BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F80 Cluster installed in my F30
      01-26-2024, 06:52 AM   #67
Revoltos
Revoltos's Avatar
62
Drives: BMW F30 335i
1, You will only get static rev limit lights on a non M car.
2, MoeTE87 has screen shotted the coding for the HUD side of things earlier in this post.
3, M cars don't have front fogs so there is no option to indicate your front fogs are on in the cluster.
4, You need to make sure that the M-sport chassis options are not switched on in your I-drive as it will display that instead of drive mode (efficiency drive graphic) in the cluster.
      02-07-2024, 03:43 PM   #68
SuspecTARX
Drives: BMW F30 330d
Originally Posted by Revoltos View Post
What does that coding enable moeTE87?
SuspecTARX, what car did you install the F80 cluster in mate? Your rev counter rev limit lights are showing way more segments than does.
Hey, sorry haven't visited the forums in a while
My f8x cluser is installed in my 330d.
The rpm leds on mine are just coded like that, they don't move or anything, had them coded differently (think it was 1 yellow and 2 red) at one point as well, changed it while trying different coding options, stopped playingaround with it and just stayed like that
      02-07-2024, 04:03 PM   #69
SuspecTARX
Originally Posted by ClearlyB58 View Post
@MoeTE87
Do you know if it’s possible to —
A. Move the shift light indicator in the tac and HUD to have orange start at 5.5k and the two reds at 6&6.5k
B. An easier way to access the M HUD display. Currently I have to manually go into display settings to select the option.
I have an answer for the question about moving the shift lights, unfortunately at this point it doesn't seem possible, me together with BimmerRetroLA have tried changing a lot of different coding options on my f8x cluster.
We wanted to change the scale of the RPM gauge it self, how many of the shift lights are lit up and the scale of the temp gauge, sadly no luck The reason why we wanted to make these changes was because my diesel has a max of 6k RPMs on my old cluster and the redline starts at 5k RPM, as well as the temp gauge is 100 C in the middle for my old cluster and this one is about 120 C.
The idea was to change the scale that the RPM is displayed in, so that where the f8x cluster has 8,5k RPM it would be 6k RPM instead and so on, if this would have been successfully done I would then order custom gauge faces for the RPM gauge and the temp gauge so that it shows correctly again. At the moment all is displayed correctly, it's just that everything after 5,4k on the gauge is useless for the diesel engine XD
Hopefully can make it work how I want sometime in the future with some sort of adapter or something
Only scale that we could change with coding was the gas tank size to a diesel one so that the fuel gauge shows correctly, sucks that they don't have the options as easily available for the other gauges as well
      04-29-2024, 07:38 AM   #70
MSPORT62
MSPORT62's Avatar
101
Drives: Bmw 335i
2013 BMW 335i  [8.78]
Originally Posted by SuspecTARX View Post
To be honest it's not that different from the regular F3x cluster with extended scope aka 6WA, but for me it's the little things that are different and make it look better for me personally.
1)The digital speed is displayed like 2 or 3 times bigger than in an F3x cluster and it also seems to refresh much faster.
2)Design of the gauge faces and the digital instantaneous consumption display looks nicer, more modern imo
3)Cut off and slightly differently shaped rings around the gauges look nicer
4)The ///M logo under the speedo looks much nicer than totaly unused space like the regular cluster
5)White backlight with the red speedo needles are also nice, but might be more tyring for your eyes at night than the red backlight, although you can turn down the brightness to a pretty low amount tbh
I probably missed some things, but for other people it would probably be different anyways
Why are the led higher than the original posted pic from te87
      04-29-2024, 07:39 AM   #71
MSPORT62
MSPORT62's Avatar
101
Drives: Bmw 335i
Can u code the cluster on BimmerCode like you could with 6wa
      04-29-2024, 07:44 AM   #72
MSPORT62
MSPORT62's Avatar
101
Drives: Bmw 335i
I also have manual so will it tell me what gear to go in like my current cluster or tell me the gear it’s in like f80 or will it show nothing
      05-19-2024, 07:24 PM   #73
Smerke
Smerke's Avatar
Drives: 2014 335i M Sport
cluster virginizer NY
I know im a little late but what are the chances that you can connect me with the guy in ny that virginized your cluster?
Originally Posted by MoeTE87 View Post
Update below:
For the longest time I have been wanting to change up my cluster and wasn't sure which route to take. Haven't really been a fan of the 6WB as I feel it is too much in your face and looks pieced together with not a lot of info shown..just my take.
I just so happen to browse these forums and some one with an F30 had an F80 cluster installed. I really liked the way it looked and it was def an OEM+ mod that really changed the interior look. I reached out to the guy (codingdynamics is his handle on Instagram) and he gave me the info of the coder in NY that could virginize the F80 cluster and then code it to my car.
I went on ebay and found a MY2018 F80 cluster in near perfect condition. To my surprise, the clusters are pretty cheap. I paid $200 for it shipped to the coder in NY.
