01-21-2019, 11:34 AM | #1 |
Rep 59
F30 msport partial brake upgrade. Still need to code?
Hi forum. I have seen several threads skirting the exact subject, but nothing definitive. I have an F30 2015 328i x drive with the Msport package. It came with the 340mm 4 piston Brembo calipers (grey) on the front and the standard 1 piston calipers with a 330mm rotor on the back. I am upgrading the rears to some Brembo 2 piston blue calipers and the 345mm rotors I found used from a parted out 335i. Will it be necessary to do a code change on the car? If so, what should the new settings be? I appreciate all the help in advance.
01-21-2019, 09:35 PM | #2 |
Rep 10,256
Please confirm ...
- Does your vehicle have M Sport brakes as an option (probably not ...)? - Front calipers are not changing - Rear rotors are 330m now; changing to 345mm - Rear calipers are 1 piston units now; changing to 2 piston blue M Sport calipers On the surface, it's difficult to tell. M Sport brakes use 370mm rotors in the front. Even with coding to specify M Sport brakes, there is a mechanical mismatch in the front: 340mm rotors in the front vs 370mm. Rear rotors and calipers are exactly what the software wants to see. When it comes to brakes, precision is always prudent. Thread of interest: https://f30.bimmerpost.com/forums/sh....php?t=1373547 |
6629matt16.00 |
01-22-2019, 06:18 AM | #3 | |
Rep 59
01-22-2019, 07:23 AM | #4 |
Rep 57
It's not necessary to code. Last week I did it on my f32, I had the single piston floating type caliper with 340mm rear rotors, and I replaced it with the blue 2 piston Brembo/345mm rear rotors, and it's perfect!
