01-11-2022, 11:42 PM | #1 |
Rep 23
Tire suggestion for 513M on F30 Msport
Currently, I am running staggered 400Ms 225/45/18/8j front and 255/40/18/8.5j in the back.
Now I have opportunity to upgrade to staggered 513Ms with factory tires MPSS 255/40/18/9j and 275/40/18/10j. My car is 330i with Msport suspension and brakes, so I am worried about 513M's rub or misfitting issue. Can I run 225 in front and 255 in the back with 513s? Or which tire setup should I choose to avoid rubs, wrong MPH readings and issues. |
01-12-2022, 02:03 AM | #3 | |
Rep 23
What about wrong readings of speed and milage? Will it negatively affect gear ratios or transmission? |
alohasurftoad3076.50 |
01-12-2022, 02:47 AM | #4 | |
Rep 4,324
If you want OEM diameter, 255/40/18 front, 285/35/18 rear is possible but the tire shoulders will poke a lot and front will be close to rub at full lock turn. |
abayramov13.50 |
01-12-2022, 03:18 AM | #5 |
Rep 4,324
here are some F30 with 255/40/18 front, 275/40/18 rear, tire sizes from M3/M4, which you could try as well.
https://f30.bimmerpost.com/forums/sh....php?t=1417070 https://f30.bimmerpost.com/forums/sh....php?t=1537895 https://f30.bimmerpost.com/forums/sh....php?t=1525586 https://f30.bimmerpost.com/forums/sh....php?t=1396368 this one is 235/45/18, 265/40/18 on x-drive wheel gap. your m-sport gap rwd is lower and look better. https://f30.bimmerpost.com/forums/sh....php?t=1712886 |
abayramov13.50 |
01-12-2022, 04:26 AM | #6 | |
Rep 23
01-13-2022, 12:56 PM | #8 |
Rep 133
Drives: F32 435dx
Whatever alohasurftoad advised you. But as weehe126 said, there's no rubbing front or rear with the M3/M4 dimensions (255/40F, 275/40R). I would keep the same dimesions as is on the 513M since you are not x-drive.
abayramov13.50 |
01-20-2022, 09:32 AM | #9 |
Rep 1,714
255/40/18 square
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190 |
abayramov13.50 |
