11-21-2016, 11:44 AM | #46 |
Rep 548
Drives: 2011 E90 M3 ZCP
Is it possible to use the midpipe by itself? My 340i currently has the factory MPE (axle back).
11-21-2016, 12:53 PM | #47 | |
Rep 1,340
They both share the same break point -- the beloved dimple. |
11-21-2016, 01:12 PM | #48 | |
Rep 548
I believe the MPE requires the stock midpipe to be cut in order to be installed. I forget, as it's been a while since I looked it up. |
11-21-2016, 03:48 PM | #49 |
Rep 1,340
You are correct. There is an intentional dimple in the stock mid pipe where the cut is to take place. Our configuration shares this same break point -- i.e require the stock mid pipe to be cut at the same spot at the MPE.
11-21-2016, 03:50 PM | #50 |
Rep 548
Ah okay. So then this would totally fit! :-) Thanks for the clarification. I'll be in touch!
11-21-2016, 03:53 PM | #51 |
Rep 1,340
02-01-2017, 02:02 PM | #52 |
Rep 1,340
02-02-2017, 01:09 PM | #54 |
Rep 1,340
02-06-2017, 10:46 AM | #55 | |
Rep 48
Sounds very similar to the mppsk exhaust. Thanks in advance! |
02-06-2017, 01:42 PM | #56 |
Rep 1,340
02-09-2017, 03:31 PM | #59 |
Rep 698
02-09-2017, 04:06 PM | #60 |
Rep 1,340
02-10-2017, 10:45 AM | #62 |
Rep 1,340
Actually it's three sections of 3" .065-wall mandrel-bent T304 stainless steel with factory-matched inlet.
Appreciate the input, though! |
02-10-2017, 01:48 PM | #63 |
Rep 679
Sorry to be a negative nancy here. You're basically paying $500 + ~$100-$200 labor to have everything installed. I don't think its worth it when local muffler shops can offer the same material for fraction of the cost. Having that said, I don't disagree with AWE exhaust though. Looking to purchase one in the future.
02-11-2017, 12:18 AM | #64 |
Rep 360
We need some more videos of catless downpipe +midpipe only
2016 340I build thread : http://f30.bimmerpost.com/forums/sho....php?t=1266037
03-10-2017, 04:16 PM | #65 |
Rep 1,340
AWE Non-Resonated Performance Mid Pipe x MPE!
Equip the rumble for your 340 through an AWE dealer or direct right this way. Last edited by Josh/AWE; 03-11-2017 at 10:14 PM.. |
03-11-2017, 10:11 PM | #66 | |
Rep 698
