BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > code 1B5302
      03-19-2020, 08:40 PM   #1
Tatts4278
Drives: 2013 f30 328i x drive
code 1B5302
anyone have any clue what this code means.
it says terminal 15N_2 no voltage. if anyone knows please let me know I d ok nt want to get robbed at the dealership. however If i do pay for a diagnosis they have to give me the printout right ?
thanks.
stay healthy
      03-20-2020, 06:40 AM   #2
dmaxdmax
dmaxdmax's Avatar
Drives: 2016 M235i 6-spd
https://bmwfault.codes/
There were a number of alternative 'translations' for this code, all dealing with a short circuit to ground.
If you don't have a good led flashlight, I'd get one. And although I have a multimeter, I never really took the time to learn how to use it for other than reading voltage, but you can get one for $20 and spend some time learning/hunting.
Also...other than reading a code, what symptoms does your car have? Is your cel on? Is it running poorly?
https://bmwfault.codes/XMLDiagView?d...MANQA1ADAANAA=
'92 325i, '99 328i, '16 340i, '16 M235i all manuals
dmax on FB
My last pre-covid standup set
      03-20-2020, 08:16 AM   #3
IK6SPEED
Drives: BMW M3 / AH3
thanks.
Simple rule when it comes to BMWs.
If you have to ask what a fault code means, then you are over your head.
Have a professional deal with it.
kpgray340.50
      03-20-2020, 09:19 AM   #4
cray101
Drives: 2017 340i
Super helpful response there...Him simply asking what it means is not the same as him asking how to fix it. If he wants to try to educate himself so that when/if he does have to take it to the dealer he can have a better understanding of what is required to fix, and an idea of what the cost may be to do that repair. Isn't that kind of the point of these forums?
jh_f301316.00
Billfitz9072.50
Boznien471.00
      03-20-2020, 09:48 AM   #5
jh_f30
jh_f30's Avatar
Drives: 2021 X3 M40i
Par for the course.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
Billfitz9072.50
      03-20-2020, 09:51 AM   #6
IK6SPEED
A simple Google search would have provided an answer to what the fault meant without a delay of half a day from his posting.
His wording of the stealership further defines his level of expertise.
      03-20-2020, 10:12 AM   #7
cray101
Drives: 2017 340i
We all have to start somewhere, dude. I'm sure there was a point where you weren't as well versed in all things BMW as you are now.
Billfitz9072.50
      03-20-2020, 10:16 AM   #8
IK6SPEED
1 big difference.
I was willing to use a simple forum search and Google, both which return results on the initial question.
I wasn't waiting for someone to spoon feed me.
Furthermore, if one reads the code meaning and what it applies to, it's nothing a newbie should be dealing with unless you want to destroy your DME.
So it actually was the correct answer.
      03-20-2020, 10:19 AM   #9
Tatts4278
yes you are right I dont know much I do have other codes and I would love to be able to fix it myself however I cant and am going to the dealership today and dont want to get robbed. if I pay for the diagnosis do they have show me it ?
there are short cut to ground codes.
battery is good.
vanos soleniod inlet and outlet show short circuit to ground or earth.
auc sensor as well
like I said just want to make sure l have an idea of what's going on.
thought it might be a relay
or a wire.
Google doesn't tell you everything I have been reading lots of searches on everyrhing related. not sure why you mentioned a flashlight.
car still starts bur shows drivetrain malfunction. I also tried to install ista+ into an old laptop but it didnt work to see it I could fix the issue. so yes I'm biting the bullet. and taking her into the dealer today. at 1. thanks for the responses.
stay healthy
      03-20-2020, 10:21 AM   #10
IK6SPEED
Par for the course.
About as helpful as the post you made immediately prior to the one above.
Btw, I just Googled "BMW 421336". Google is my indy mechanic of choice.
      03-20-2020, 10:32 AM   #11
Tatts4278
1 big difference.
I'm not asking you to spoon feed. me. I learn a lot from these forums. I also see the arrogance in people as well.. feel free to google it. it took me lots of searches to find out the code for 15n short circuit into ground could be as simple as ignition being an issue. you may think I'm trying to be spoon fed the answers however I research this stuff all the time and I love my car and would fix it myself If I could. when I ask a question. and say any help would be appreciated that's all I'm asking for. believe me I have downloaded pdfs and mechanical guides for the N20. and fear the timing. chain guide curse happening for these engines. you have your opinions I have mine. regardless of my mechanical skills.
stay healthy
      03-20-2020, 10:36 AM   #12
IK6SPEED
1 big difference.
