BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > my bmw F30 bleu estoril
      06-26-2018, 08:23 PM   #287
james53112009
Drives: F30 328i
my F30 is equip with stock cic system and small 7 button control,what is your F30 year?is cic system also?
I notice your picture in dark outside the small LCD screen stay in white , and that picture your system is CIC style have not install the NBT yet ,am I right?
if I’m right , the cic could setting the 6WA small LCD stay in white background color mode right?
      07-09-2018, 04:23 PM   #288
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Hello
I was equipped with gps nbt
it is 2012
      09-14-2018, 02:10 PM   #289
mazzy960
Drives: BMW 320d Efficient Dynamics
Are these LEDs need soldering or just inserting in to the slots
Originally Posted by David Hurng View Post
nicceee always wanted this! i have it on my 7 but they only run daytime. is it possible to make all the clusters white? or is that the most u can do.
Hi David,
Could you please tell me if these LEDs can be fitted to my 2012 320d ed vehicle? It has got an extended 6WA tachometer/speedometer?
Also, I have got a problem with the daytime tacho illumination (white illumination) which has gone off (turned off) 3 days ago. It was working during the day on the 11the of September. In the evening about 9; 00 pm. I drove to my workplace - obviously, during the night it illuminates as the orange color. So on way to the workplace iI did not see any difference. But When I finished my night shift (since I work as a Night shift Pharmacist); in the morning about 8; 00 am When I turned the ignition on The white illumination of the Speedometer, rev counter, fuel gauge and temperature gauge have gone or turned off for an unknown reason. Also, the figures (numbers on these gauges don't illuminate. All other information; i.e. The temperature, clock, date, and fuels to empty miles or kilometers are shown as illuminated?
According to your knowledge, what could be the problem?
It looks like you have got great experience in the filed?
Initially, I thought that the issue might be the fuse? But again if it is the fuse problem; Orange color illumination during the night could be gone off/turned off too? Am I right? Or is there a specific separate fuse for the daytime white illumination; If so what is the fuse number?
I checked the Paper diagram inserted behind the fuse box but I could not see any fuse related to the Tachometer/speedometer daytime illumination?
Your quick reply on this matter highly appreciated?
Regards
Maz
      05-07-2019, 02:15 PM   #290
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by mazzy960 View Post
Hi David,
Regards
Maz
Hello
in my opinion you have one or two LEDs that are poorly soldered on the meter circuit board
      06-23-2020, 06:32 AM   #291
JovanUK
JovanUK's Avatar
Drives: '17 M4 F83 CP, '18 M140i SHA.
Hi david51. Amazing build on your f30, and your m235i looks amazing!
I have m140i 2018my lci2, with manual non heated leather seats. I have just bought 4 series F36 gran coupe full electric memory heated seats. WIll this be possible to retrofit correctly with everything working correct heating memory function lumbar etc? Do i need to swap over the airbags or just the pretensioners?
The driver side seat has the white module box, but on passenger side only the smaller black module. My friend says on his elec memory seats that both have white module box. will this be a problem?
Kind regards
"We at BMW do not build cars as consumer objects, just to drive from A to B. We build mobile works of art" - Chris Bangle
"If it depreciates, lease it. If it appreciates, buy it."
      06-23-2020, 07:12 AM   #292
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Kind regards
Hello
Yes it's possible
just add the cables, buy the air conditioning console with the heated buttons.
for the airbag, you can leave them for the moment but if there is an error you will have to submit yours.
For the white module on the driver's side, keep your original
      07-02-2020, 09:23 AM   #293
EliasBAM
Spain
Drives: BMW F30 '12
Hi david51 , I currently have my speedmeter disassembled to change the orange LEDs to white, but the LED area under the km / h needle I do not know how to disassemble it, it is the area on the right, it seems that there is a plastic fused to the needle and I am afraid to break it, I have seen that in another forum you have uploaded this image, could you tell me how this piece is disassembled? it's the black / transparent piece
Thank you
      07-02-2020, 11:41 AM   #294
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Thank you
just lift it slightly to remove it
      07-06-2020, 08:09 AM   #295
JovanUK
JovanUK's Avatar
Originally Posted by david51 View Post
Hello
Yes it's possible
Thanks, i have just ordered new climate display, should be here 7-14days.
