04-19-2021, 08:59 AM | #67 | |
Rep 849
Drives: BMW 435i
One evening an add popped up in the middle of the my Autotrader search for 235/240's for the car I know own. Not only was it manual, but RWD, but it also had my "must have" packages, plus a couple of other good ones thrown in. I was shocked when I noticed the add was for a dealership about 30 miles away. The rest is history
04-19-2021, 11:54 AM | #68 | |
Rep 20
04-19-2021, 03:01 PM | #69 |
Rep 919
I pieced it together from what I had because I wanted it so bad!
Bimmercode I think the FEM Cluster/advanced/that three letter acronym I vaguely recall seeing Reverse the two SPA settings from their current aktiv or 'nicht aktiv.' Someone in one of the threads tried it...he might have documented better...or maybe you will? Glad I did it...hated being told I was in the wrong gear all the time!
04-19-2021, 03:27 PM | #70 | |
Rep 20
04-19-2021, 08:10 PM | #71 |
Rep 919
Yes, it still suggest the gear to go into, but it also shows the gear you're in first...in a larger font. Makes me feel partially 'right' from the car's point of view.
04-19-2021, 09:15 PM | #73 | |
Rep 1,510
Edit: looked up the SS kits on Turner, looks like the Turner branded one is for F30s/F32s up to 2015 (pre-LCI) and doesn't include the 340i, while the UUC one is for F30s from 2012+ including 340i. Is is safe to assume that if it fits an F30 335i or F32 435i then it will fit the 340i as well? I thought the drivetrain stayed the same through the LCI Last edited by im_an_alien; 04-19-2021 at 09:28 PM.. |
04-20-2021, 01:16 AM | #74 |
Rep 49
2018 340i, 6MT RWD. I knew this was the last year to get one fresh off a lease, so I did it. Still haven't seen another one--and if I do I dead-ass might buy that, too.
[IMG]https://f30.bimmerpost.com/forums/pi...ictureid=80063[/IMG]
2018 340i
04-20-2021, 07:29 AM | #75 |
Rep 259
Dang, in front of Neuschwanstein, that's a winner! (unless it is Photoshopped)
Garage:
2020 F32 440i 6MT 2018 Mazda 3 6MT 2013 Mazda 3 6MT 2008 Honda Oddyssey |
04-20-2021, 04:16 PM | #76 | |
Rep 20
04-20-2021, 04:37 PM | #77 | |
Rep 20
04-21-2021, 05:28 AM | #78 |
Rep 919
You reverse those two. If aktiv, make it nicht aktive, and vice versa.
04-21-2021, 01:06 PM | #79 |
Rep 20
They are three SPA settings. I'll attach a screenshot. Which ones to make aktiv and not aktiv? Could you possibly check?
04-21-2021, 01:16 PM | #80 |
Rep 919
SPA
SPA IST I didn't touch 'kombi select' When you get past these, you'll see that each one 'labeled' enable, will be either aktiv or not. Just reverse those two. You're very close...let me know it worked...and if you could document where you're at better than me, others would appreciate it. I'm sorry...I was so eager to fix this babysitter, I didn't write down the steps.
04-21-2021, 05:23 PM | #82 |
Rep 286
Drives: 2014 335i 6MT MSport
See signature. Ordered the car built to my spec.
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE 2001 E53 M54 5MT peeling green/black, well-optioned |
04-25-2021, 06:49 AM | #85 |
Rep 919
As requested--I've doublechecked what I did to get the gear you're in to show (as well as the suggested gear)--see pic above.
Using bimmercode: Instrument Cluster/expert mode/ FZG_Ausstattung SPA_enable : nicht aktiv SPA_ist__gang_enable: aktiv SPA_Kombiselect_DISABLE: Nicht aktiv
Alvin Mpower389.50 |
04-25-2021, 07:31 PM | #86 |
Rep 596
Montana based '17 440x drive with a MT -- a unicorn. Estoril, M-sport, track handling pkg, and literally every other option. Found it in Oregon as a lease return CPO with only 22K miles
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option |
04-25-2021, 08:01 PM | #87 |
Rep 1,510
In case any of you three pedal people were wondering, a short shifter can be installed without removing the exhaust or lowering the transmission. Requires lots of patience though. Feels great, needs more effort to shift and you get more feedback through there shifter. Mine is centered but the knob is a bit canted to the left, doesn't bother me much. Keeping it at stock height for now. Double posting here for relevance