He virginized the cluster same day. He charged me $200 to virginize it then another $150 to code it to my car. So I am all in $550 for it. The guy who did the coding was very knowledgeable and very quick to respond when I had questions.
Thoughts after driving with the new cluster over a week:
I really like the way it looks, especially at night. I was getting tired of looking at the same cluster over the years with nothing special to look at. OEM one is simple, but almost too simple and dated. Some people love the classic look but I want to enhance my driving experience and not look at a cluster that I have been looking at for a long time anymore.
My HUD still works and it is awesome as I can see the RPM's move and the speedo is still in tact. The only down side with it all is the "P" for parked does not show up but everything else does. Would need an expensive module to get that to work and the guy even said, if I were happen to get the XHP tune, it will show up. Still debating on that.
Final thoughts:
I love the way it looks, really transforms the interior, however..for $550...to me, that is a little steep. Wish I knew how to virginize clusters and code. I would say this would be a great deal at $400. But all in all, I am very pleased with it.
A few pictures:
My original cluster ^--
F80 cluster ^--
UPDATE 3/18/2023:
Last week I purchased the F80 to F30 cluster adapter from Bimmer ECU Solutions. LINK: https://www.bimecu.com/f80-cluster-retrofit-adapter
Cost was $300 for the adapter then about another $26 for shipping.
- Note: Once you get this adapter installed, you will need to code it to your car. I have provided documentation how to do that below.
I reached out to my coder (you can find him on Instagram: codingdynamics) a few days ago and he sent me a detailed things to code within EXPERT mode under the instrument cluster part of Bimmercode.
Here is a list of things that need to happen if you already have the F80 cluster coded to your car and bought the F80 cluster adapter after the fact:
Additional pictures after getting the adapter coded correctly. Which was very simple. Very happy now that I have the P, R, N and D displayed on the F80 cluster. Finally can call this project complete!
Don’t hesitate if there are any questions about this and the process. Happy to answer!
Thanks!
      05-21-2024, 01:40 PM   #74
Taku10
Drives: 18' BMW 340i
Off topic, but I am proud to be the new owner of MoeTE87 former 340i! The M3 cluster works like a dream and looks awesome. It’s a really nice touch!
      07-11-2024, 07:55 AM   #75
phoenixorion
phoenixorion's Avatar
Drives: 2018 BMW F30
2018 BMW F30  [8.50]
Hello, I was able to follow the thread and get the F80 cluster working on my F30 MT. But the font and details below the dials (tacho) is just like the F30. Can someone direct me to the correct fields to be coded to get the F80 font. As mine is a MT I did not install the adapter.
      07-16-2024, 05:59 AM   #76
MSPORT62
MSPORT62's Avatar
101
Drives: Bmw 335i
I got it done by @codingdynamics on ig, he also did the coding
      07-30-2024, 06:31 AM   #77
MarioZuwi
Drives: BMW F30 340I
I don’t know if this will help anyone but I managed to get my gears working, my rev limiter working, with no fault codes on dash.
See me giving it some in the video below after I installed my new f80 cluster 🫡
If you got any questions on how I’ll try my best to help
https://jumpshare.com/v/B8ectSRWpkKOIwNM4rLU
      08-15-2024, 07:38 AM   #78
SuspecTARX
That's awesome man! I am sure that a lot of us would want to code it in in to work like yours, so if you could share what you've done with us, that would be greatly appreciated!
      08-28-2024, 08:03 AM   #79
phoenixorion
2018 BMW F30  [8.50]
Awesome work dude. Where did you buy the adapter which shows the gear info in the cluster?
      09-14-2024, 07:29 AM   #80
SuspecTARX
He doesn't have any adapter as far as I've read from his posts.
If you have a manual gearbox I believe it will show the gears without the adapter or maybe you need XHP for them to show, I am not 100% sure as I have an automatic myself.
For an automatic you can code the cluster as a manual and it will show gears 1-8 with the shifter in manual or sport, in drive it will not show anything (no D), P won't show, R and N will show when selected.
      09-17-2024, 01:34 PM   #81
Cpark14
Cpark14's Avatar
Drives: 2016 340i xdrive 6MT
Love the F80 look but if you want even cheaper easier option, it’s not too hard to change the LEDs on the og cluster for the F30 all you have to worry about it getting the needles lined up correctly and that was the worst bit by far. These LEDs cost me $15 and all I needed was a sauder and tweezers.
      09-17-2024, 02:04 PM   #82
oem.plus_440gc
oem.plus_440gc's Avatar
413
Drives: 2019 440i XDrive GC
Likely going to be parting out my F80 cluster/adapter in the next month or 2 if anyone is interested, hmu.
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
      09-17-2024, 05:11 PM   #83
phoenixorion
2018 BMW F30  [8.50]
Yeah, mine’s manual transmission and it does not show the gears. Do you know who can do the coding? I don’t have XHP.
