01-26-2024, 06:52 AM | #67 |
Rep 287
1, You will only get static rev limit lights on a non M car.
2, MoeTE87 has screen shotted the coding for the HUD side of things earlier in this post. 3, M cars don't have front fogs so there is no option to indicate your front fogs are on in the cluster. 4, You need to make sure that the M-sport chassis options are not switched on in your I-drive as it will display that instead of drive mode (efficiency drive graphic) in the cluster. |
02-07-2024, 03:43 PM | #68 | |
Rep 10
My f8x cluser is installed in my 330d. The rpm leds on mine are just coded like that, they don't move or anything, had them coded differently (think it was 1 yellow and 2 red) at one point as well, changed it while trying different coding options, stopped playingaround with it and just stayed like that |
02-07-2024, 04:03 PM | #69 | |
Rep 10
We wanted to change the scale of the RPM gauge it self, how many of the shift lights are lit up and the scale of the temp gauge, sadly no luck The reason why we wanted to make these changes was because my diesel has a max of 6k RPMs on my old cluster and the redline starts at 5k RPM, as well as the temp gauge is 100 C in the middle for my old cluster and this one is about 120 C. The idea was to change the scale that the RPM is displayed in, so that where the f8x cluster has 8,5k RPM it would be 6k RPM instead and so on, if this would have been successfully done I would then order custom gauge faces for the RPM gauge and the temp gauge so that it shows correctly again. At the moment all is displayed correctly, it's just that everything after 5,4k on the gauge is useless for the diesel engine XD Hopefully can make it work how I want sometime in the future with some sort of adapter or something Only scale that we could change with coding was the gas tank size to a diesel one so that the fuel gauge shows correctly, sucks that they don't have the options as easily available for the other gauges as well |
04-29-2024, 07:38 AM | #70 | |
Rep 59
04-29-2024, 07:39 AM | #71 |
Rep 59
Can u code the cluster on BimmerCode like you could with 6wa
04-29-2024, 07:44 AM | #72 |
Rep 59
I also have manual so will it tell me what gear to go in like my current cluster or tell me the gear its in like f80 or will it show nothing
05-19-2024, 07:24 PM | #73 | |
Rep 94
cluster virginizer NY
I know im a little late but what are the chances that you can connect me with the guy in ny that virginized your cluster?
05-21-2024, 01:40 PM | #74 |
Rep 17
Off topic, but I am proud to be the new owner of MoeTE87 former 340i! The M3 cluster works like a dream and looks awesome. Its a really nice touch!
hooligan_G016524.50 |
07-11-2024, 07:55 AM | #75 |
Rep 30
Drives: 2018 BMW F30
Hello, I was able to follow the thread and get the F80 cluster working on my F30 MT. But the font and details below the dials (tacho) is just like the F30. Can someone direct me to the correct fields to be coded to get the F80 font. As mine is a MT I did not install the adapter.
07-16-2024, 05:59 AM | #76 |
Rep 59
07-30-2024, 06:31 AM | #77 |
Rep 4
I dont know if this will help anyone but I managed to get my gears working, my rev limiter working, with no fault codes on dash.
See me giving it some in the video below after I installed my new f80 cluster 🫡 If you got any questions on how Ill try my best to help https://jumpshare.com/v/B8ectSRWpkKOIwNM4rLU |
08-15-2024, 07:38 AM | #78 | |
Rep 10
08-28-2024, 08:03 AM | #79 | |
Rep 30
09-14-2024, 07:29 AM | #80 | |
Rep 10
If you have a manual gearbox I believe it will show the gears without the adapter or maybe you need XHP for them to show, I am not 100% sure as I have an automatic myself. For an automatic you can code the cluster as a manual and it will show gears 1-8 with the shifter in manual or sport, in drive it will not show anything (no D), P won't show, R and N will show when selected. |
09-17-2024, 01:34 PM | #81 |
Rep 80
Love the F80 look but if you want even cheaper easier option, its not too hard to change the LEDs on the og cluster for the F30 all you have to worry about it getting the needles lined up correctly and that was the worst bit by far. These LEDs cost me $15 and all I needed was a sauder and tweezers.
