08-19-2017, 04:42 PM | #89 |
Rep 943
Drives: 2012 328i Modern Line
Every time I?ve coded my car I?ve had the engine running.
:wave:
08-19-2017, 07:00 PM | #90 |
Rep 216
I don't think there is any argument whether it CAN be done with the engine running ..... the point we are trying to make is that you are probably better off not having it running.
Do it any way you like.
2017 340i M Performance Edition: Fashion Grey, MPPSK, M performance front splitter, rear diffuser, side sills, black grille, CF spoiler, 405M 20s, 8AT, full Marino interior and dash, adaptive suspension
08-27-2017, 07:17 PM | #91 |
Rep 147
Drives: '17 328d M-Sport Touring
So I've had success with most things but it seems as if when my wife drives the car, some of the coded things don't work on her profile. Does this seem odd or has anyone tried to load their other profile and see if it is all the same?
08-28-2017, 11:24 AM | #92 |
Rep 15
Won't code
Went through the process of identifying vehicle, verifying coded items, changed a few and when I went to code, I received the following message in the attachment. What am I missing?
2017-440i, Mineral Grey, Black Leather, 6 M/T, 21C/ZCW/ZDA/ZDB/ZTP/ZTR/ZMP/Apple Car Play/Clear bra/Tint/black M kidneys/RW Carbon rear diffuser/black chrome exhaust tips/ PS4s wrapped on 763 rep wheels
08-28-2017, 01:03 PM | #93 |
Rep 130
Have you purchased bimmercode? You can go to the settings in the app to check / purchase
F30Beast335i114.00 |
08-28-2017, 02:13 PM | #94 |
Rep 15
I thought that I did but I checked and that did it! Thanks
08-29-2017, 05:54 AM | #96 |
///M SubDriver
1833
Rep 2,782
Drives: 2017 M3, 2020 X7 40i
I just got this app yesterday and began playing with it.... You need to go into "Expert Mode" to code this particular feature. But if you are not familiar with how to change the parameters available in Expert Mode, I would recommend you stay away from that as you can seriously mess up your car (but if you do, it is usually reversible - but not worth the headache IMO). If you go to the coding section of the forum you can learn more about how coding works and what the parameters mean in Expert Mode to code some of the options that the developer has not already put into the app.
Bimmercode will "automatically" code several of the common features/options that people want. These are the ones that are available on the app and many of these features require parameter changes to multiple modules/ECUs in the car. If an option is not available, like easy access, you will need to use Expert Mode to change the individual parameters to get that function working. I coded easy access on my car using E-sys and my laptop some time ago. What I like about this app so far is that Expert Mode appears to give you access to the same parameters as using a laptop. Except using the app on my phone is less cumbersome than using a laptop, but you still need to understand what the parameters mean before you change them. If you are curious, this thread here provides additional info on the parameters that must be adjusted to get this feature to work, including how to take measurements so the seat moves back/forward to where you want - this is what I did to get it working in my car. I have not personally verified yet, but all of the parameters mentioned in that thread should be accessible in Expert Mode so in theory, you could use the Bimmercode app to get the easy entry feature working. But I still recommend you read up on the basics of coding before messing around in Expert Mode - it will make using the Expert Mode feature much easier (and safer). I am sure that as time goes on, the developer will add more options to the app, such as easy access, so a user does not need to use Expert Mode to add this capability.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) Last edited by jmciver; 08-29-2017 at 06:11 AM.. |
scostu1623.00 |
08-29-2017, 08:30 AM | #97 |
Rep 50
Drives: 330e & 218 GC MSport
What about BMWs guarantees if you fiddle with the settings like this? (I'm having an 2017 330e)
08-29-2017, 11:30 AM | #98 | |
Rep 158
08-29-2017, 05:47 PM | #99 |
Rep 832
Drives: 2019 G01 X3
Coding success with Bimmercode and Vgate iCar2!
Super easy to get connected and start coding with my iPhone 7 Plus. Expert mode allows you to get everything you want using a cheat sheet for any options not already listed in the app. I did get some warnings/errors (e.g. Lighting and Chassis Stabilization) after coding a few things (even with engine not running), but they went away on their own after turning the ignition off and on, so I'm not too worried. Significantly less work than figuring out E-Sys... Here's the full list of what I was able to successfully code on my 2015 F32 435i: Disable iDrive legal disclaimer Disable camera legal disclaimer Fold mirrors when locking with keyfob, change delay to 0.2 secs Unfold mirrors when unlocking with keyfob Change iDrive startup animation to M logo Display individual pressure and temperature on TPMS display Enable Sport Displays (hp/tq) Turn off radio when driver door is opened Unlock driver door when ignition off Enable digital speedometer on instrument cluster Disable initial seat belt warning Change seat belt reminder duration to 5 secs Auto Start-Stop set to off by default Did I miss anything? Last edited by dr.roro; 08-30-2017 at 09:54 AM.. |
08-29-2017, 07:58 PM | #100 | |
Rep 2,036
08-29-2017, 09:33 PM | #101 | ||
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
08-30-2017, 07:40 AM | #102 |
Rep 832
Drives: 2019 G01 X3
08-30-2017, 10:39 AM | #104 |
Rep 2,036
08-30-2017, 11:06 AM | #106 |
Rep 1,476
Isn't that only on the 328/330?
08-30-2017, 12:22 PM | #107 |
Rep 832
Drives: 2019 G01 X3
If I have it, I definitely haven't noticed it...
08-30-2017, 12:55 PM | #108 |
Rep 1,907
answers please
1) Is it possible to code ASD on a 330D?
2) Also is it possible to code the drivers seat to move back once the ignition is switched off & move back into position when you get back in & press start button? (my previous MB used to have this) 3) Using bimmercode app how do you revert back a code i have done (backup?)
Happy Motoring
Evdok |
08-30-2017, 03:07 PM | #109 |
Rep 2,036
08-30-2017, 03:10 PM | #110 |
Rep 2,036
evdok819.00 |
