BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F36 noise from engine bay
      09-14-2024, 10:14 AM   #1
X3MDG
Drives: F36 440i g82 M4
https://vimeo.com/1009456345?share=copy
My 4 series has started making a metallic rattle coming on and off the throttle (gently) in first and second gears.
It’s not related to road surface. Only light throttle inputs and not present above 20mph.
Anyone have any idea?
Thank you!
      09-14-2024, 02:00 PM   #2
cfm56d7b
Can you provide more details: engine type, mileage, prior maintenance history?
      09-14-2024, 04:57 PM   #3
Wires
Drives: 2016 340i xDrive
When you get in and out of the throttle, the engine will rock on the motor mounts. Maybe the mounts?
It's at such a low frequency that it doesn't sound like it's internal to anything rotating (engine, transmission, driveline). Those would have sounds matching RPM or road speed.
      09-15-2024, 05:55 AM   #4
X3MDG
2018 440i B58, 50,000 miles, full main dealer service history (at recommended timelines)
Thank you!
      09-15-2024, 05:56 AM   #5
X3MDG
This was my initial thought too. Just found it a bit odd it doesn’t do it at all at higher speeds when I’m rapidly accelerating and lifting off the pedal.
      09-15-2024, 08:37 AM   #6
Wires
Might be how the engine is loaded at higher speeds, etc?
      09-15-2024, 08:48 PM   #7
monster6a2
monster6a2's Avatar
Drives: f30 335i xdrive
Someone forgot their 10mm socket in the engine bay lol
Fr tho it just sounds like something I’d lose.
I’d check for axle play, it’s not engine related that’s fs
