02-21-2020, 02:04 PM | #1717 | |
Rep 500
Drives: BMW 330e F30 M-sport
You are likely to rub both in front and rear with KW V1 and those wheels. As an example: My car is lowered around 35mm in the front, I've got maybe 10mm clearance with 235/40R19 on 8.5" wheels with ET35 offset. Rear I'm probably lowered around 40mm, with 265/35R19 on 9.5" wheels with ET40 I was rubbing slightly. When I replaced the tires with 255/35R19 it just cleared. Your suggested wheels will poke out more both in the front and rear than mine. Mine are pretty flush with the fender. Looks like this:
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
02-26-2020, 06:33 AM | #1719 | |
Cheapskate
4447
Rep 4,993
It won't look good and will ride poorly. I doubt any forgiato wheel fits our car's styling anyway. |
04-13-2020, 07:06 PM | #1720 |
Rep 34
Only took a year, but finally got these on.
Volk TE37SL - 18x9.5 +38 (CTR spec) 5mm spacers 255/40 Falken FK510 Lowered on H&R Super Sport Coils next to close that gap a little more! Last edited by Jordan1scool; 04-13-2020 at 08:08 PM.. |
04-15-2020, 02:50 PM | #1721 |
Rep 1
I've read through this whole post now, so many nice wheels and setups.
So much knowledge, no doubt through some trial and error. I dont know where you find the patience, guess i have something to learn there. I have a question, as many others about some wheels. I'm looking at some Ferrada FR4 for my F30 '12 Wondering if this size will fit om my car 20" 9.00 ET 35 Front and 10.50 ET 38 in the rear. Original m-sport suspension atm. |
04-15-2020, 10:40 PM | #1722 |
Rep 19
need help with tire sizing
i just picked up some bbsrs2 18x8.5+22 18x10+25. looking to get the tires flushed with the fenders i'm thinking 255/35 for the rear but kind of stumped on the front. 225/40? any 18 setups for reference |
04-16-2020, 09:33 AM | #1723 |
Rep 46
finally got fenders rolled and wheels installed:
18x9 ET30 235 18x9.5 ET35 265
2012 f30 n55 6 M/T, RWD
VRSF Catless DP/CP, CSF FMIC, BM3 Stage 2, KW V3 |
04-17-2020, 06:27 AM | #1724 |
Cheapskate
4447
Rep 4,993
I want some TEs so bad, but I am so in love with my setup.
04-27-2020, 09:54 PM | #1725 |
Rep 9
Advan RS-D
I have Advan RS-D 20x9 +17 20x10.5 +25. The Fronts look really mean and aggressive but the rear stick out about an inch to wide, in know i can roll the fender but i really dont want to do that, is there anything i can do to fix the problem without having to buy new wheels?
04-28-2020, 03:16 AM | #1726 | |
Cheapskate
4447
Rep 4,993
05-01-2020, 09:22 AM | #1728 | |
Rep 271
I'm thinking like -4 to -4.5 and a 245/30, it would look off though if your front camber didn't match |
05-01-2020, 12:34 PM | #1729 |
Cheapskate
4447
Rep 4,993
18x8.5 et30 245/40
18x9.5 et40 275/35 It'll look off with that much camber regardless |
05-01-2020, 07:24 PM | #1730 |
Rep 271
-4 is pretty mild imo if you are going for that real stanced out look. My genesis was -4 all around and the tires didn’t even wear that uneven. I’d guess most the guys on air are hitting that or more when they air out.
05-07-2020, 11:47 PM | #1731 |
Instagram @F82_Al
33
Rep 143
Was wondering if i could get some insite here. looking at a set of bbs ch-r and was wondering if they would fit. Be mindful im on Air so car will be airing out. Front: 19x9.5 et 35 Rear: 19x10.5 et 25. I know the fronts will be fine but im worried about the rears clearing/fitting
Insta @f82_al
05-08-2020, 03:32 AM | #1732 |
Rep 1
Hey guys new to the forums! I just had a question? I'm looking at some wheels and I was looking to get some opinions. The wheels are 19x10 +17 front and 19x11 +15 rear, would they be possible to run? I am currently on coil overs max low about 2-3 inches off the ground and with around -3 camber all-around current setup is 19x8 +10 front and 19x8 +23 in the rear with no fender modifications.
still working my way around the forums please if I'm doing something wrong feel free to chime in. Thanks in advance! |
05-08-2020, 10:50 AM | #1733 | |
Rep 19
05-08-2020, 10:55 AM | #1735 |
Rep 19
attachments didn't uplpad
DThr33635.50 Alpine-F80200.50 |
05-08-2020, 03:52 PM | #1736 |
Rep 150
Drives: 2016 BMW 340i
How do you guys avoid scraping the bottom of your cars when driving over things like speed bumps and such?
2016 340i | EB | M Sport
05-08-2020, 04:16 PM | #1737 |
Cheapskate
4447
Rep 4,993
Just let it scrape. It's not a big deal. The only things I scrape are the under the front bumper/air deflectors and the jack points. I'd rub my tires before I have to worry about hitting something important like my oil pan or gas tank.
05-10-2020, 06:11 PM | #1738 |
Rep 19
went out to take some photos today
kern4174446.50 claytonap178.50 DThr33635.50 Stlthnmrdrd156.50 HondaGoneRogue432.50 TBMNYS12.00 F30_SixSpeed1170.50 |
aggressive, f30, low, slammed, stance |
