BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Chassis Stabilization
      12-01-2021, 07:32 PM   #1
alexander7599
Alexander Hartunian
alexander7599's Avatar
Drives: 2018 BMW 440i
2018 BMW 440i  [0.00]
Exclamation Chassis Stabilization
2018 440i F32
The car is stock other than the VR Performance intake I put it yesterday. No tune or anything else. During my install, I had to jack the car up to get under the engine to retrieve a tool I had dropped and when lowering the jack, it came down a little hard. Not dead weight drop, but controlled, just a little faster than I would like.
Turned the car on for a test drive and got a chassis stab. code which went away after about 15 seconds. I ran Carly to see if everything is fine by running for codes, clearing them, and running again to find no fault codes.
The car has 25,000 miles and just got an oil change the week before, runs healthy. Does anybody have another theory about the code? I suppose it was from the car coming down a little too hard. No problems since and the intake sounds amazing!
2018 F32 440i - Black Sapphire Metallic - KW Suspensions V1 | VRP Intake | VRSF Catless Downpipe | Dorch Stage 2 HPFP | MHD OTS Stage 2 E40
      12-01-2021, 09:37 PM   #2
dmanb2b
Drives: G07, F97, F30, E90, E46, E30
what were the codes before you cleared them?
      12-01-2021, 09:56 PM   #3
alexander7599
Alexander Hartunian
ABS & Stability Control
801A56 @ 22880 miles (3k miles before intake was installed)
801A55 @ 21421 miles (4k miles before intake was installed)
Dynamic Stability Control (DSC)
D35A53
480AB8 @ 25773 miles
Integr. Chassis Module
480134 @ 22852 miles
D014A1 @ 25773 miles
I currently have 25855 miles, I don't think I drove 82 miles since that intake was installed yesterday, I live in a small town. Keep in mind, throughout the install, I had my battery disconnected, which may have resulted in some "reboot" or "reset" of the chassis.
dmanb2b2124.50
      12-02-2021, 09:29 AM   #4
Nickski06
Drives: 2016 340i M-Sport
When I changed out my front reflectors, I had the car jacked up and manually moved the tires to access the inner fender. Next time I drove it I got the chassis stabilization warning. Shut it off, restarted and never saw it again.
      12-02-2021, 01:45 PM   #5
G.Newt
Drives: CT4-V Blackwing 6MT
D35A53
[COLOR="DarkOrange"]480AB8 @ 25773 miles[/COLOR]
[COLOR="darkorange"]D014A1 @ 25773 miles[/COLOR]
Yeah that's happens. You'll want to turn your steering wheel full lock left and right and then drive. It'll go away almost immediately after a battery disconnect/replacement.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      10-28-2022, 08:18 PM   #6
Jboowan
Drives: 2018 430i M-Package
D35A53
I have the same problem except my steering went out. Any similar problems out there?
440i, b58, chassis stabilization, install, intake
