BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Dyno Results are here!!!
      12-08-2018, 03:12 PM   #23
Dheeth-G80
Dheeth-G80's Avatar
226
Drives: 2021 G80 M3C
Originally Posted by BEAR-AvHistory View Post
Originally Posted by Dheeth-F30 View Post
That 378 I calculated based on this online charting tool haha idk how accurate that is - https://www.mk5cortinaestate.co.uk/calculator4.php
Its not just, a WAG based on an "Average" loss factor. I know my COBRA 5.0L does not have over 600 horsepower at the crank.
Haha yeah idk if this is accurate or not but maybe as you said its 370, don't even care since its not WHP
2021 G80 M3C - Current
2017 G30-B58 - Sold
2013 F30-N55 - Sold
      12-08-2018, 03:13 PM   #24
Dheeth-G80
Dheeth-G80's Avatar
226
Originally Posted by valve float View Post
sorry but if OP is PWG and running ACN91 then numbers are in ballpark...
PWG and 91oct is the worst possible combination for a 'tuned' N55 F30...
You're right, it's PWG and 91ACN
2017 G30-B58 - Sold
2013 F30-N55 - Sold
      12-08-2018, 03:14 PM   #25
Dheeth-G80
Dheeth-G80's Avatar
226
Yeah bro I'm hella bummed. These are all 4/5/6 gears. 315 is 6th gear and he said he hit 160mph in 6th. 4th gear was the shortest so hits redline too fast so 5/6 gears there. 4th got hella torque 386/381 wtq
do you have datalogs?
Yes I do, how can i attach them here? I can email them to you. I don't understand those but it be nice if you can give me some input
So are you gonna post some logs so people can evaluate why the car had such a low hp dyno? Everyone just speculating in here without logs.
Look at those pulls on the dyno how they ramp up all weird, something weird was going on for sure and is likely related to the tune.
I want to but the logs are in WP8 file format which opens up only in Dynojet's native software and I wasn't able to properly convert them in CSV format to post on Datazapp
2017 G30-B58 - Sold
2013 F30-N55 - Sold
      12-08-2018, 05:26 PM   #26
akgambino
Drives: 2013 F30 335xi M-Sport (PWG)
Surely u have other logs of the car. Doesn't need to be logs from the dyno run
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
      12-08-2018, 05:33 PM   #27
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
Agree that the numbers look far too low.
OP, if you logged using bootmod3, go to the datalogs screen, click on the drop down menu at the far right of the log, click share link, it will open a pop up tab (make sure you disable 'block popups' in your browser) and copy and paste the link of that pop up tab.
EDIT: saw you didn't log with bootmod3 for the dyno runs, but any logs from another time are better than no logs.
      12-08-2018, 05:45 PM   #28
F30_SixSpeed
F30_SixSpeed's Avatar
1171
Drives: 335i M Sport
Those numbers are low. A stage 2 PWG stock turbo should be at least 340-350+ on pump gas. I did quite a bit more on my last dyno with the stocker so I'm even being conservative.
2013 F30 335i 6MT - Stock PWG Turbo, FBO, 93 octane, BM3 S2 v6 map
Best Pull: 383whp, 494trq
335i M Sport 6MT || PS2 Turbo, FBO, XDI-35 HPFP, BM3, KW, MP BBK, OEM+
INSTAGRAM || BUILD THREAD
      12-10-2018, 09:11 PM   #29
Dheeth-G80
Dheeth-G80's Avatar
226
Posted the logs under the main post bro, can you help take a look?
2017 G30-B58 - Sold
2013 F30-N55 - Sold
      12-10-2018, 09:12 PM   #30
Dheeth-G80
Dheeth-G80's Avatar
226
Did some logging, see if that helps, links under the main post
2017 G30-B58 - Sold
2013 F30-N55 - Sold
      12-10-2018, 09:14 PM   #31
Dheeth-G80
Dheeth-G80's Avatar
226
Logs posted under the main post bro, see if that helps?
2017 G30-B58 - Sold
2013 F30-N55 - Sold
      12-10-2018, 09:22 PM   #32
akgambino
Logs look pretty normal to me for stage 2 stock pwg turbo, aside from high wgdc in upper rpm range that is odd
Is this ots v7.1 91oct map or acn91 map?
      12-10-2018, 09:23 PM   #33
Dheeth-G80
Dheeth-G80's Avatar
226
Logs look pretty normal to me for stage 2 stock pwg turbo.
Yes sir, it is ACN91 OTS map
2017 G30-B58 - Sold
2013 F30-N55 - Sold
      12-10-2018, 09:32 PM   #34
Dheeth-G80
Dheeth-G80's Avatar
226
Originally Posted by agentorange View Post
All except the black plot show evidence of torque management or timing being pulled between 2k and 3k rpm. Is that the 4th gear pull?
Edited to add: Maybe it's the boost that is being pulled.
Posted logs under the main post bro, if you wanna take a look?
2017 G30-B58 - Sold
2013 F30-N55 - Sold
      12-10-2018, 09:32 PM   #35
Dheeth-G80
Dheeth-G80's Avatar
226
Somethings way wrong. This is my pure stock base run 2011 335is BMW advertised 320BHP & first cut with only a JB4 map 2 on 94 octane, no other add-ons
Pure stock baseline. Track test 13.0 to 13.4. seconds 107 to 110MPH. Compared favorably with other stock 335is 7DCT & other dynos
JB4 out of the box @ 94 octane
BTW not sure how you are getting 378BHP @ the crank out of those numbers.
Logs posted under the main post, if you could help take a look?
2017 G30-B58 - Sold
2013 F30-N55 - Sold
      12-10-2018, 09:42 PM   #36
F30_SixSpeed
1171
Boost and timing look decent, at least acceptable and on par. I don't like how WGDC is at 100% up top and boost is only 11 psi or so. Seems like the turbo is overworking quite a bit, possibly a boost leak. PWG turbo should only be in the ~70s or so on S2.
      12-10-2018, 09:44 PM   #37
rjd_F30
rjd_F30's Avatar
I'm not an N55 guy, but I don't see anything out of the ordinary that would lead to low power numbers, but hopefully someone will come up with something for you.
      12-10-2018, 09:45 PM   #38
Dheeth-G80
Dheeth-G80's Avatar
226
But it still doesn't equate to how I made about 30-50whp less than I should've, correct?
I sent it to bm3 people as well so curious to see what they have to say about it.
2017 G30-B58 - Sold
2013 F30-N55 - Sold
      12-10-2018, 09:46 PM   #39
F30_SixSpeed
1171
Can you get dyno graph in STD smooth 5 correction factor? I see you have uncorrected... was it very hot that day?
      12-10-2018, 09:48 PM   #40
Dheeth-G80
Dheeth-G80's Avatar
226
Yeah I can request that to the dyno shop. Actually no, it was about 55 but inside it does get hot sure, after I think 4th run, car was heat soaked but either way, we didn't make more than 315 and lowest 302
2017 G30-B58 - Sold
2013 F30-N55 - Sold