I do not have a white module underneath mine atm, it is the basic manual seats non-heated. hopefully i dont need to swap airbags.
i think my current leather is in better condition though. can i swap over the leather parts? i cant see anywhere online how to do this properly.
speak soon
Jovan
      07-06-2020, 03:32 PM   #296
david51
david51's Avatar
France
538
Drives: bmw M3 F80
speak soon
Jovan
yes you can change the leather see the link here
https://translate.google.fr/translat...hp%3Ft%3D34845
      08-17-2020, 09:40 AM   #297
omie
omie's Avatar
Netherlands
26
Drives: 2015 /// 328i
Hi David, beautiful car, beautiful interior! My project now is also to change the lights exactly like you did. I see you have changed almost everything, also the door lock button, the airco control panel, the gearknob, all the buttons like sport mode, idrive controller and so on. Can I ask you 1 favour please? Can you maybe make a list with all the different kind of LEDS I need for all these places? Because im also going to change every orange LED to the white and blue like you did. But im not sure which LEDS I need. I would appreciate it very much
      08-17-2020, 03:57 PM   #298
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Here the original LEDs for radio / door / wheel idrive etc ...
http://www.ebay.fr/itm/172013762759?...%3AMEBIDX%3AIT
I have put this model is the most powerful
http://www.ebay.fr/itm/170651032163?...%3AMEBIDX%3AIT
http://www.ebay.fr/itm/140563451521?...%3AMEBIDX%3AIT
led to the counter and air conditioning
http://www.ebay.fr/itm/191349287875?...%3AMEBIDX%3AIT
      08-17-2020, 05:01 PM   #299
omie
omie's Avatar
Netherlands
26
Nice thank you for the quick response! So actually only 2 different type of LEDs in the car, the 1206 and the 3528. So I'll buy the 1206 white and blue colours, and only white 3528.
But I see you have the CD insert place, and volume button also blue colour. Is that also 1206 blue LED. And also the foot lights, iDrive button, all blue, but also 1206 blue?
And all the small buttons, like steeringwheel, windows, doorlock button, is all 1206 white yes?
      08-17-2020, 05:34 PM   #300
david51
david51's Avatar
France
538
Drives: bmw M3 F80
For the steering wheel controls they are even smaller
you need the 0603 models
https://www.ebay.fr/itm/Lot-de-10-pc...-/253428065877
      08-18-2020, 06:36 AM   #301
omie
omie's Avatar
Netherlands
26
Ah okay thanks! Are there any more different types of LED we need? I'm going all in, changing every ugly orange to white in the whole car
      08-18-2020, 07:06 PM   #302
david51
david51's Avatar
France
538
Drives: bmw M3 F80
normally no need other led
      08-19-2020, 03:22 AM   #303
omie
omie's Avatar
Netherlands
26
Great thanks for the info! I ordered everything, hopefully wont be very difficult with the very small LEDs.
      08-23-2020, 10:20 AM   #304
omie
omie's Avatar
Netherlands
26
David, thanks for all the information on the LEDs. I started out doing the most difficult ones in my eyes, the center airco panel and radio. I messed up the ambient light around the airco, the LEDs dont work there anymore, I need to recheck. Here is a picture of work in progress.
https://ibb.co/ZHNVWCz
I miss 1 thing, the 3528 LED, but the blue version. We need this for the footlights. Do you have any link, the brightest one you buy maybe? I found one is 1400 mcd blue. THIS ONE
You think this LED will work, or you buy another one? I appreciate it, thanks!
      08-23-2020, 01:50 PM   #305
david51
david51's Avatar
France
538
Drives: bmw M3 F80
cool
the best is to keep the models 3528
https://www.ebay.fr/itm/20x-Led-CMS-...EAAOSwRs1dwDnd
      08-23-2020, 03:26 PM   #306
omie
omie's Avatar
Netherlands
26
Thanks for the link!
d2un2117.50
      09-12-2020, 09:52 PM   #307
hokiedood
Drives: 2016 BMW 340i
2016 BMW 340i  [0.00]
What lip is that?
2016 340i | EB | M Sport
      09-13-2020, 10:33 AM   #308
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by hokiedood View Post
What lip is that?
https://www.perl-carbon.de/bmw/spoil...0/31-m-paket-5