      09-25-2024, 07:11 AM   #84
SuspecTARX
BimmerRetroLA helped me with the coding when I first got the cluster, you can find him on Instagram or Facebook.
I am fairly certain that it's just a matter of some coding and you should be able to see them without the adapter or xhp as I don't have those on my automatic car
      10-08-2024, 04:08 PM   #85
armenh7
Drives: 2017 340i
Does anybody know how to code out the shift lights? They are all red starting from 5000 rpm and it doesn't look good.
      10-08-2024, 04:09 PM   #86
armenh7
Drives: 2017 340i
SPA_IST_GANG_ENABLE: nicht_aktiv (00) -> aktiv (01)
      10-08-2024, 04:10 PM   #87
armenh7
Drives: 2017 340i
These are all the differences between F30 and F80 cluster coding.
• BMW_LOGO: ag (00) -> M3 (06)
• DIG_KVA_BEREICH: 20_l/100km (14) -> 30_l/100km (1E)
• HUD_LOGO: wert_01 (00) -> wert_02 (06)
• KL_PREDRIVE_F51_DTC_SCHRIFT: nicht_aktiv (00) -> aktiv (01)
• DSC_ENABLE: nicht_aktiv (00) -> aktiv (01)
• M_DRIVE_BLINKFREQUENZ: wert_02 (00) -> wert_01 (06)
• SPA_ENABLE: aktiv (01) -> nicht_aktiv (00)
• SPA_IST_GANG_ENABLE: nicht_aktiv (00) -> aktiv (01)
• ALLRAD: allrad (01) -> kein_allrad (00)
• M_VARIANTE: ag_variante (00) -> motorsport (01)
• VZA_ENABLE: aktiv (01) -> nicht_aktiv (00)
• BR_KENNUNG: f30 (04) -> f80 (0B)
• TACHO_HUD_HYSTERESIS: wert_01 (00) -> wert_02 (02)
• SU_SW_DRDY_TIMEOUT: aktiv (01) -> nicht_aktiv (00)
• SU_SW_DRDY_ALIVE: aktiv (01) -> nicht_aktiv (00)
• SU_SW_DRDY_APPL: aktiv (01) -> nicht_aktiv (00)
• SU_SW_DRDY_2_TIMEOUT: aktiv (01) -> nicht_aktiv (00)
• SU_SW_DRDY_2_APPL: aktiv (01) -> nicht_aktiv (00)
• DISP_DCRN_ASST_APPL: aktiv (01) -> nicht_aktiv (00)
• MOST_LISTE_N_V_EMPFANGEN: aktiv (01) -> nicht_aktiv (00)
• CTR_DISP_M_SYS_TIMEOUT: nicht_aktiv (00) -> aktiv (01)
• CTR_DISP_M_SYS_ALIVE: nicht_aktiv (00) -> aktiv (01)
• CTR_DISP_M_SYS_APPL: nicht_aktiv (00) -> aktiv (01)
• ST_MDRV_2_TIMEOUT: nicht_aktiv (00) -> aktiv (01)
• ST_MDRV_2_ALIVE: nicht_aktiv (00) -> aktiv (01)
• ST_MDRV_2_APPL: nicht_aktiv (00) -> aktiv (01)
• TNK_FILTER_STEIGEND: 90_liter_h (66) -> 150_liter_h (AA)
• TNK_FILTER_FALLEND: 90_liter_h (66) -> 150_liter_h (AA)
• TNK_RW_VERBRAUCH: 8l_100km (10) -> 10l_100km (14)
• KI_PIA_ANALOG_RW_KVA: aktiv (01) -> nicht_aktiv (00)
• KI_PIA_M_SPORT_DIGI_TACHO: nicht_aktiv (00) -> aktiv (01)
• HUD_PIA_M_SPORT: inaktiv (00) -> aktiv (01)
• FDS_MENUE_TEXT_1: menue_3 (01) -> menue_4 (02)
• FDS_MENUE_SIGNAL_1: menue_3 (05) -> menue_4 (04)
• FDS_MENUE_TEXT_2: menue_3 (02) -> menue_4 (04)
• FDS_MENUE_SIGNAL_2: menue_3 (04) -> menue_4 (03)
• FDS_MENUE_TEXT_3: menue_3 (04) -> menue_4 (06)
• FDS_MENUE_SIGNAL_3: menue_3 (03) -> menue_4 (07)
• FDS_MENUE_TEXT_4: menue_3 (06) -> menue_4 (0F)
• FDS_MENUE_SIGNAL_4: menue_3 (07) -> menue_4 (0F)
• FDS_MENUE: menue_3 (03) -> menue_4 (04)
      10-08-2024, 04:17 PM   #88
armenh7
Drives: 2017 340i
Do you recall how to restore the shift lights to be 1 yellow and 2 red?
