11-16-2021, 01:41 PM | #1 |
Rep 77
Lexus Wheel Alignment for BMW?
Hi my friend has a friend that works at a Lexus dealership and he offer to do my wheel alignment for $100. The machine Lexus has isnt specific to only Lexus cars right? It should be able to program to do BMWs?
11-16-2021, 02:45 PM | #2 |
Rep 193
No programming needed. Alignment has to do with adjusting the physical geometry of the suspension. An alignment lift is an alignment lift and will work for any vehicle that fits on it.
11-17-2021, 09:09 AM | #3 |
Rep 77
Great thank you.
Another question, the clamp that goes on your wheel during an alignment does it clamp onto the rim as well? I am afraid that it will scratch my new rims that I recently installed. |
11-17-2021, 10:38 AM | #4 |
Rep 193
It depends. Some grab on solely to the tire and others have contact points with the rim. I believe the ones that contact the rim typically have rubber feet to prevent scratching, but someone can correct me if I'm wrong.
11-17-2021, 12:33 PM | #6 | |
Rep 193
"Vehicle with complete equipment for normal operation with: 2 x 68 kg on front seats (seats in centre position); 1x 68 kg on 2nd row of seats; 1x 26 kg in luggage compartment (centre) and full fuel tank." |
11-17-2021, 12:52 PM | #7 | |
Rep 7,591
11-17-2021, 01:23 PM | #9 |
Rep 7,591
I'm not going to judge how important it is because i can't say quantitatively how much the weight affects the suspension geometry, I'm just saying its a consideration for OP. I assume its done that way so that with more or less weight you will still be within spec, as opposed to setting the alignment at one extreme or the other (unloaded or fully loaded) such that going to the other extreme will put you out of spec.
11-17-2021, 02:10 PM | #10 |
Rep 849
Drives: BMW 435i
I can't imagine most dealerships going through the process of weighting the seats or filling the tank with gas. I've only had one dealership alignment and they did not fill the tank or require me to do it first.
My guess is they throw it up on a machine/rack no different than any other dealership, repair garage, or tire shop. Depending on the dealership some of those other places may have more advanced alignment equipment than the dealership.
11-17-2021, 02:12 PM | #11 | |
Rep 7,591
11-17-2021, 06:09 PM | #12 | |
Rep 282
OP that price isn't bad for a dealership but if it's out of your way they're not really doing you any favors. Your local firestone will have a new hunter alignment machine and it cost around 89$ for a 1 year alignment or 180$ for lifetime alignment. |
11-18-2021, 12:50 PM | #13 |
Rep 7,591
Again I'm merely pointing this out so OP is aware, making no claims as to how necessary it is, what quantitative impact it has if it is or is not done, how likely a dealership is to do it, or whether or not OP should go to the Lexus dealer.
11-18-2021, 01:35 PM | #14 |
Rep 14
I didn't do the kg to lb arithmetic, but I don't think many shops will jack around ~500lb (?) in & out of your car. I also don't think they ask about large heavy things in your trunk which might mess their work up.
11-18-2021, 02:25 PM | #15 |
Rep 7,591
See post above. Not saying who will or wont, just sharing information and saying the procedure exists. OP and everyone else can decide whether or not this matters to them when they want to get an alignment done.
Techno 9000518.00 |
11-18-2021, 07:40 PM | #17 |
@_sunbish
281
Rep 609
Having worked for a dealer, the machine that we had was a Hunter. The software had basically 99% of the vehicles on the road, with each having all the specifics suggested/required by each manufacturer. How much weight, where to place the weight, where to adjust, how to adjust, what special tools, etc. was all available.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
11-19-2021, 04:48 AM | #18 | |
Rep 14
01-12-2022, 11:24 PM | #19 |
Great Teacher
1076
Rep 1,303
Drives: 06 e91 325ix
For bmws with trailing arm rear suspension the weights were Very important. toe changed dramatically with even a 1/2 difference.
It isn’t as critical anymore and they have specs for normal and weighted they can use now on modern cars.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