If you have really read these forums, you find weekly threads from people who have turned a minor issue (or no issue) into a major issue by thinking they can code their car.
When you get to the DME coding, that is far beyond most members.
And if you cannot find the error code meaning, is well beyond your abilities unless you want to make your costs exploded like the Covid19 infection rate.
      03-20-2020, 10:36 AM   #13
dmaxdmax
dmaxdmax's Avatar
OP, I agree you (or most of us) shouldn't be messing with the DME, but I mentioned flashlight so you could look to see if there are any wires you can see that are broken or rubbing against something.
Often, not always, voltage issues can come down to a loose/corroded connection. Or, if this fault showed shortly after you did something else on the car, it can narrow your search down...and sometimes you find something even if you don't know anything about cars.
Good luck at dealer. Let us know what it turned out to be.
dmax on FB
      03-20-2020, 10:45 AM   #14
Tatts4278
1 big difference.
only codes done to it where bimmcode codes for mirrors. and unlocks I wanted insta+ for diagnosis only not insta p. rhis all happened after thermostat housing was changed and the oil was changed. a week later the drivetrain malfunction showed up. I just miss my car. if we didnt love these cars we wouldn't be on here.
lol to the covid 19 reference. I have to get my notifications setup on here so I can respond more promptly.
stay healthy
      03-20-2020, 11:13 AM   #15
jh_f30
jh_f30's Avatar
Par for the course.
Not to mention the link I provided right before that pertaining to a similar issue/resolution in the F10 forums.
Also, I don't consider 22 hours beforehand to be "immediately prior".
      03-20-2020, 03:49 PM   #16
Tatts4278
back from dealer.
Par for the course.
the tech noted "need to start with the integrated supply module. if that does not fix the issue it could need dme as well . then they told me how my timing chain will need to he replaced and a possible bill of 9k US dollars to fix the whole thing. the service manager was not enough to show me the location of both parts. what a day.
stay healthy
      03-20-2020, 06:09 PM   #17
dmaxdmax
dmaxdmax's Avatar
Just know what the warning signs of a timing chain going are and don't worry about that bill just yet...and the 'integrated supply module' sounds like a battery.
Not sure if you're familiar with realoem.com and I'm sure you can get to the dme supply module with help from the TIS. I think shops will frighten you into saying 'DME' so you're then grateful when it's only $500 to replace a hard to get to $50 battery.
dmax on FB
      03-20-2020, 06:15 PM   #18
Tatts4278
ok do you mean battery in dme ? as for as the battery itself for car it's good. I'm looking into my gfs mechanic eventually doing the timing stuff cause the body is in awesome shape. and as mentioned before I am a rookie. but if I can fix it I will. tg i have a Silverado I can drive as well.
stay healthy
      03-20-2020, 06:47 PM   #19
dmaxdmax
dmaxdmax's Avatar
I'm 'guessing' that the supply module is a fancy name for a battery, but it might be some sort of transformer? See if something comes up in realoem under engine electronics.
Here's 'a' supply module under vehicle electric (in my car, not yours)...but I bet you have something comparable.
Not sure how pricey it is to 'guess' that the tech's guess might be right...but hope this gets you closer to finding out.
https://www.realoem.com/bmw/enUS/sho...diagId=61_5467
dmax on FB
      03-20-2020, 07:12 PM   #20
Tatts4278
Not sure how pricey it is to 'guess' that the tech's cguess might be right...but hope this gets you closer to finding out.
https://www.pelicanparts.com/More_In...BF30&DID=16975
this is the part. and if this doesnt work they say its DME. they wanted 385 alone. to replace that $123.00 part.
stay healthy
      04-16-2020, 09:45 PM   #21
Tatts4278
sort of resolve.
https://www.pelicanparts.com/More_In...&DID=16975
well different dealer said it was a bad ground wire. and then three days later when their tech came back to work on my car they called me and told me there is a hard fault in the icm. so after 2 hours Alberto diagnose. its going to be 2650 to replace icm. and problems should all go away.
stay healthy
      09-13-2024, 06:28 PM   #22
f30_kh4n
Drives: bmw f30
Did you find what the problem was?
I have the same issue doesn’t say anything
