BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Lifting a 328d xDrive
      02-07-2019, 04:11 PM   #1
TroyH
Drives: 2015 328d Wagon
Hey all,
I'm looking at picking up a 328d xDrive wagon, and am curious if there are any good options to lift them so I can shove bigger tires underneath.
I live out in the American West and will be using it to pull a snowmobile, haul bikes, skis etc, and the ground clearance isn't confidence inspiring as is. I used to have a VW Jetta Wagon that was lifted 2" which was perfect.
Thanks!
      02-07-2019, 11:56 PM   #2
cu260r6
Drives: 428i
Larger spring spacers/boosters would probably do the trick. You wouldn't need much at the spring to have a larger effect at the wheel. https://www.jegs.com/i/JEGS/555/60828/10002/-1
      02-08-2019, 01:28 PM   #3
TroyH
That's the backup plan. Curious if any company was making taller suspension setups though, or if there was a weird solution. For my Jetta, I was able to just swap stock Tiguan springs and that did the trick.
      05-18-2021, 10:58 AM   #4
TouringM3
TouringM3's Avatar
620
Drives: '18 F80 6MT / '16 F31
Hey Troy - did you end up finding or making a solution for this?
2018 F81 M3 Touring Project | Bend, Oregon, USA
Instagram: @TouringM3
      05-18-2021, 11:00 AM   #5
TroyH
Nah I ended up buying a Q5 TDI instead, was a great rig. Sold it a month or so back and got a Ram 1500 EcoDiesel -- I got bit by the snowmobiling bug, while trailers are fine, not-trailers are better
