05:19 PM   #22
alohasurftoad
i don't think so. using nominal numbers, the aspect ratio is not really correct. 235x45%=105.75mm =4.16" sidewall =(4.16+4.16+18) =26.33" diameter.
if you do the math, a 235 that is 26.7" is more like a 47% aspect ratio sidewall.
maybe the mold designer partied too much the night before he made it,