09-17-2024, 02:04 PM | #82 |
Rep 568
Drives: 2019 440i XDrive GC
Likely going to be parting out my F80 cluster/adapter in the next month or 2 if anyone is interested, hmu.
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
09-17-2024, 05:11 PM | #83 | |
Rep 30
09-25-2024, 07:11 AM | #84 | |
Rep 10
I am fairly certain that it's just a matter of some coding and you should be able to see them without the adapter or xhp as I don't have those on my automatic car |
10-08-2024, 04:09 PM | #86 |
Rep 48
10-08-2024, 04:10 PM | #87 | |
Rep 48
BMW_LOGO: ag (00) -> M3 (06) DIG_KVA_BEREICH: 20_l/100km (14) -> 30_l/100km (1E) HUD_LOGO: wert_01 (00) -> wert_02 (06) KL_PREDRIVE_F51_DTC_SCHRIFT: nicht_aktiv (00) -> aktiv (01) DSC_ENABLE: nicht_aktiv (00) -> aktiv (01) M_DRIVE_BLINKFREQUENZ: wert_02 (00) -> wert_01 (06) SPA_ENABLE: aktiv (01) -> nicht_aktiv (00) SPA_IST_GANG_ENABLE: nicht_aktiv (00) -> aktiv (01) ALLRAD: allrad (01) -> kein_allrad (00) M_VARIANTE: ag_variante (00) -> motorsport (01) VZA_ENABLE: aktiv (01) -> nicht_aktiv (00) BR_KENNUNG: f30 (04) -> f80 (0B) TACHO_HUD_HYSTERESIS: wert_01 (00) -> wert_02 (02) SU_SW_DRDY_TIMEOUT: aktiv (01) -> nicht_aktiv (00) SU_SW_DRDY_ALIVE: aktiv (01) -> nicht_aktiv (00) SU_SW_DRDY_APPL: aktiv (01) -> nicht_aktiv (00) SU_SW_DRDY_2_TIMEOUT: aktiv (01) -> nicht_aktiv (00) SU_SW_DRDY_2_APPL: aktiv (01) -> nicht_aktiv (00) DISP_DCRN_ASST_APPL: aktiv (01) -> nicht_aktiv (00) MOST_LISTE_N_V_EMPFANGEN: aktiv (01) -> nicht_aktiv (00) CTR_DISP_M_SYS_TIMEOUT: nicht_aktiv (00) -> aktiv (01) CTR_DISP_M_SYS_ALIVE: nicht_aktiv (00) -> aktiv (01) CTR_DISP_M_SYS_APPL: nicht_aktiv (00) -> aktiv (01) ST_MDRV_2_TIMEOUT: nicht_aktiv (00) -> aktiv (01) ST_MDRV_2_ALIVE: nicht_aktiv (00) -> aktiv (01) ST_MDRV_2_APPL: nicht_aktiv (00) -> aktiv (01) TNK_FILTER_STEIGEND: 90_liter_h (66) -> 150_liter_h (AA) TNK_FILTER_FALLEND: 90_liter_h (66) -> 150_liter_h (AA) TNK_RW_VERBRAUCH: 8l_100km (10) -> 10l_100km (14) KI_PIA_ANALOG_RW_KVA: aktiv (01) -> nicht_aktiv (00) KI_PIA_M_SPORT_DIGI_TACHO: nicht_aktiv (00) -> aktiv (01) HUD_PIA_M_SPORT: inaktiv (00) -> aktiv (01) FDS_MENUE_TEXT_1: menue_3 (01) -> menue_4 (02) FDS_MENUE_SIGNAL_1: menue_3 (05) -> menue_4 (04) FDS_MENUE_TEXT_2: menue_3 (02) -> menue_4 (04) FDS_MENUE_SIGNAL_2: menue_3 (04) -> menue_4 (03) FDS_MENUE_TEXT_3: menue_3 (04) -> menue_4 (06) FDS_MENUE_SIGNAL_3: menue_3 (03) -> menue_4 (07) FDS_MENUE_TEXT_4: menue_3 (06) -> menue_4 (0F) FDS_MENUE_SIGNAL_4: menue_3 (07) -> menue_4 (0F) FDS_MENUE: menue_3 (03) -> menue_4 (04) |
10-08-2024, 04:17 PM | #88 | |
Rep 48
