11-10-2018, 05:46 AM | #1 |
Rep 6
6WB Issue
hello, I made kombi retrofit for 6WB I added 6WB to FA and coded HU_nbt evo and kombi everything works fine but oil temperature and diesel do not work well. when I turn off the ignition the diesel does not come to zero is a 1/3 and the temperature seems to be the opposite wronf side pointer. will it be some coding or do I have to also add the FEM ICM etc …
i filling full up the pointer marks out the scale, analyzing well the pointer always points to 1/3 higher what should mark with the car off should point to zero points to wrong to 1/3 above when full fil points 1/3 off range The oil temperatura pointer are on wrong direction (like a mirror) Last edited by ZECAR33; 12-07-2018 at 09:36 AM.. |
11-10-2018, 09:21 AM | #2 |
Rep 2,302
I have not seen this problem yet.
Was it a new one? But you can try to code the ICM or manually change the value "IcmKod_B_FPK" to "verbaut". It is normally not necessary but it's a try. |
11-10-2018, 11:55 AM | #3 | |
Rep 6
I bought on eBAY, the description said it was new, but have some use signs probably "virginized" when install took the km and my vin car |
12-07-2018, 12:54 PM | #6 |
Rep 66
I think those sub-dials still use physical needles, just made to look digital. Is it possible they opened up the cluster when they virginized it and accidentally put the needles on incorrectly?
