03-19-2013, 02:42 PM | #199 |
Rep 265
Drives: 340i M Sport
You gotta join our BMWCCA chapter (River City Bimmers)! Our website is down for maintenance, but we have a Facebook page. As for tuning, not sure, but for general service most people suggest memphis motorwerks.
2016 340i M Sport Alpine White, BMS Intake, JB4 Beta
2012 335i Sport Line, RIP |
03-19-2013, 04:25 PM | #200 |
Rep 556
Drives: 2012 BMW 335I
Hey, what are the guide lines for E85? I found a station near where I am at. Is it a mixture of E85 I do with 91 octane?
Or can I mix 100 Octane and E85? Or should I not do that? What are the guidelines? |
03-19-2013, 04:47 PM | #201 | |
Rep 1,997
The JB4 crew can help answer specifics. There is some issues with our cars not being set up for E85 from the factory, E85 is pretty corrosive and eats up seals if I recall correctly, so some tweaks probably need to be made. I'm just speaking from information that I've stumbled upon so don't consider me the expert in this. Still learning myself. |
03-20-2013, 01:10 AM | #203 | ||
Rep 665
03-20-2013, 09:50 AM | #205 |
Rep 665
Just curious, do you know if that car is an N55 or an N54? Any idea what the track's density altitude was at the time?
That's a great ET for the mph; obviously on slicks or ultra sticky DRs. Would be curious to see the full mod list. On a track a car like that stands a chance to put solid distance on an E60 M5 out of the hole, but outside of having slicks on a track, that car from roll wouldn't "walk" an E60 M5...trap speed is telling....if the car does in fact have full slicks that does lower mph just a shade. |
03-20-2013, 11:50 AM | #206 | |
Zooombie attaaack!!
136
Rep 1,179
03-20-2013, 12:48 PM | #207 | |
Rep 1,997
03-20-2013, 02:08 PM | #209 | |
Rep 1,575
Example:** V10 300wtq 10:1 ratio = 3000 multiplied wheel torque I6TT 440wtq 7:1 ratio = 3080 multiplied wheel torque So yes the M5 could rev higher and thus stay in a lower gear (10:1) giving it better torque multiplication. However since the N55's torque is so much more ( ~50% more in the low & mid range) even at the higher gear (7:1) the multiplied wheel torque for both are equally matched...now add the fact that the load is 500lbs less on the 335i (3590 vs 4090) and the 335i should accelerate faster with the same amount of multiplied torque... ** The "wtq" figures are relatively accurate, however the gear ratios used are example only, used to illustrate the point that an engine with more rpm isn't always faster; rpm, gearing, torque, and weight all matter. |
03-20-2013, 02:49 PM | #211 | |
Rep 1,997
His install guide: http://www.n54tech.com/forums/showthread.php?t=13171 The 'guide' only touches on the new connections and doesn't mention the old ones, so I'm guessing you do not connect it as you do not connect it for Stage 1. I'd double check to be sure though as I haven't seen anything specifically stating you do or do not for stage 2 and this is only ancillary evidence that you don't given it's not used for stage 1 and stage 2 doesnt specify that you need to.... |
03-20-2013, 02:49 PM | #212 |
Rep 1,975
Leave it
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
03-20-2013, 04:57 PM | #213 |
Rep 1,339
first off stop trolling the hell out of this thread about what car is faster no one cares.. Just installed stage2 a lot faster than stage1 loving it
2013 F30 335i xdrive | Estoril Blue | Black Dakota Leather | Aluminum Hexagon trim | M-Sport | Cold weather | DHP | Premium package | Tech package | Harmon Kardon | PDC | Rearview Cam | IND Painted reflectors | BMW performance grills | JB4 stage 2 | ER downpipe | BMS Intake | H&R sport springs
03-20-2013, 06:15 PM | #214 |
Rep 265
Are you just running Map 1?
03-20-2013, 06:51 PM | #215 |
Rep 1,997
How difficult was the install? The other stage 2 videos were a bit iffy but seemed like you could mess something up if you didn't get it right. I'm mildly afraid of tinkering with those wires if I'm not 100% sure...
03-20-2013, 07:01 PM | #216 |
Rep 1,975
Install was SO easy if you go slow and read the pdf. I was nervous at first too but once its all there laid out in front of you, its cake. But my harness also already had all the extra wires so that helped.
03-20-2013, 07:01 PM | #217 |
Rep 1,339
If your not handy at all what so ever deff have someone whose familiar with installing burger tunes do the install. I had my friend install it took about 20 mins. Car is really fast now, I lose traction easily now even with the xdrive, it still needs to adapt though put like 25 miles on the car with stage2 installed. I suggest hooking it up to the laptop through the usb to confirm what map you are in.. The steering wheel controls don't give you a confirmation on what map your in.
03-20-2013, 07:10 PM | #218 | |
Rep 1,997
It doesn't look "difficult" as you're only connecting a few wires, I've installed car amps and whatnot that are more complicated than this, but I wasn't messing with a $55k+ car's ECU either. My only real concern is ensuring I'd tap into the correct wires more than anything else. I presume loading the correct firmware isn't difficult. That and I figured without DP or E85, Stage 2 would be virtually identical to Stage 1. |
03-20-2013, 08:34 PM | #219 |
Rep 1,975
the pdf on the bottom of the first post here has the instructions... http://www.n54tech.com/forums/showthread.php?t=18588
03-20-2013, 09:37 PM | #220 |
Rep 1,339
